More questions on 67 Master Cylinder vs 71 & later
STG44
STG44 is offline
PostPosted: Fri Apr 11, 2008 9:49 am    Post subject: More questions on 67 Master Cylinder vs 71 & later Reply with quote
Hello from a first time poster..
1) I'm converting my '65 Bus to dual circuit master cylinder. Found a re-man master cylinder for a '67 Bus at a seemingly dirt cheap price of $37. Can the 67 MC be used and is the rod different or ??? I have seen postings that say the primary reason the '67 isn't used is the high cost.
2) If it's not feasible to use the '67 MC which early 70s MC should I get? The power assist is plentiful and roughly $60-$70 for reman ( yes I want an OEM but none to had in my area) BUT would the manual/standard MC be a better choice? Can't seem to find a manual cylinder for less than $200 but lots of power ones for $50-$75
Price isn't necessarily the defining criteria but efficient use of money is a part of the decision process. Biggest reason I want the 67 MC is because the I like the idea of split parts on my split BUS- pure ego on that! Thanks in advance guys!
BarryL Premium Member
BarryL is offline
PostPosted: Fri Apr 11, 2008 10:37 am    Post subject: Reply with quote
You're going to get a lot of opinions on this but I'm for the '67. The rod is different in length or something and I think hazetguy posted pics but there's a way to make the rod. Sorry for the flakey reply but I've never done either conversion, only worked on already installed ones. Reason I say '67 is cuz you can still buy the OEM ones and the difference in dough doesn't seem that much more in the scheme of things. I don't know about the mounting bracket on pre '67 vs '67 so check that out too: one may be farther or closer to the pedal or somesuch fubar.
420GOAT
Location: Wilmington, CA on a nice quiet street but still in the 'hood
420GOAT is offline
PostPosted: Fri Apr 11, 2008 11:15 am    Post subject: Reply with quote
I did the conversion and the 67 master is the best way due to proper pressure and bore size, i went with ate brand and it was 168 dollars at my cost!!! 40 for the res. used and 20 for the correct pushrod. not cheap but most correct in my opinion, many use bay m/c but the bore is larger which i believe is a higher volume but lower pressure which i feel is more important. a lot has been written up and i studied the situation for some time before i laid down the cash. good luck.
once you realize im not impressed we will get along just fine
ritchiet002
ritchiet002 is offline
PostPosted: Sat Apr 12, 2008 2:36 am    Post subject: Reply with quote
What is this? Is it a dual master?
LINK
http://www.autopartswarehouse.com/details/QQVolksw...33200.html
Somewhere there is a jar with your name on it!
From now on, I'm gonna connect the dots my own way!______________________________________
bill may
bill may is offline
PostPosted: Sat Apr 12, 2008 7:54 am    Post subject: Reply with quote
LINK
that looks like a M/C that has been foosed up.
Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
BarryL is offline
PostPosted: Sat Apr 12, 2008 9:01 am    Post subject: Reply with quote
It says that the picture doesn't necessarily match the part for sale. Yes it's a dual. Don't know 'zactly what issue its for but a lot of British cars use those Banjo style lines which are super trick. The wires just tells you if one or the other circuits had less pressure.
65 Deluxe
65 Deluxe is offline
PostPosted: Sat Apr 12, 2008 5:54 pm    Post subject: Reply with quote
I have used the 71 and later MC and they work fine. I have 87 944 Porsche turbo front disks with 68 rear bug drums for the Porsche pattern. What I had to do is create a spacer which was around 1/2 inch or so. This gives the proper clearance for the push rod and you can reuse the 67 master cylinder or use one out of a early VW rabbit. You can buy the adapter for $50 bucks and master cylinder from Wolfgang so you don't have to make a spacer. I like it because there isn't much play on the pedal and it stops on a dime.
Think big drive a bus...
Own it, drive it, and don't make it a trailer queen...
The VW Junkie,
55 Oval
56 Euro 23 Window
58 Krankenwagen (Mr. Kranken)
59 Fjord Blue Bug
61 Ragtop
61 Double Cab
64 Euro Squareback Model S
65 21 Window (Blue)
71 Deluxe Bay Window
Culito
11010101
Culito is offline
PostPosted: Sun Apr 13, 2008 11:30 am    Post subject: Reply with quote
I use the 71-79. Stops and feels great. Here's the adapter kit from Cip1:
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC20%2D4100
© CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote:
65 Deluxe
PostPosted: Sun Apr 13, 2008 11:41 am    Post subject: Reply with quote
And anyone can make that adapter. You have space to adjust the push rod so all you need is to have the spacer you create close. $60 dollars for a piece of aluminum is a little to high if you ask me.
The VW Junkie,
55 Oval
56 Euro 23 Window
59 Fjord Blue Bug
61 Ragtop
61 Double Cab
65 21 Window (Blue)
STG44
STG44 is offline
PostPosted: Fri Apr 18, 2008 2:44 pm    Post subject: 67 MC cylinder Reply with quote
Well ,I picked up my $40 67 VW dual circuit master cylinder today- IT WAS AN A.T.E. rebuilt by Bendix! I immediately tried to order 15 more but they would not accept my order; not even for just 2 more. Guess since they took my prepaid order they felt obligated for the one . I'm trying other sources.https://www.thesamba.com/vw/gallery/pix/thumbnails/433455.jpg[img]
https://www.thesamba.com/vw/gallery/pix/thumbnails/433455.jpg [/img]
I'd like to get together with other Split owners in Dayton Area
P-Dub
P-Dub is offline
PostPosted: Fri Apr 18, 2008 4:53 pm    Post subject: Re: 67 MC cylinder Reply with quote
Was this from your local auto parts chain, or online, or what?
