iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9830 Location: Somewhere between Dubuque and Keokuk
Posted: Wed Aug 16, 2023 5:33 pm Post subject: Re: What did you do to your Beetle this week? |
67rustavenger wrote: |
The factory inspection code, should stay in place. If you just rinse the fender wells with water.
Use a solvent or soapy spray cleaner, and it will take off the hand written code. |
I am amazed that it is still there after 58 years and 135K miles. |
Rome Samba Member
Joined: June 02, 2004 Posts: 9657 Location: Pearl River, NY
Posted: Fri Aug 18, 2023 3:57 am Post subject: Re: What did you do to your Beetle this week? |
From May 2022:
iowegian wrote: |
I figured out a non-invasive way to mount these little European Tourist badges that I got from a gentleman in Budapest, Hungary. Mounted them to a cardboard visor sleeve.
Nice idea. Those are souvenir badges for your wooden walking cane or hiking stick. They are made of thin tin or aluminum/etc and bend easily to conform to the curvature of the cane. Attach to the cane with very small nails/brads. You can still find similar badges in local area souvenir stores nowadays.
25 yrs ago I bought a number of larger enameled tourist badges from cities or areas in Germany. They were from a small shop in the German town Garmisch-Partenkirchen. I mounted them to the exposed metal windshield header on the passenger side using double-stick tape. The Beetle I had at the time did not have a passenger sun visor so that the badges were in direct sight. My only tie to those badges was that I had been to those towns while working in Germany in the early 1980's. My Beetle was never there... |
Posted: Fri Aug 18, 2023 5:20 am Post subject: Re: What did you do to your Beetle this week? |
Thanks for explaining the intended use for these badges, Rome. The ones that I have are from Switzerland, Heidelberg, and Innsbruck. The car is Tourist Delivery that was owned by the wife of a U.S Army officer. I know that she crossed the Alps in the car and they were stationed in Heidelberg. I can't prove that she went to Innsbruck, but it is logical (and the badge is pretty). |
far rider Samba Member
Joined: August 30, 2005 Posts: 773 Location: Rutland, VT
Posted: Tue Aug 22, 2023 11:06 am Post subject: Re: What did you do to your Beetle this week? |
This has been on my mind since I started this project but finally got the HC in. Next place the body back on the pan and check for overall fit and alignment
_________________ 67 zenith blue sunroof
Contentment; when what you have is what you want. |
indianpeaksjoe Samba Member
Posted: Tue Sep 05, 2023 11:31 am Post subject: Re: What did you do to your Beetle this week? |
I added an sPod and USB charger/volt meter. It had just a piece of plastic over the radio hole in the dash before. I added a blank so I wouldn't chop up the dash any more. What can I say, I love the look of driving lights on a beetle, so I wanted a clean way to wire them. The sPod should be a neat way to do that. In theory.
And then I took it for a ride. Still need to hook up the front driving lights, but I need to paint the front bumper first.
And just a pic, cause I think it turned out cool.
-Joe |
Posted: Sat Sep 09, 2023 8:11 pm Post subject: Re: What did you do to your Beetle this week? |
My stock VDO gauge was leaking at the boot. This Wolfsburg West replacement seems really nice.
-Joe |
hobthebob Samba Member
Joined: December 08, 2021 Posts: 375 Location: Austin, TX
Posted: Wed Sep 13, 2023 10:11 am Post subject: Re: What did you do to your Beetle this week? |
I replaced the gas cap gasket after ordering one at 70mm for my 67 which turned out to be too large.
Turns out I have a bus gas cap that fits on my beetle, 60mm gasket! Fits perfectly! |
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2667 Location: Long Island, NY
Posted: Fri Sep 22, 2023 8:14 pm Post subject: Re: What did you do to your Beetle this week? |
In addition to the usual monthly battery charge and tire pressure adjustments, I did a clutch cable adjustment today. Not so mysteriously, the clutch chatter from a stop is gone. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch' |
Posted: Sun Sep 24, 2023 6:33 pm Post subject: Re: What did you do to your Beetle this week? |
Today I replaced both axle boots with new, German made boots. Less than two years ago I replaced one axle boot with a Chinese made boot, and then about a year later I replaced the other one with another Chinese made one. Both began cracking and leaking within a year and two years respectively
Hopefully the German made boots will last a bit longer! They fit better(the Chinese ones were slightly small around the transmission end of the boot), but are made of thinner rubber... the ad says they are crack resistant though, so who knows! |
mikelars Samba Member
Joined: February 27, 2019 Posts: 238 Location: North Carolina
shanered Samba Member
Posted: Tue Sep 26, 2023 11:06 am Post subject: Re: What did you do to your Beetle this week? |
moved it out of the garage and put up for sale
Posted: Tue Sep 26, 2023 11:08 am Post subject: Re: What did you do to your Beetle this week? |
indianpeaksjoe wrote: |
-Joe |
thats free buzz you coulda charged for rides |
OldSchoolVW's Samba Member
Posted: Tue Sep 26, 2023 2:09 pm Post subject: Re: What did you do to your Beetle this week? |
shanered wrote: |
So ... what are you hoping to get for the garage? _________________ Tom
"Following distance is proportional to IQ."
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
Posted: Sat Sep 30, 2023 2:23 pm Post subject: Re: What did you do to your Beetle this week? |
I had a noise in my steering wheel, took it off and found one of the three bolts holding the aftermarket wheel on had come loose.
And this, well this was just bugging me. Where the speaker was there was duct tape holding on foam from the PO. So I cut some plexi to cover it up instead.
And I took it for a cruise
Posted: Wed Oct 04, 2023 8:29 am Post subject: Re: What did you do to your Beetle this week? |
Finished my 2276 build Wednesday evening.
AA 82mm forged crank
JPM Ductile iron 94mm cylinders, stuffed with JE forged pistons
Scat 5.7 H beam rods
FK-10 camshaft with Engle lifters
Smith Brothers custom 3/8" chromo PR's
Scat 1.4 rockers
CB Wedgeport heads with 42cc combustion chambers
CB Bigbeef intake manifolds, topped with 48 IDA clones
CB magnaspark distributor
CSP 42mm EVO Comp SS exhaust, dual muffler
12.2:1 CR, race gas only for this build.
Rotating assembly, repaired and balanced @ DPR, Thanks Jose.
A rough estimate of the power on this build, 187HP, 167trq.
Hoping to get the engine installed tomorrow, 8/6/23. |
I like what you're doing here. |
Posted: Fri Oct 13, 2023 6:42 am Post subject: Re: What did you do to your Beetle this week? |
I installed some Hella ValueFit LEDs on a bar I had the local boat shop make. They are really bright, I have them on my Vanagon, but woah, for the price I like them.
Everything on the install went so well, during the test drive around the neighborhood the shifter broke. This is my fault, I kept fidgeting with the knob because it wasn't lining up right.Lesson learned. I had a spare, but now I kind of want a bug-tech one.
-Joe |
Posted: Sat Oct 14, 2023 4:17 pm Post subject: Re: What did you do to your Beetle this week? |
On a 250 mile cruise last weekend I got annoyed with a slight "twitch" of the steering when crossing bumps in the highway. I figured it was time to replace
the steering damper, so I did that today and it drives great. I was quite proud of myself for finding a "SACHS" damper on line, instead of the more common COFAP unit.
Upon receiving the part yesterday, I was quite excited, but then I saw it-----
on a label on the SACHS box were the words in little, tiny letters, "made in China". No such information on the part itself.
But it works just fine. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9788 Location: Oregon
Posted: Sat Oct 21, 2023 2:47 pm Post subject: Re: What did you do to your Beetle this week? |
New tires!
The JG 67 was needing new tires. The old ones were well over 20yo and hard as rocks.
I ordered a set of Michelin XZX 165 SP 15 from Jegs.
Had um mounted and balanced yesterday.
Of course, the tire shop over filled the tire pressure to 42psi
The car was squirrely driving home from the shop.
I lowered the tire pressures to 19 front and 26 rear. The car drove sooo much better after lowering the pressure.
Next up? An alternator change. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Sat Oct 21, 2023 2:58 pm Post subject: Re: What did you do to your Beetle this week? |
And while the JG was getting new shoes at the tire shop.
I finished the installation of the 2276 in the ZenithBlau 67.
After all the work, I climbed into the cabin and turned the key to build oil pressure.
And Nothing! The starter would not spin.
It's a new INI high torque starter and I may have not connected the starter trigger wire correctly. _________________ I have learned over the years.
Buy Once, Cry Once!
agramer1966 Samba Member
Joined: October 17, 2010 Posts: 152 Location: Northern Poland
Posted: Wed Oct 25, 2023 3:35 am Post subject: Re: What did you do to your Beetle this week? |
Finally gettin' ready to assemble my '66 engine for my' 66 bug.
_________________ 1966 VW1300
1973 VW1302
1974 VW Trike
1984 924
Bunch of old Jap motorbikes
Instagram & YT: #agrameroldoctane |
