HELP!! armrest broken
ddonnell
ddonnell is offline
PostPosted: Sun Apr 06, 2008 7:23 pm    Post subject: HELP!! armrest broken Reply with quote
So one of my old friend that I drove to school would always play around with the armrest since it wobbled a little bit. I was too lazy to ever fix it and he only made it worse and worse! Evil or Very Mad So this past week I was going surfing with a buddy of mine and he noticed it was broken. I investigated there and found a bolt out of place. I put the bolt in the dash ash tray and enjoyed the surf. SOO now here I am begging you to help me fix it. the black bar that is in this pic won't move and there is a hole to place the bolt that I found. I have no clue how to fix it but I am thinking that the one little pin should get pushed through so I can take the arm rest off and work on it a little easier.HELPPPPP.
1990 Vanagon Carat-SOLD
1995 Dodge Ram 2500 4x4 V10
1966 Baja "The Beast"
instagram #bajabugproject
View user's profile Send private message Facebook Classifieds Feedback
floggingmolly
floggingmolly is offline
PostPosted: Sun Apr 06, 2008 8:34 pm    Post subject: Reply with quote
Well, your photos are awful, but is the problem that the mounting bracket came off the seat, but is still in the armrest? Or maybe just the one bolt came out, so the armrest is only half atttached now? If so, the solution depends on your year of van. My 85 has a small plastic cover on the outside of the armrest, when you remove it, there is a hex head bolt that can be removed which allows you to remove the pivot post form the armrest and gives you access to the two holes for the mounting bracket to the seat. On later models I think the arrangement is slightly different.
If yours is like mine and you need photos, let me know.
'85 Wolfsburg Weekender
vwlovr
vwlovr is offline
PostPosted: Sun Apr 06, 2008 8:42 pm    Post subject: Reply with quote
you are correct you have to push that pin through in order to rescrew the mounting plate. soak it with a penetrating lube, then get out a punch and start hammering and cursing. using something that is as large as the pin so that you don't go inside it and make it larger.
if the threads inside are stripped you could probably take of the seat back, open up the bottom and reach in the put some nuts behind it, after maybe drilling out the stripped threads?
good luck
ddonnell
ddonnell is offline
PostPosted: Sun Apr 06, 2008 8:48 pm    Post subject: Reply with quote
good luck
perfect thank you
ddonnell
ddonnell is offline
PostPosted: Sun Apr 06, 2008 8:50 pm    Post subject: Reply with quote
the photo were the best i could do. Embarassed my van is a 90 and where you have the plate, i have pleather. you can feel the distinct hole but without breaking it you cant get through. thanks though Sad
ak_runner
ak_runner is offline
PostPosted: Mon Apr 07, 2008 1:27 pm    Post subject: Reply with quote
Take a 1/4" bolt at least 4 inches long and use it drive the pin out. Once it is out you can reinstall the screw holding the bracket onto the seat back, use a little loc-tite and do both screws. Then put the armrest back in place and use the bolt to drive the pin back in. No need for penetrating lubricant, plus it will just make a mess on your seat and/or carpet. I slide a piece of plastic(credit card, drivers license, etc) between the armrest and the pin as I remove and install it to prevent damage to the upholstery.
techbot
techbot is offline
PostPosted: Mon Apr 07, 2008 2:10 pm    Post subject: Reply with quote
hey ddonnell.. i can't help w/ you armrest but maybe a bit with your pictures. if your camera has a "macro mode" (sometimes signified with a close-up of a flower icon) try taking those close up photos with that. I've found that for techy closeup shots like that it makes a much cleaner picture! I took a lot of crummy close ups before I discovered what that flower icon meant!!
good luck w/ your armrest!
1991 Westfalia Multivan
vwlovr
vwlovr is offline
PostPosted: Mon Apr 07, 2008 3:04 pm    Post subject: Reply with quote
maybe so, but if it's seized in there good, it's a good helper. i spent about 35 mins of sweat and cursing before lubing one and it came out within minutes afterwards. i then pre-lubed the other three and they were all a lot less painful.
ddonnell
ddonnell is offline
PostPosted: Mon Apr 07, 2008 3:30 pm    Post subject: Reply with quote
I did it today during my lunch break and didn't need any lube. But thanks because once I got off the arm rest it was evident what I needed to do.
kenmag
kenmag is offline
PostPosted: Mon Apr 07, 2008 3:32 pm    Post subject: Reply with quote
Techbot said it!
Macro is usually depicted by a symbol like this..
Cheers
87GL Westy/suby ej22
87GL tintop/suby ej22
05 Golf TDI
95 jetta GLX
floggingmolly
PostPosted: Mon Apr 07, 2008 4:16 pm    Post subject: Reply with quote
That's usually the way. Took me a while to figger out how to remove the armrests the first time when they were loose. Now I'm like a NASCAR pit stop when it comes to tightening the armrests. Very Happy
Also in remodeling a home. EVERYTHING took longer than it should cause I was figuring everything out the first time, hoping never to have to do it again. So no benefit of experience there. That's where the learning curve can suck. If you only have to do it once, you don't benefit from the knowledge acquired, but if you do it right, at least you are done.
ddonnell
ddonnell is offline
PostPosted: Mon Apr 07, 2008 6:56 pm    Post subject: Reply with quote
haha it's always tougher putting it back together Confused havent quite got that one figured out Surprised
