Posted: Wed Aug 28, 2002 11:24 am Post subject: Slipping Transmission |
Just put a new clutch,pressure plate,throw out bearing and clutch cable in my 65 Bus starts to slip when accelerate in 2nd,3rd and 4th gear. And info would be great |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Wed Aug 28, 2002 12:23 pm Post subject: Slipping Transmission |
Check that the cable is not too tight... how much free play do you have at the pedal?
Another possibility is a "spun" rear brake drum.... when the big nut is not tightend enough over time the hardend German steel splined shafts tear up the weaker cast iron of the drum and the splines eventually wear out... Pull both your rear hubcaps and take a look... Red rusty powder is a dead give away.... I'm not saying you don't have a clutch problem but this is real easy to check out and gives the same or similar symtoms up to the point that the vehicle will eventually go nowhere..... |
Posted: Wed Aug 28, 2002 1:17 pm Post subject: Slipping Transmission |
Thanks I'll check it out. Just pulled the engine out the fly wheel looks polished the clutch and pressure plate look good. And it looks like the transmission seal has a little leak but nothing on the clutch parts.
Thanks for the info
Jesse |
Posted: Wed Aug 28, 2002 1:47 pm Post subject: Slipping Transmission |
Did you pull the flywheel and replace the rear main seal and O ring?
If you have not you may want to read the thread titled "greasy rigid disc" some info there on this.... its on this page I think just a few days ago.... |
Posted: Wed Aug 28, 2002 1:50 pm Post subject: Slipping Transmission |
It is in the general column... but now pushed a page back...... |
