Dubbin68 Samba Member
Joined: June 27, 2006 Posts: 253 Location: Duluth, MN
Posted: Thu May 22, 2008 5:48 pm Post subject: Steering box |
So i replaced my old steering box with a new one because i ran out of adjustment on it and my wheel was loose. Well i got thenew steering box on but now the steering it too tight and the adjuster is loosened all the way out., there is also little bit ofplay in the wheel, like ten degrees. Another thing noticed is when i turn the wheel i hear a creaking sound, but can't seem to track it down.
any help would be greatly appreciated _________________ 68' Westy Weekender
73' Squareback
69’ Beetle |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34023 Location: Conejo Valley, CA
Posted: Thu May 22, 2008 7:50 pm Post subject: |
Where did you get it? What brand?
Mine was a little tight, and it worked loose over time, and I had to adjust it tighter after about 1000 miles. Make sure it is lubed properly, and give it a chance to loosen up. |
Woreign Samba Member
Joined: June 04, 2006 Posts: 2841 Location: Crestview FL
Posted: Thu May 22, 2008 8:16 pm Post subject: |
Hopefully you didn't buy it from CIP1... They sell bad steering boxes! |
Posted: Thu May 22, 2008 8:34 pm Post subject: |
it's a brand new TRW. Wheel turns and everything, just doesn't return back after turning, just stays in position. Also the creaking sound sounds like it's coming from the ball joints? _________________ 68' Westy Weekender
73' Squareback
69’ Beetle |
Keith Samba Member
Joined: August 15, 2005 Posts: 3634 Location: Brodheadsville, PA
Posted: Thu May 22, 2008 9:27 pm Post subject: |
Kyler wrote: |
it's a brand new TRW. Wheel turns and everything, just doesn't return back after turning, just stays in position. Also the creaking sound sounds like it's coming from the ball joints? |
Had the same problem with my TRW box.It was too tight and didn't return to center. For my adjustment, I backed the top adjustment off 1/8 of a turn from where it was and then I adjusted the bottom adjustment ..... the HUGE hex nut and inverted star adjuster. You get to it from the bottom of the car. I used a fan clutch wrench for Mopar fan clutches....fits the nut perfect and a big nut that fit into the adjuster to turn it and adjust it. Just backed it off slightly. It loosened it and now it finally returns to center. _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
Posted: Sat May 24, 2008 1:17 pm Post subject: |
ovalteen wrote: |
Kyler wrote: |
Had the same problem with my TRW box.It was too tight and didn't return to center. For my adjustment, I backed the top adjustment off 1/8 of a turn from where it was and then I adjusted the bottom adjustment ..... the HUGE hex nut and inverted star adjuster. You get to it from the bottom of the car. I used a fan clutch wrench for Mopar fan clutches....fits the nut perfect and a big nut that fit into the adjuster to turn it and adjust it. Just backed it off slightly. It loosened it and now it finally returns to center. |
thanks i'll try it out, just have to track down a huge hex wrench _________________ 68' Westy Weekender
73' Squareback
69’ Beetle |
El Cookie Monster Samba Member
Joined: January 21, 2008 Posts: 262 Location: Santa Ana
Posted: Wed Jun 04, 2008 11:37 am Post subject: |
i'm having the same issue. I just get play on one side but all of this just happend when i installed a narrowed 6" beam. i took it to a mechanic to see if he can fix it but all he said that my box was no good, but it was working fine with the stock beam. please help!!! |
KTPhil Samba Member
Posted: Wed Jun 04, 2008 12:36 pm Post subject: |
Channel-locks may work to loosen the nut. Then use a large bolt head that fits the adjuster, and grab the threads with vice grips (or file two flats and use a wrench).
nucks Samba Member
Joined: January 12, 2008 Posts: 34 Location: Virginia
Posted: Wed Jun 04, 2008 6:07 pm Post subject: |
are there any pic. of how to tighten the sterring box. my stering is very lose and I dont know how to tighten it. |
Keith Samba Member
Posted: Wed Jun 04, 2008 9:51 pm Post subject: |
5spoke66 wrote: |
What kind of play? If your box was fine on your old beam it should be fine on your narrowed beam. The beams have nothing to do with it. Make sure your box is lined up straight with the steering shaft and not at a slight angle up or down or too far left or right. That can cause the steering to bind as it tries to turn since its not turning in a perfect circle. _________________ Formerly known in the forums as "OVALTEEN"
2067Bug Samba Member
Posted: Mon Jun 09, 2008 6:05 pm Post subject: |
Ovalteen:
Do you happen to know the size of the Mopar wrench you used, and big nut that fits into the adjuster? I have been trying to figure out what tool to use to adjust the big HEX nut. I have the same problem with the wheel not returning to center and tried everything over the past year. Thanks |
figitt Samba Member
Posted: Mon Jun 16, 2008 6:55 am Post subject: |
To put my 2 cents in here... I also replaced my box cause my old one was just not adjusting and very worn. Play in the wheel is the main reason. The new box from JBUGS was worse than the one i had... with almost 2 inches of play in the wheel when centered. I was able to adjust some of that out, but its still in the 1 inch range at center.
Is it normal for this car to have a certain amount of play in the wheel..?
Ive replaced every single item in the suspension on this car, and im at my wits end... this play is driving me nuts. |
