wheel rub
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
Tbirdusa
Tbirdusa is offline
PostPosted: Sat Jul 19, 2008 5:14 pm    Post subject: wheel rub Reply with quote
I've got a bad case of wheel rub on the inside of the fender well. Car is substantially lowered with huge rubber under it.
I've got 295/15's on 10" rims. Rims are 4.75" bolt pattern and hubs have been redrilled obviously. I've already got two spacers on the drums and if I can't go any further. I want the rubber to stay where it is on the outside up under the fender but I need to get the inside of the tire further out. I'd like to keep the rims that are on the car.
Can I put a narrower tire on this rim and get the clearance I need? Car has big engine and when the weight transfers they rub real bad.
Royals 2015 World Champions
Chiefs 2017 Superbowl winner
1986 Falco records Rock Me Amadeus!
67 Shane
67 Shane is offline
PostPosted: Mon Jul 21, 2008 12:51 pm    Post subject: Reply with quote
10" rims?
-OstKüste-
67 Euro Type 1.
67 SO-42 Westfalia
Tbirdusa
Tbirdusa is offline
PostPosted: Mon Jul 21, 2008 2:23 pm    Post subject: Reply with quote
67 Shane wrote:
10" rims?
yeah... 10" wide rims. The hubs are drilled for 4 3/4" bolt 5 lug pattern. It's a Chevy pattern.
Franklin's VW Werks
Franklin's VW Werks is offline
PostPosted: Mon Jul 21, 2008 4:23 pm    Post subject: Reply with quote
10" rims are too much. You'd have to do some serious modifications to the car to make those work without rubbing. If I were you I'd stick to something no wider than 8" then play with spacers. Your clearances will still be really tight, but it should work fine.
I assume you've got it narrowed already?
Franklin's VW Werks
Service and Parts for the Pacific Northwest and Worldwide.
Custom Narrowed Beams, Wilwood/Porsche Brake Kits, Roll Cages and More!
On MySpace
SBS #24
Last edited by Franklin's VW Werks on Mon Jul 21, 2008 5:04 pm; edited 1 time in total
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Gallery Classifieds Feedback
Tbirdusa
Tbirdusa is offline
PostPosted: Mon Jul 21, 2008 4:42 pm    Post subject: Reply with quote
narrowed 3" on each side in the rear. The guy I bought the car from wanted a real rat rod tubbed rear end look. it shows good but it's just not drivable with the monster skins on it.
Franklin's VW Werks
PostPosted: Mon Jul 21, 2008 5:05 pm    Post subject: Reply with quote
You have a really good custom shop nearby? Wink
That's something we could do here, but to be honest it's probably not worth the time and expense. Are you totally in love with the wheels? Post a pic so we can see what you're working with.
Franklin's VW Werks
On MySpace
SBS #24
Tbirdusa
Tbirdusa is offline
PostPosted: Mon Jul 21, 2008 6:43 pm    Post subject: Reply with quote
My gallery may give you an idea of what I'm dealing with. Rims are Crager 5 spokes and I'm not attached to them but was hoping to run them 1 more year as I've dumped a ton of cash in the engine this year.
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
