Dark Alley Dan Samba Member
Joined: November 23, 2005 Posts: 188 Location: The Land of Wind and Ghosts (AKA Edmonton, AB)
Posted: Thu Jul 06, 2023 12:04 pm Post subject: Bottom bunk - ventilation while sleeping? |
Howdy, all.
Just back from two weeks on Vancouver Island. Lovely place.
The Mrs. and I are sufficiently geriatric that climbing upstairs to sleep ain't happening. We sleep downstairs on the foldy bed with our heads toward the aft of the vehicle so we're not losing pillows to gravity all night and my feet have somewhere to go. When it's warm and humid, our respiration kinda build sup back there. By morning it's dampish and smells like morning breath.
That's as gross as it sounds.
Air exchange back there is non-existent. We have the hatch latch extension, but that just means losing things out a wee slot in the back.
Been thinking about installing a fan in the D-pillar - something small and quiet - that pulls air out of that space and exhausts it from behind the rear external side vents. If it exhausts out the rear (as we all do from time to time) it'll draw fresher air from the forward areas of the van, where air exchange is vastly better...
Have any of you done anything like this? Any ideas?
Cheers,
Dan _________________ Dark Alley Dan
______________________
I blame rap music. For everything. |
Timwhy Samba Member
Posted: Thu Jul 06, 2023 12:49 pm Post subject: Re: Bottom bunk - ventilation while sleeping? |
We have the RMW rear sliding window on the passengers side and a screen to fit it for ventilation. The guy that was producing the screens isn't making them any more.
Also have two USB fans and a 110v for shore power sites. Get the Bus Depot rear hatch screen w/ a zipper in the middle and you'll stop loosing things.
Also a sliding door screen will keep the air moving. _________________ '15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
http://www.youtube.com/user/TIMWHY2?feature=mhee |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15391 Location: Syracuse, NY
Posted: Thu Jul 06, 2023 1:48 pm Post subject: Re: Bottom bunk - ventilation while sleeping? |
I have a small $5 USB powered fan that is clipped back there.
any air movement is an improvement.
plus I like the white noise and the slight breeze, but I can divert it away if needed. _________________
Abscate wrote: |
kourt Samba Member
Joined: August 13, 2013 Posts: 2351 Location: Austin, TX
Posted: Thu Jul 06, 2023 2:35 pm Post subject: Re: Bottom bunk - ventilation while sleeping? |
Install a Caframo Kona fan under your spice rack as I did (see upper right corner of the picture).
This is not a cheap fan. It is expensive, waterproof, quiet, and durable. It can be disassembled and cleaned. Mounted in the galley as I had it, it can point forwards to the front seats, or backwards to the rear bench/bed. It has three speeds. You will sleep better with this fan blowing on you. You can open the screened sliding window behind the galley to draw in cool air at night. When I had a Vanagon, I used this for years and always had great airflow. It can also be used to clear cooking smells/smoke from the galley area. The Vanagon is gone now, but I have one in my Eurovan now (when I get bored with the Eurovan forum, I come here for fun).
kourt
Vanagon install:
Eurovan install:
clamay Samba Member
Red Ryder Samba Member
Joined: June 26, 2021 Posts: 1195 Location: PNW — Washington
Posted: Thu Jul 06, 2023 3:59 pm Post subject: Re: Bottom bunk - ventilation while sleeping? |
Yes. Many portable fan choices are available on Amazon with various options for mounting system, colors, power source, etc. This may be a case for trial and error to find the best solution for you. _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition (Tornado Red)
“Nigel” — 1999 Jaguar XK8 convertible (Alpine Green Metallic) |
cmayna Samba Member
Joined: August 18, 2014 Posts: 1173 Location: SF Bay area, CA
Posted: Thu Jul 06, 2023 5:16 pm Post subject: Re: Bottom bunk - ventilation while sleeping? |
Do you have a rear hatch screen? Do you have one of these?
https://gowesty.com/products/lock-extension-for-rear-hatch _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
bobbyblack  Samba Member
Joined: May 21, 2015 Posts: 4627 Location: United States, Iowa
Posted: Thu Jul 06, 2023 5:53 pm Post subject: Re: Bottom bunk - ventilation while sleeping? |
The '88 (+) model years' rear quarter windows have a flow through cabin air "box" that replaced the last 3 inches or so of the glass. On the inside, there are maybe a dozen oval slots along the rearward edge, and a sort of septum rubber flap that allows air to flow outward from the rear, and shuts against flowing inward. It is possible to modify that inside slotted area to mount some computer heat sink fans along that inside edge, they are small, and powered by USB, so they are low power consumers overall. I have a dozen that can be mounted on both sides of the bus's D pillar air box edges and tape off the rest of the oval slots. Mind you, you do need to actually HAVE either an '88 or newer, or GET some '88 or newer rear quarter glass with the vent boxes. I tape mine up on the inside in the winter, as there is too much air flow near my head and I get cold at around 28F and colder. They are not perfect, but I got mine for exactly the reason you are describing.
Otherwise, you should take a look at Jalousie windows. There is a great example here on TS where that same rear quarter window was recreated to use Jalousie windows, I believe from a '68-'79 Westfalia bus center side window (slider door and opposite)
When I get a sec, I'll edit this with some example pix, likely stolen from the posters I follow with enthusiasm.
before
after
My Jalousie on the driver side:
-bobby _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch
VeeDubn Samba Member
Joined: May 31, 2019 Posts: 162 Location: Olympia, Washington
Posted: Thu Jul 06, 2023 6:04 pm Post subject: Re: Bottom bunk - ventilation while sleeping? |
Timwhy wrote: |
Also a sliding door screen will keep the air moving. |
Do you have/would you post a picture of your rear sliding window with the fitted screen, please? Thank you! |
Timwhy Samba Member
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1735 Location: Budapest Hungary, Europe
Posted: Fri Jul 07, 2023 5:26 am Post subject: Re: Bottom bunk - ventilation while sleeping? |
Latch extension and a sliding window vent grill works for us.
You can buy them or DIY:
https://www.thesamba.com/vw/forum/viewtopic.php?t=388627&highlight=screen
You can buy an opening rear side window, and there are vents for that too
_________________ Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008 |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6344 Location: Portland OR
Posted: Fri Jul 07, 2023 12:30 pm Post subject: Re: Bottom bunk - ventilation while sleeping? |
If you use the rear hatch bug screen and then prop your rear hatch open, nothing falls out the back. _________________ 89 Westy 2.1 Auto |
wbailey2112 Samba Member
Joined: October 02, 2015 Posts: 556 Location: Grove City, OH
jimf909 Samba Member
Posted: Fri Jul 07, 2023 7:13 pm Post subject: Re: Bottom bunk - ventilation while sleeping? |
Suggestions:
1 - Hatch extender - it looks like you have this covered
2 - As mentioned, netting for the rear hatch, open the hatch, this is one of my favorites because it allows for a lot of air flow
3 - Hatch extender plus an exhaust fan in the roof - this is also very effective because the roof fan will pull air through the extended hatch. I have a Fantastic Fan but the MaxxAir fans are also well-kiled. This would require some modification to the pop-top which people have done.
I believe I recall IdahoDoug here experimenting with a D-pillar fan but can't find the thread. Mentioned here:
https://www.thesamba.com/vw/forum/viewtopic.php?p=8102809
p.s. Good work on sleeping on the bottom bunk the correct way. So many people get it wrong and have their heads towards the front of the van.  _________________ - Jim
Butcher wrote: |
This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
markswagen Samba Member
Joined: January 28, 2018 Posts: 1555 Location: san diego
Posted: Fri Jul 07, 2023 9:15 pm Post subject: Re: Bottom bunk - ventilation while sleeping? |
l have one of these to hold the tailgate open.
https://www.homedepot.com/p/Everbilt-3-8-in-x-10-1.../204273921
one of the rear sliders is on my wish list from van cafe _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
Posted: Fri Jul 07, 2023 11:29 pm Post subject: Re: Bottom bunk - ventilation while sleeping? |
Timwhy wrote: |
VeeDubn wrote: |
RMW sliding window w/ screen
[Pic]
Sliding door open w/ sliding window open.
[Pic]
With both windows opened, still able to get a breeze thru them |
Thank you! Very helpful  |
Timwhy Samba Member
Posted: Sat Jul 08, 2023 8:48 am Post subject: Re: Bottom bunk - ventilation while sleeping? |
Timwhy wrote: |
Forgot to post the screen. It slides into the window frame and is keep in place with pressure from closing the window.
[Pics] |
Extra helpful! Thank you so much!  |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 18848 Location: Retired South Florida
Posted: Sat Jul 08, 2023 9:35 am Post subject: Re: Bottom bunk - ventilation while sleeping? |
Quote: |
p.s. Good work on sleeping on the bottom bunk the correct way. So many people get it wrong and have their heads towards the front of the van. Laughing Laughing Laughing |
That would be us. Sheets stay tucked in, easier to take care of business in the middle of the night.
Have a cheap 12 volt truck fan on a tarp clamp. We clamp it anywhere we need it. On mild nights, it gets clamped to the roof cross bar. Warmer nights, on the front table leg. Really hot nights, we are in a state park with the AC cranking. It gets clamped to the spice rack when stove is being used.
Unfortunately, the fan died on our last trip. After 4 stops ended up with an even cheaper fan from O reilly. Watching for a replacement.
I looked at the fan posted above to Amazon. They are really proud of it$$$ Looks like I could adapt it to my tarp clamp. |
space Samba Member
Posted: Sat Jul 08, 2023 3:03 pm Post subject: Re: Bottom bunk - ventilation while sleeping? |
There would be a Mutiny if I didnt travel with this
I also carry a small generator in the event we dont have power _________________ 82 westy
w:
2.5 JDM Subie
Rear discs |
