Mpec2 Samba Member
Joined: May 24, 2015 Posts: 113 Location: Chicago, IL
Posted: Wed Sep 25, 2024 12:27 pm Post subject: Installing an aux connection, 1972 VW Bus |
Has anyone any experience making some sort of aux connection to speakers in your buses/bugs.
I've got a period correct AM radio in my 72 bus, that i don't want to remove/replace.
I've also got 2 additional speakers in the back of the camper that i would really like to use to connect to an aux so i can play my own music during longer camping trip drives.
I'm not particularly well versed in electronics, but preliminary research shows i could maybe wire the speakers into an amp, and then just pull power to the amp from somewhere. I could probably pull power from the existing radio, since most amps seem to have an on off button anyways.
Would anyone have any recommendations for an amplifier? Or in general any thoughts on doing something like this.
Thanks _________________ 1972 Westfalia |
WhirledTraveller Samba Member
Joined: January 09, 2008 Posts: 1414 Location: Cambridge, MA
Posted: Wed Sep 25, 2024 12:46 pm Post subject: Re: Installing an aux connection, 1972 VW Bus |
I use a small Kenwood 90 watt per channel bluetooth amplifier for a similar purpose. The model I have is discontinued, but this looks similar:
https://www.amazon.com/Marine-Bluetooth-Amplifier-Channel-Stereo/dp/B07WS7DL5W/
Nice to have the bluetooth, but you can use an aux cable if you want. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
Mpec2 Samba Member
Posted: Wed Sep 25, 2024 12:50 pm Post subject: Re: Installing an aux connection, 1972 VW Bus |
Bluetooth would be even better since apple keeps changing their inputs...
That you for the link, i appreciate it.
Anything special that went into wiring it, if you recall? _________________ 1972 Westfalia |
Posted: Thu Sep 26, 2024 8:33 am Post subject: Re: Installing an aux connection, 1972 VW Bus |
Mpec2 wrote: |
Anything special that went into wiring it, if you recall? |
No but you do need to be familiar with basic wiring/crimping. I hid the amp up under the dash and used VHP tape to put the little control in a discreet spot.
I also wired it into the rear defrost switch... rear defrost doesn't work anyway and allows me to turn the stereo on and off without putting the key in the ignition. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
Mpec2 Samba Member
Posted: Fri Sep 27, 2024 6:15 am Post subject: Re: Installing an aux connection, 1972 VW Bus |
Good idea with the defroster, may very well do the same thing now that you mention.
I'm thinking of putting the amp in the compartment behind the drivers seat perhaps, screwing it into the wood from the wooden seat or double sided taping it to the metal portion from the drivers seat.
Thanks for the insights. Looking forward to some actual music vs just AM radio talk shows for a change. _________________ 1972 Westfalia |
jjvincent Samba Member
Joined: January 11, 2016 Posts: 1422 Location: Bethlehem, PA
Posted: Mon Sep 30, 2024 7:54 am Post subject: Re: Installing an aux connection, 1972 VW Bus |
A friend of mine put these Pyle speakers on his boat. They have input for a regular radio but they have bluetooth too. You need to run 12V to them though but they are just run of the mill 6.5" round speakers. I think they sound great and do the job.
If not that, hide a bluetooth speaker under the dash and go from there.
https://www.amazon.com/6-5-Inch-Bluetooth-Marine-S...2742?psc=1 |
Mpec2 Samba Member
Posted: Mon Sep 30, 2024 9:37 am Post subject: Re: Installing an aux connection, 1972 VW Bus |
Ooo thats not a bad idea as well.
I ended up mounting a bluetooth amp though, saw it as a reasonable solution to the already mounted speakers.
Sound is good but current speakers are very old and not particularly loud, so thatll be the next upgrade before next camping season.
Thanks for the input and help gents. _________________ 1972 Westfalia |
