Shepherds hook - do most use them? Make or buy?
markeaton
markeaton is offline
PostPosted: Wed Jun 02, 2021 5:09 am    Post subject: Shepherds hook - do most use them? Make or buy? Reply with quote
All-
Do most use a shepherds hook steel vacuum line to their carburetor? Are they needed?
If so, I saw the video on how to make, but do any vw vendors sell them?
Thanks
-Mark
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Jun 02, 2021 6:12 am    Post subject: Re: Shepherds hook - do most use them? Make or buy? Reply with quote
It's nothing fancy. You can simply loop the hose higher than the vacuum port or make one out of metal tubing.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
markeaton
PostPosted: Wed Jun 02, 2021 6:53 am    Post subject: Re: Shepherds hook - do most use them? Make or buy? Reply with quote
Gotcha.... thanks
Eric&Barb
Eric&Barb is offline
PostPosted: Wed Jun 02, 2021 7:26 pm    Post subject: Re: Shepherds hook - do most use them? Make or buy? Reply with quote
Needed if one wants the vacuum advance not to fill with gasoline. Rubber diaphragm does not do well in the long term by being soaked with fuel.
In Stereo, Where Available!
tasb
The Distributor Distributor
tasb is offline
PostPosted: Sat Jun 05, 2021 8:28 pm    Post subject: Re: Shepherds hook - do most use them? Make or buy? Reply with quote
From the 1960's the diaphragm is actually made of a speaker cone like paper- even more vulnerable.
I would say most do not know about them, yes they are needed, I've had NOS in the past and good used off and on and yes there are vendors that have them.
Roads Scholar
Member# 2059
tasb
tasb is offline
PostPosted: Sat Jun 05, 2021 8:36 pm    Post subject: Re: Shepherds hook - do most use them? Make or buy? Reply with quote
There was an evolution to the line and not always in the shape of a shepherds crook.
Roads Scholar
Member# 2059
Braukuche
Braukuche is offline
PostPosted: Sat Jun 05, 2021 8:41 pm    Post subject: Re: Shepherds hook - do most use them? Make or buy? Reply with quote
71 up with the push pull cans didn’t use them.
Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1989 Westfalia
tasb
tasb is offline
PostPosted: Sun Jun 06, 2021 8:44 pm    Post subject: Re: Shepherds hook - do most use them? Make or buy? Reply with quote
From my experience the advance line was still a "shepherds crook" but the retard side was not.
Roads Scholar
Member# 2059
Braukuche
PostPosted: Mon Jun 07, 2021 7:16 am    Post subject: Re: Shepherds hook - do most use them? Make or buy? Reply with quote
You know more than I, so I double checked looking at old brochures and you are correct, they used them even on the ones with the advance port located at 7 o’clock.
Guess what I am going to be doing this morning…
Retirement is here!
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
1989 Westfalia
markeaton
PostPosted: Mon Jun 07, 2021 7:27 am    Post subject: Re: Shepherds hook - do most use them? Make or buy? Reply with quote
What size metal line is common? Can a normal brake line work? 3/8"
Eric&Barb
PostPosted: Mon Jun 07, 2021 8:10 am    Post subject: Re: Shepherds hook - do most use them? Make or buy? Reply with quote
2mm which is about .080" (80/1,000 of an inch).
3/8" is .375" (375/1,000 of an inch)
markeaton
PostPosted: Mon Jun 07, 2021 8:12 am    Post subject: Re: Shepherds hook - do most use them? Make or buy? Reply with quote
Thanks..... to be clear, you are saying 2mm is the correct size and not the 3/8"
Eric&Barb
PostPosted: Mon Jun 07, 2021 9:20 am    Post subject: Re: Shepherds hook - do most use them? Make or buy? Reply with quote
Exactly.
heimlich Premium Member
VWNOS.com
heimlich is online now
PostPosted: Tue Jun 08, 2021 1:33 pm    Post subject: Re: Shepherds hook - do most use them? Make or buy? Reply with quote
VW ones have nipples like this on the ends:
You will see aftermarket ones where they just trim a piece of tube off.
