Tach wont go over 1000 rpms
a_and_b1228
a_and_b1228 is offline
PostPosted: Sat Jan 12, 2008 12:01 pm    Post subject: Tach wont go over 1000 rpms Reply with quote
I have just gotten done installing my VDO tach in my 79 california bus. I have working lights and the guage will not go over 1000 rpms. I also have some wiring questions, where in the fuse panel do I run the wire from my tach. Also does the different type of ignition coil needed for the california EFI make a difference.
View user's profile Send private message Send e-mail Yahoo Messenger Classifieds Feedback
Randy in Maine
Randy in Maine is offline
PostPosted: Sat Jan 12, 2008 2:25 pm    Post subject: Reply with quote
The 79CA coil is no problem.
Make sure your tach wire is hooked up to the "-" or "1" side of the coil, that the little dip switches are set correctly for both electonic ignition and 4 cylinders, and that you have the Radio Shack diode #1N4005 attached to the wire going from the coil.
Been here? http://egauges.com/pdf/vdo/0-515-012-020.pdf
Dead 1
Dead 1 is offline
PostPosted: Mon Jun 23, 2008 2:40 pm    Post subject: Reply with quote
My tach is doing the same thing. Checked the dip switchs, have a diode in place but tach is way way off. Any helpful ideas?
"I reject your reality and replace it with my own"
"The American Dream - true enough because you gotta be asleep to believe it"
71, 1776 cc.
Randy in Maine
PostPosted: Mon Jun 23, 2008 2:50 pm    Post subject: Reply with quote
What happens if you remove the diode (thinking that it might be on backwards)?
It should work even though it might dance around a bit.
TRN9
TRN9 is offline
PostPosted: Mon Jun 23, 2008 3:53 pm    Post subject: Reply with quote
On my VDO tach the dip switches were installed upside down, I had to rotate the tach 180 to set the dip switches properly. Might double check the dip switches.
