water leak? in 86 near catalytic converter
jerryil
jerryil is offline
PostPosted: Mon May 12, 2008 10:01 am    Post subject: water leak? in 86 near catalytic converter Reply with quote
So after sitting in the driveway overnight, I noticed a small patch of water on the ground this morning. There is water slowly dripping out of one of the (bolts?) right beside the catalytic converter. Anybody have an idea where I should start? Thank you!!!!!!
sagebus
sagebus is offline
PostPosted: Tue May 13, 2008 6:01 am    Post subject: Reply with quote
Water pump
1984 Vanagon GL, Wolfsburg Westy 1.9 ltr
Terry Kay
Banned
Terry Kay is offline
PostPosted: Tue May 13, 2008 6:41 am    Post subject: Reply with quote
Right beside, or right above it?
Take a real close look at the engine oil cooler.
Pretty common area for the seal above the cooler to be leaking.
Get a coolant pressure tester on the expansion tank---you'll know exactly where it's coming from right now.
T.K.
