indianpeaksjoe Samba Member
Posted: Fri Oct 27, 2023 5:52 pm Post subject: Re: What did you do to your Beetle this week? |
Fixed this broken spot weld with a rivet. And now I want a fancy air filter to replace it:) |
shanered Samba Member
Posted: Sun Oct 29, 2023 12:24 pm Post subject: Re: What did you do to your Beetle this week? |
indianpeaksjoe wrote: |
watch out valves here comes a rivet |
PWB Samba Member
Posted: Mon Oct 30, 2023 7:34 am Post subject: Re: What did you do to your Beetle this week? |
SLA 3D printed and painted a shift knob w/ cool shift pattern:
The small size of the original knobs always bothered me, and any alternatives always looked out of place. So I purposely printed this at 120% the original size, and am very pleased with the look and feel.
Came across the .stl file here if anyone else is curious:
https://www.thingiverse.com/thing:5189316 |
Posted: Tue Oct 31, 2023 6:52 pm Post subject: Re: What did you do to your Beetle this week? |
shanered wrote: |
Damnit, now I have to buy a new air filter
-Joe |
Posted: Tue Oct 31, 2023 6:55 pm Post subject: Re: What did you do to your Beetle this week? |
No work today, but a cruise to hole n the rock
Joe |
62RagTopBug Samba Member
Joined: April 10, 2022 Posts: 12 Location: MidMichigan
Posted: Thu Nov 02, 2023 6:04 am Post subject: Re: What did you do to your Beetle this week? |
The proper hood with the Wolfsburg crest is now on this 62. This is just one of many projects completed on this vintage beetle.
I’ve taken the “rolling work in progress” approach, we drive it and enjoy taking it to places all over Michigan in between various projects.
Posted: Thu Nov 02, 2023 9:07 pm Post subject: Re: What did you do to your Beetle this week? |
When I bought this, it had an 11” steering wheel. This mooneyes one called to me. 13.5” seems like a good size.
OldSchoolVW's Samba Member
Posted: Thu Nov 02, 2023 9:52 pm Post subject: Re: What did you do to your Beetle this week? |
62RagTopBug wrote: |
More photos please! _________________ Tom
"Following distance is proportional to IQ."
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9779 Location: Oregon
Posted: Tue Nov 14, 2023 2:11 pm Post subject: Re: What did you do to your Beetle this week? |
67rustavenger wrote: |
And while the JG was getting new shoes at the tire shop.
I finished the installation of the 2276 in the ZenithBlau 67.
After all the work, I climbed into the cabin and turned the key to build oil pressure.
And Nothing! The starter would not spin.
It's a new INI high torque starter and I may have not connected the starter trigger wire correctly. |
Turns out the INI starter was defective from the get go. I replaced it with the spare starter from my bench starting rig and the car turned over and fired right up.
Then while the engine was idling, I looked under the car. Oil was practically streaming out of the #3 exhaust pushrod tube seal.
I moved the car over to the winter storage location and locked the door. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Tue Nov 14, 2023 2:20 pm Post subject: Re: What did you do to your Beetle this week? |
Over the last week or so. I have replaced the alternator. What a PITA with the engine in the car. Got it completed the day before knee surgery.
Yesterday while out driving the JG 67. It refused to idle. I checked for vacuum leaks, none. Checked the carb float bowl was full of fuel after it died while idling for 3 seconds. The bowl was full.
This morning I searched ts for the symptom I was experiencing.
Pulled the idle (pilot) jet and cleaned it with brake cleaner and compressed air.
Reinstalled the jet and, what do ya know. The engine idled like it was new.
I also addressed a twisted seat belt that was annoying. Turns out the installer (Me) had put a twist in the lap portion of the belt. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Tue Nov 14, 2023 5:22 pm Post subject: Re: What did you do to your Beetle this week? |
A bunch of little things over the last few weeks.
I adjusted the choke, carb and advanced the timing 6*. That made it run even better.
Then little doodads I have been doing over the past month or so.
Vintage Air Cooled door handles and window cranks. The cranks are night and day better than the Empi ones that were on there. The parking brake cover is a bit messed up, but they are sending a new one.
Than a Moon Eyes wheel.
And a month or so ago I put on the Vintage Speed cup holder. Wow. This is great.
Lastly today I put on Bug Tech shift lever. This is amazing. The only other comparison is the $20 one from Jbugs. This blows it away. I need to figure out how to get the 8 lined up and down on my 8 ball shifter, but otherwise amazing.
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Wed Dec 13, 2023 10:54 pm Post subject: Re: What did you do to your Beetle this week? |
mikelars wrote: |
I am supercharging my beetle
I really like that build sticker on the fan shroud. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Thelovelylimey Samba Member
Posted: Fri Dec 15, 2023 4:17 pm Post subject: Re: What did you do to your Beetle this week? |
Ive had the veedub bug for many years, but I've only recently wandered into air cooled territory. I got a vanagon westy last year and have really enjoyed tinkering with the systems. I've always liked beetles, so I recently also contracted the bug bug. Long story longer, I was checking it over and removed the fuel tank to get at the master cylinder and steering components. This is the work of art I found. I have never seen better. Anyone else? |
Posted: Sun Dec 17, 2023 6:37 am Post subject: Re: What did you do to your Beetle this week? |
Installed new fuel lines and a new fire extinguisher mount. Then a cruise.
-Joe _________________ Adventures in owning a 66 beetle |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9830 Location: Somewhere between Dubuque and Keokuk
Posted: Sat Dec 30, 2023 7:50 pm Post subject: Re: What did you do to your Beetle this week? |
Put some Christmas decorations on the roof rack and then drove around town looking at all of the pretty lights.
Posted: Sun Jan 21, 2024 5:01 pm Post subject: Re: What did you do to your Beetle this week? |
After the last weeks snow storm followed by an ice storm. I needed to move the ZenithBlau 67 away from the neighbors fence that was threatening to fall onto my car.
I poured a half a gallon of race fuel in the tank and fired it off. Surprisingly, it started with little drama.
I really like the smell of burnt race fuel in the air!
Buy Once, Cry Once!
alex857 Samba Member
Joined: December 26, 2010 Posts: 714 Location: Stuttgart/Germany
Posted: Sun Feb 04, 2024 2:14 pm Post subject: Re: What did you do to your Beetle this week? |
I made the first short tour today with my 1961 Pearl White Rag Top:
Rome Samba Member
Joined: June 02, 2004 Posts: 9657 Location: Pearl River, NY
Posted: Sun Feb 04, 2024 3:49 pm Post subject: Re: What did you do to your Beetle this week? |
I haven't looked into this thread for a few months... Excellent photo!
-Joe |
