busboyjake Samba Member
Joined: September 22, 2002 Posts: 400 Location: Colorado
Posted: Mon Feb 24, 2003 3:47 pm Post subject: GEX engine ? |
hello, i've had three GEX engines go bad within days or months because of internal problems, i now am asking for a refund, but i seem to be getting nowhere, will i ever see my money again? have any of you ever had this experience, or know anyone there that i can deal with? Help!!!!
thanks
Moderator note:
This thread has been locked in favor of this longer GEX thread:
http://www.thesamba.com/vw/forum/viewtopic.php?t=92079 |
toddgsanford Samba Member
Posted: Mon Feb 24, 2003 4:03 pm Post subject: GEX engine ? |
| check archives on gex motors I lucked into one in a parts car that had 500 miles on it I have only logged about that on it and although it leaks non stop from somewhere I have replaced push rod tubes all rear main oil cooler seals 3 different drain plates and we will see what happens I would not invest much in the quality of there product nor would I pay real money by the way I paid 50 bucks for the parts car and sold at least 300.00 worth of other stuff of it so it was beyond free out of pocket as for time invested I am at a deficit as far as for your refund there will likely be some slippery language in there warranty that will place you at fault I however have had no experience with them they have since at least 95 been known as a so so low quality builder personally I have relative success with mine I only use it as a spare motor to jockey cars around while under construction wouldnt put it to the road trip test just yet if you paid with a credit card there is the option to dispute the charge or amex has buyer protection it might be worth it if this is how you paid got back at rocky mountain motorworks for not warrantying shitty rubber this way had no luck dealing with them for the record hope that helps definitly check archives |
ronnie Samba Member
Joined: May 01, 2002 Posts: 1053 Location: lost somewhere between the earth and my home.
Posted: Mon Feb 24, 2003 7:44 pm Post subject: GEX engine ? |
| I've heard of one person beating them and getting their $ back, a mechanic tore the engine down and put it down on paper all that was wrong with it, and he was kind enough to call himself when the folks on the phone got to technical to try and bs the owner. seems like he said the case halves didn't even match. |
Bingo Samba Member
Posted: Mon Feb 24, 2003 7:48 pm Post subject: GEX engine ? |
I've not heard very good reports about them in UK....
Bingo. |
Posted: Tue Feb 25, 2003 7:21 am Post subject: GEX engine ? |
What size engine did you buy? How long ago?
Was it a new or use case? I recently purchased a 1776 and would like to know if I am in for the same problems |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9831 Location: Exit 7, New Jersey
Posted: Tue Feb 25, 2003 3:00 pm Post subject: GEX engine ? |
If GEX knows what's good for them, they'll refund your money muy pronto, and come on this site and explain what they are doing to improve quality control. Otherwise, TheSambaddicts will spread the word!
Come on GEX, step up! |
joey-bugnaked.com Samba Member
Joined: January 04, 2003 Posts: 258 Location: the bugnaked mansion
Posted: Tue Feb 25, 2003 3:08 pm Post subject: GEX engine ? |
| My buddy got a GEX engine about 6 years ago, the case was linebored 80 over and the bearings were too small. The crank was just flopping around, it lasted about 500 miles. He fought with them for about 2 years then gave up. Hasent seen a penny. |
SHTUBBY Samba Member
Joined: February 20, 2003 Posts: 294 Location: PHOENIX, AZ
Posted: Tue Feb 25, 2003 4:17 pm Post subject: GEX engine ? |
| gtrieb, either you or your mechanic should tear-down the engine, and find the problem. make sure you document everything you find wrong inside. take pictures!!!!! GEX has moved to Arkansas, and set up a new shop there. if you have enough documentation, you might beat them. LOL Steve |
Posted: Tue Feb 25, 2003 11:10 pm Post subject: GEX engine ? |
A fellow LiMBO (Late Model Bus Org.) member bought a GEX engine a few years back for his air-cooled Vanagon. It croaked very shortly after installation. He did get them to send a replacement motor but still had to eat some shipping and installation costs. I've never heard anything good about their engines.
-Stan |
ice baller Samba Member
Joined: July 13, 2002 Posts: 444 Location: 626 El Monte CA
Posted: Wed Feb 26, 2003 12:42 am Post subject: GEX engine ? |
| There is a GEX store here where I live, Its in Baldwinpark, I went to the store and it apears nothing but imagrents work there(no offense to any 1) They are just trained monkeys, they just put the engines toghter with out measureing for out of round, Luckly I decided not to buy an engine form them, but the bug I bought had a GEX engine and hasnt broken down yet(knoking on wood)I guess its 1 of those "lucky engines" |
nik Samba Member
Joined: February 13, 2003 Posts: 849 Location: 1 block away
Posted: Wed Feb 26, 2003 12:48 am Post subject: GEX engine ? |
Where is a good place to get an engine from? Anyone have any good experiences with anywhere? Just curious.
nik |
glandnut 40 horses of Fury
Joined: February 26, 2003 Posts: 1432 Location: J-ville, FL
Posted: Wed Feb 26, 2003 6:50 am Post subject: GEX engine ? |
| Build it yourself, no one will do it better. |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10804 Location: the past
Posted: Wed Feb 26, 2003 8:54 am Post subject: GEX engine ? |
i just tore apart a very big-buck gex engine for a friend. 92mm p/c, solid rocker shafts, hydraulic cam and lifters, huge oil pump & oil pressure booster kit, big dellorto carb, gex "041" heads. look up the prices for all this stuff on their site.
anyway, they had to machine the case for the lifters. they used chevy hydraulic lifters which are bigger than the original vw lifters, essentially ruining the case for any future build up using anything other than chevy lifters. too bad, it is a case that is at standard bore.
the engine wouldn't run right, poor idle, low power, blew oil, etc. tore it apart and here's what i found (and remember this engine had less than 4K on it): cylinders severely scored, piston rings frozen in their grooves, pistons severely scored, cam severely damaged on the front 2 lobes because the LIFTERS WENT FLAT and lost all hydraulic pressure. i tried all the ways i know to try to get them to pump up (out of the case) and they are junk. so i think that was a poor engine.
i have had a gex engine in the past and i did drive it all over the place and put many many miles on it. a few years after i got it, my friend bought the bus it was in from me, and he only got a few thousand on it. upon tearing it down, the case was cracked where the #2 main bearing seats on the case, causing a loss of oil pressure and eventual failure.
i have used GEX in the past with very mixed results. i personally would NOT recommend them again. if i were you, [email protected], i would find a reputable shop who hand builds them, or i would build my own. |
Posted: Wed Feb 26, 2003 10:31 am Post subject: GEX engine ? |
| Gene Berg makes a pretty strong engine, but I agree that the homebuilt engines are the best, If you are doing a rebuild, I'd start from scratch and buy a new case, unline bored and get brand new main bearings! I've had good results. |
Posted: Wed Feb 26, 2003 4:53 pm Post subject: GEX engine ? |
| Don't go for the cheapest. You'll pay in the long run. |
crukab Samba Chef
Joined: December 13, 2002 Posts: 6132 Location: Vermont
Posted: Wed Feb 26, 2003 6:09 pm Post subject: GEX engine ? |
Check out Bob Donalds, Boston Engine
508-653-7229 www.bostonengine.com
he is really good, I've known Bob 10+ years, he is really into the vw engine scene,and as far as I know he has a good rep.
Tom in Vt. |
NorCalNick Ain't yo baby daddy
Joined: December 07, 2002 Posts: 1583 Location: San Jose, Ca.
Posted: Wed Feb 26, 2003 8:30 pm Post subject: GEX engine ? |
if da foolz dont wanna refund my money if i waz stooopid enough to get one from them , id have to git my 9 milly and show them wut da dilly!!!!
ha ha ha ha ha ha!!!1
you git wut yooz pay foe!! |
Posted: Wed Feb 26, 2003 9:11 pm Post subject: GEX engine ? |
Geez, guys - thanks for all the replies - i thought i was all alone - ok, heres the complete story:
for my 71 bus i bought a 1776 performance longblock, added a new head option, i bought a vanagon 2.0 from them for a 79 bus i had before and it ran fine so i said what the hey, right, anyway the first one got about a mile down the road and suddenly exploded, oil spewing out everywhere, etc. i immediately thought what did i do wrong?!!! - sent it to a local vw mechanic who told me obviously, its locked up and full of metal debris - sent it back to gex, they said there was some debris left in the case after build, so warranty sent me a new one, installed it myself again got about 300 miles for first checkup - oil was full of small metal fragments (besides the fact that it ran like absolute crap, wouldn't idle, irratic vacuum pressure, etc. from day one) - sent this one back, same thing internal problems, the sent me another, had this one installed by earlier vw mechanic because they (GEX) said that they would pick up the labor - same problems running as before, but this one lasted longer, about 2000 miles and several lobes on the cam went flat, so i sent it back and said, forget it i want my money back, so about nine months from my initial day of purchase, here i am, out the money, and my mechanic still has not been paid, where do i go from here? |
Posted: Wed Feb 26, 2003 9:19 pm Post subject: GEX engine ? |
oh, also i took the engine that came out of the old bus i had - thought it was bad - bought it that way - tore it apart and it looks great except for #1, replaced #1 cyl, piston and head, runs very nice and smooth, for around $300.
i thought gene berg didn't make bus motors,
& in the future i will always spend the extra money, find a reputable local mechanic w/ experience and have one built locally with a new case, counterbalance, the works - do it right the first time! |
Posted: Wed Feb 26, 2003 9:23 pm Post subject: GEX engine ? |
| i sure hope they hear you j.pickens! they sure lost my business and stand to lose a whole lot more! |
