Mounting a late front sway bar on an early beam
Page: 1, 2, 3  Next
Stocknazi
Stocknazi is offline
PostPosted: Fri Jun 20, 2008 7:05 am    Post subject: Mounting a late front sway bar on an early beam Reply with quote
is it possible to use a front sway bar from a 64-67 beam on an 55-63 beam?
WANTED:
Thomas Jefferson
pyrOman
Fire Master
pyrOman is offline
PostPosted: Fri Jun 20, 2008 7:16 am    Post subject: Reply with quote
I don't know but can tell you it will be well worth the effort! Cool
The Dormy's disc brake fatchick beam has that weak half inch bar on it. It broke on me once and after getting all squarely in an on-ramp, I went straight to the wrecking yard to get a replacement! Shocked
I wish I could get a thicker heavy duty one as it will make it more stable even! Razz
bill may
bill may is offline
PostPosted: Fri Jun 20, 2008 8:35 am    Post subject: Re: front sway bar on early beam Reply with quote
1966 and 1967 stock nazi. Very Happy EMPI makes aftermarket ones. it cost me $29 for clamps from wolfsburg west (211 498 101 part number) i am going to mount it on my 1965 panel/camper. not sure about earlier beams tho'.. check EMPI catalog.
Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617
Stocknazi
PostPosted: Fri Jun 20, 2008 4:14 pm    Post subject: Reply with quote
i was hoping this would be a bolt-on thing that i could use all the hardware from a spare stock swaybar i have. i'm suprised i have not seen the idea mentioned before, unless the beam mounting area on the beams is slightly different. i haven't really noticed a difference, but it's certiently possible.
WANTED:
Thomas Jefferson
bill may
bill may is offline
PostPosted: Fri Jun 20, 2008 6:21 pm    Post subject: Reply with quote
my sway bar is a stock 66/67 one. i did not have the mounting clamps or anything. just the sway bar. now i have new clamps and can mount it on my 65. you may have to hold it up to 63 and older to see if trailing arms are same distance apart and same diameter.
www.sv2s.com
SBS #100
PostPosted: Fri Jun 20, 2008 7:09 pm    Post subject: Reply with quote
As far as I know it mounts up with no problems.
Line it up and try.
quartermilecamel
quartermilecamel is offline
PostPosted: Sat Jun 21, 2008 1:15 am    Post subject: Reply with quote
I would so love to have a stiffer front sway bar for my 69 front end. Hell I would love to have a rear sway.
Lind
Lind is offline
PostPosted: Sat Jun 21, 2008 11:24 am    Post subject: Reply with quote
I bolted a '67 sway bar onto my '61 front end. it bolts up fine.
the bar only touches the trailing arms, not the main part of the beam.
I actually pulled the sway bar off of a junk front end because someone had a wanted ad up for one. they never responded to my $75 price so I just installed it onto my bus. I am glad now that they didn't get back to me, because the sway bar really makes a noticeable difference in the handling of the bus around corners. I am planning on putting sway bars onto most of my buses now.
Wanted:
Stocknazi
PostPosted: Sat Jun 21, 2008 5:18 pm    Post subject: Reply with quote
that's awesome, thanks lind. i can tell a difference in my 66 with bar and my 61 w/o around the corners.
WANTED:
Thomas Jefferson
Stocknazi
PostPosted: Sat Jun 28, 2008 12:50 pm    Post subject: Reply with quote
got the sway bar on my 61; there is a noticible improvement around the corners. kinda a bitch to get on and off, that's for sure.
WANTED:
Thomas Jefferson
kingodirtp3
kingodirtp3 is offline
PostPosted: Tue Nov 18, 2008 2:20 pm    Post subject: Reply with quote
has anyone seen 4" narrowed sway bars? do i even need one since its narrowed 4 inches?
RobzKombi
RobzKombi is offline
PostPosted: Tue Nov 18, 2008 3:07 pm    Post subject: Reply with quote
I don't think they make a sway bar for any narrowed beams, my beam is narrowed 4" and I still have noticeable body roll going around corners. I'm now getting a new beam (non narrowed) and hopefully a swaybar aswell.
Riff Raff
Shivering Sambian
Riff Raff is offline
PostPosted: Tue Nov 18, 2008 3:21 pm    Post subject: Reply with quote
This has been discussed before if you want to do a search on the subject.
AFAIK, there are no narrowed sway bars.
It would not be a big deal to cut 4 " out of a sway bar and weld it back together. One would want to do a superior welding job on it though I think (root, fill, cap).
Although it is spring steel, the attributes of the spring steel would only be compromised in the heat affected region, so it should still work pretty well I would think.
There is also the feature of narrower bar so stiffer response, same effect as narrowing torsion leaves, but it should still work fine.
Someone needs to try this out and report back.
The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin
bigmau
bigmau is offline
PostPosted: Fri Nov 21, 2008 1:42 pm    Post subject: Reply with quote
I didn't want to start a new thread so here it goes:
Can I make a stock baywindow swaybar fit on my 60 stock width beam? It seems like baywindow shit is easier to find in junkyards/classifieds. My beam has chunky lower control arms, if that might make it better or worse. thanks.
Clara Premium Member
Clara is offline
PostPosted: Fri Nov 21, 2008 2:18 pm    Post subject: Reply with quote
split (regular and ambulance versions):
211 411 309 stabilizer 18mm dia.
271 411 309 stabilizer 16mm dia.
bay:
211 411 309 A
This is from parts list, I don't know the difference to look at them
Culito
11010101
Culito is offline
PostPosted: Fri Nov 21, 2008 7:40 pm    Post subject: Reply with quote
I'm assuming that the sway bar doesn't make much difference on a single cab because of the lower center of gravity?
© CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote:
big bus mike
big bus mike is offline
PostPosted: Fri Nov 21, 2008 7:45 pm    Post subject: Reply with quote
So I've got a sway bar and a new rubber mounting kit, but I'm concerned about bolting it up. The buses I'm using for reference have little metal bands with pinch bolts holding the end of the swaybar onto the contol arm. The bay buses at the shop just use a bolt and a nut.
I'm assuming that I need these clamps to properly secure the swaybar, correct? Just using the rubber mounts seems like a bad idea to me...
View user's profile Send private message Visit poster's website AIM Address Facebook Gallery Classifieds Feedback
Clara is offline
PostPosted: Fri Nov 21, 2008 10:29 pm    Post subject: Reply with quote
67 bus:
Dewayne Premium Member
Dewayne is offline
PostPosted: Thu Jun 18, 2009 6:12 am    Post subject: Reply with quote
Just got a front sway bar and camber compensator from Empi after reading this thread...
My question is.. since my 64 DC didn't have a sway bar, I don't have the two clamps for the end of the bar. I'm not talking about the bushing and clamp, it's the pinch clamp on the very end. I looked on WW's site and they don't show them... any ideas where I can purchase a set? Or are they a 'salvage yard only' item... in which case I'm in BIG trouble.... Confused
Thanks!
Dewayne
"My ex-wife had a hint of a beard and she looked like a manly-girl... that made no difference..."
Drive 'em if ya got 'em, and don't brag if you didn't do the work yourself...
'64 SO34
'60 SO23
westy@7000
westy@7000 is offline
PostPosted: Thu Jun 18, 2009 6:52 am    Post subject: Reply with quote
I got mine used from Bus Boys.
Page: 1, 2, 3  Next
