6Volt Generator to 12 Volt
jimmybo1313
jimmybo1313 is offline
PostPosted: Wed Jul 30, 2008 10:40 am    Post subject: 6Volt Generator to 12 Volt Reply with quote
Can anyone direct me to a shop that will convert my 6 volt generator to 12 volt. I have a 64 notch and I have converted it to 12volt accept for the generator and regulator. I did not realize the shroud was different on the 1500. I would like to start driving her and work out a few bugs before I start changing the shroud and all. I'm in South Carolina but I would ship my generator anywhere to get it done. It seem's like I read that the 1600 fan and fly wheel where bigger than the 1500 and the fan cooled better. Is that true? My book shows the same fan for all models or atleast the same volume of air flow. If the fan and flywheel are smaller on the 1500 would they allow hire RPM's and horses if I built up my motor at a later date? Would the diminished air flow/cooling make it not a good idea? I'm just thinking outload!! Thanks in advance, Jim
Russ Wolfe
Russ Wolfe is offline
PostPosted: Wed Jul 30, 2008 12:00 pm    Post subject: Reply with quote
6V flywheels were slightly smaller, but not much. The 6V has 109 teeth, and the 12V has 130 teeth. There is no real difference in weight.
All of my books show that the all the T-3 fans put out the same volume of air.
Yes, the 12V fan housing has a different cradle for the generator.
Gary: OK. Ima poop.
ETPEak
ETPEak is offline
PostPosted: Wed Jul 30, 2008 2:37 pm    Post subject: Reply with quote
and a 12 volt fylwheel will not fit into the 6 volt tranny case with out some help from a grinder....
jimmybo1313
PostPosted: Wed Jul 30, 2008 8:12 pm    Post subject: Reply with quote
DDB said they can rewind my 6 volt gen. to 12 volts for $180.00 and about 3 weeks. I was hoping to keep it under $100.00 with freight! Has any body had this done? Did it last and where did you have it done?
jimmynotch
jimmynotch is offline
PostPosted: Wed Jul 30, 2008 9:33 pm    Post subject: Reply with quote
I had it done here in Seattle for about $100 or so. I had mine done at an auto/marine electrical shop... where they rebuild starters, generators, etc. You can probably find a shop locally that can do it. The guy that did mine replaces the 6V field coils from the stock genny with those from a 12V Porsche (356 or 912 IIRC). I can't remember if he also replaces the comutator or not, but its actually a very basic mod nonetheless. Just know that the 6V generator pulley spins too slow at idle to charge the battery, so make sure you have a good cell.
Jim in Sacto -
my wonderful loving supportive wife wrote:
You guys are dorks.
1965 1500-S Notchback --"Maggy"
1971 Type 2 Double Cab --"George"
TOOB member #2
ETPEak
ETPEak is offline
PostPosted: Wed Jul 30, 2008 9:36 pm    Post subject: Reply with quote
my place here in phoenix can not find the small case 12 volts fields anymore... I had to go with a later fan housing....
jimmynotch
PostPosted: Thu Jul 31, 2008 8:10 am    Post subject: Reply with quote
At that point, I would run a DDB alternator then...
Jim in Sacto -
You guys are dorks.
TOOB member #2
snj
snj is offline
PostPosted: Thu Jul 31, 2008 3:53 pm    Post subject: Reply with quote
Mind posting the name of that place?
jimmynotch
PostPosted: Thu Jul 31, 2008 4:06 pm    Post subject: Reply with quote
PM me for details....
Jim in Sacto -
You guys are dorks.
TOOB member #2
