70 washer bottle mounting
bartman
bartman is offline
PostPosted: Mon May 26, 2008 6:22 pm    Post subject: 70 washer bottle mounting Reply with quote
i'm trying to get the washer setup going in my 70 baja. i have everything i need except the correct bottle.
i have a bottle out of a 72 super but with the front end cut there really isn't any good place to mount it.
so, i'm going to get hold of the correct bottle but i can't see how to mount it in it's recess. is there a bracket or something i don't have?
blarneyman
blarneyman is offline
PostPosted: Mon May 26, 2008 6:28 pm    Post subject: Reply with quote
The filler neck goes through the center hole of the tire and the 2 teats go through two of the lug holes in the tire. A couple cotter pins will hold it in place.
69 Beetle
70 Ghia(resto)
Shaka
Shaka is offline
PostPosted: Mon May 26, 2008 6:32 pm    Post subject: Reply with quote
Are you looking for something like this?
http://www.thesamba.com/vw/classifieds/detail.php?id=610394
I took that out of my 1970 standard and upgraded to a 12v system. If you want it (the orig one) let me know!
Here is how the orig one looks installed:
(although the hose wasn't attached to the valve stem as it should be)
Here is what I have installed now:
~ Shaka! ~ FB! ~ (1971 VW Squareback) ~
realbugfanatic
realbugfanatic is offline
PostPosted: Mon May 26, 2008 6:37 pm    Post subject: Reply with quote
Shaka - more info please. I like the looks of your setup.
bartman
bartman is offline
PostPosted: Mon May 26, 2008 6:38 pm    Post subject: Reply with quote
thanks, guys.
can ya believe it? i searched the galleries for a picture of the setup, found nothing, posted, then searched the forum and found a beautiful shot of the mounting setup.
i guess i'm sol without a spare tire. i'll just try to make the super bottle work if i have to fab up a mount anyway.
thanks anyway shaka
Shaka
Shaka is offline
PostPosted: Mon May 26, 2008 7:18 pm    Post subject: Reply with quote
I got my setup from CB performance:
http://www.cbperformance.com/catalog.asp?ProductID=1280
But that required that I had to install a button/switch which I just did under the dash. So nobody would really know where it is unless I explained it to them.
Here is a kit I found after the fact, same hardware but it appears it may come with a new wiper switch too that could activate the 12v system perhaps?!...
http://www.mamotorworks.com/acvw?frame=1.8052
Hope this helps.
realbugfanatic
PostPosted: Tue May 27, 2008 3:09 am    Post subject: Reply with quote
Cool, thanks. My stock version works just fine, but then I saw your setup & suddenly thought about changing it.
