acetate909 Samba Member
Posted: Thu Jun 26, 2008 11:09 am Post subject: Difference in axle length (64 - 67) Square |
I'm now hearing conflicting information concerning the length of my axles on my 67 Square, I'm in the process of swapping in a short axle setup so as to run wide 5 - 17x7's (et42), but I've now heard a couple people tell me I dont need to swap out the axles to allow for the wider tires/wheels.
The '64 from what I've heard has the shorter axle, so by modeling my setup off this platform I would be...how do you say....misinformed
From what I can tell Im doing what I need to do, to be able to run these particular wheels...however I would prefer to have a couple more opinions, soooo...
Any insight/clarification would be most appreciated.
Thanks
Casey _________________ '67 Type 3 Variant
337 |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25186 Location: Central Iowa
Posted: Thu Jun 26, 2008 11:15 am Post subject: |
T-3's had the long axle from the start. The people you are talking to are T-1 people. Their 64's had the short axle.
Here is a 63 T-3 transaxle. Note the distance between the spring plate and the backing plate.
_________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Thu Jun 26, 2008 12:32 pm Post subject: |
| Russ Wolfe wrote: |
hmmm...
the '64 I was referring to was a Square in fact (Rasmussen's (sic?) in Denmark) so now Im just plain confused, especially considering its from you Russ
337 |
Notcho Samba Member
Joined: August 26, 2005 Posts: 105 Location: San Antonio
Posted: Thu Jun 26, 2008 12:52 pm Post subject: |
Not much to be confused about, type 3 axle lengths should all be the same.....You need early type 1 axles to do what your talking about.
I have type 1 "short" axles on my '64 Notchback.
Listen to the type 3 fellas... _________________ '64 Notchback 'S' Sunroof
San Antonio Air Coolers |
Notched Samba Member
Joined: January 19, 2003 Posts: 2365 Location: Pacific Northwest
Posted: Thu Jun 26, 2008 1:05 pm Post subject: |
I'm in the process of switching my Notch to bug "short" axles as well.
What you want is both "short" axles from an early bug and both axle tubes with the short end castings.
To get a wider tire/wheel combo in the back you can also use bug backing plates and drums — and of course all the brake shoes et al. _________________ Phillip Bradfield
Current stock: '57 Panel Bus, '63 Rat Notch, '64 Baja, '66 Variant, '67 Convertible Ghia, '68 Squareback, '69 Squareback, '69 Fastback
Southern Oregon VW Club -- http://www.sovw.org
Oregon VW Forum -- http://www.oregonvw.org |
Posted: Thu Jun 26, 2008 2:07 pm Post subject: |
awesome thanks guys
the 64 I've been referring to is in fact a Square, but the guys are in Denmark that I've been talking to, so maybe there are some things lost in translation :confused:
again thanks for your input everyone _________________ '67 Type 3 Variant
337 |
DucMike Samba Member
Joined: November 27, 2006 Posts: 156 Location: Outskirts of Sacramento, CA
Posted: Thu Jun 26, 2008 5:01 pm Post subject: |
So, what about the feasability of running the '66 (IIRC) T1 'mid-length' axles on my Typ3? Depending on the offset on the repop Gasburners I'm planning on running, I might need to move things in a bit.
Side note; looks like I've got acetate909 bracketed with two of my herd ('66 on the 'back & '03 on my 20th). Looks like we have the same taste in rides. _________________ Mike S.
'66 Variant Sunroof TIII4ME
'76 Rabbit
'91 Passat Variant (Big 'back)
'96 GTI VR6
'03 20th AE GTI OEM+ 20th
Niello Ranch Run |
thejoe138 Samba Member
Posted: Thu Jun 26, 2008 5:29 pm Post subject: |
42ET with the short axles might be too much on a T3 and run into clearance issues on the inside
Rasmussen was running the 17in raders last i saw. and i have been told by a few people that they will not fit on a T3 with the short axles.
if you have your wheels already i would test fit them with you stock axles and see what your working with.
i also have a set of those wheels that i planned to put on my 63 notch with short axles... i am just a few small pieces away from finding out the they dont fit the hard way.
not sure if i will ditch the wheels for something else, or just stash them for another project some time... |
Posted: Thu Jun 26, 2008 5:51 pm Post subject: |
Santa Maria!!!
I wish I could figure out what to do here... (before having the wheels in my hand-which I should have, I know, but times are tough at the moment)
anyone else? it seems as though the appropriate thing to do, is keep asking for people's experience with a similar setup  _________________ '67 Type 3 Variant
337 |
wolfman's brother Samba Member
Posted: Thu Jun 26, 2008 6:09 pm Post subject: |
| acetate909 wrote: |
Santa Maria!!!
anyone else? it seems as though the appropriate thing to do, is keep asking for people's experience with a similar setup  |
get solid confirmation from someone with the exact setup that did the work THEMSELVES.
I wanted to run rader's on my '64 and was told stock setup no problem by LOTS of people and guess what...WRONG!then I got conflicting stories from people who had those wheels and what was done to achieve it and turns out half of them bought the car that way and had no idea what they were talking about so now I know I need to convert axles if I want to look cool but I'm still sitting on the fence and the danged fence barbs are really hurting my keister  _________________ insanity takes it's toll,please have exact change ready.
my imaginary friends keep telling me I have a mental problem. |
Posted: Thu Jun 26, 2008 6:11 pm Post subject: |
| DucMike wrote: |
Side note; looks like I've got acetate909 bracketed with two of my herd ('66 on the 'back & '03 on my 20th). Looks like we have the same taste in rides. |
thats awesome!! I'm actually going to get her (the 337) this weekend from AZ where's she been parked for approx. 9 months in my parents garage. I cant wait!! What color is your 20ae? _________________ '67 Type 3 Variant
337 |
Posted: Thu Jun 26, 2008 6:13 pm Post subject: |
| wolfman's brother wrote: |
| acetate909 wrote: |
Santa Maria!!!
I wanted to run rader's on my '64 and was told stock setup no problem by LOTS of people and guess what...WRONG!then I got conflicting stories from people who had those wheels and what was done to achieve it and turns out half of them bought the car that way and had no idea what they were talking about so now I know I need to convert axles if I want to look cool but I'm still sitting on the fence and the danged fence barbs are really hurting my keister  |
Yeah thats exactly what I've been telling myself, I need someone that's running the same exact setup, but lo and behold I haven't run into anything yet....I think I'm just going to bite the bullet and figure out how to swing the wheels so I can do some test fitting.
thanks for your help wolfman, much appreciated
337 |
Posted: Thu Jun 26, 2008 6:18 pm Post subject: |
no problem.I got kind of lucky in my situation. david just over an hour away from me had 2 extras mounted on 195's he let me come pick up to test on the back of my '63(as the 1500club gasps)and as soon as I let the jack down it told the story so I sent them back to him via a friend at a car show the next weekend,no major investment down the drain.
I have axles and tubes already but I'm about to dump a fist of cash at the bodyshop and don't have it for powdercoating,isp bearing caps or to get my drum snouts machined.
the only thing I'm unclear about is the 1" spacer you need to hook your hand brake up to have it function properly. _________________ insanity takes it's toll,please have exact change ready.
Last edited by wolfman's brother on Thu Jun 26, 2008 6:27 pm; edited 1 time in total |
77ducci Samba Beer Head
Joined: March 07, 2002 Posts: 408 Location: Gathering the Missing Parts
Posted: Thu Jun 26, 2008 6:21 pm Post subject: |
| Dose any body have the measurement of the axels needed. I have a spare set laying around and was wondering if they would work? |
Posted: Thu Jun 26, 2008 6:26 pm Post subject: |
I have axles and tubes already but I'm about to dump a fist of cash at the bodyshop and don't have it for powdercoating,isp bearing caps or to get my drum snouts machined. |
I've realized...I need more friends
thanks for reminding me of the whole TIRE situation I was just kind of treating them like the bills, if I ignore the problem long enough it will take care of itself  _________________ '67 Type 3 Variant
337 |
