Lock Cylinder Removal?
Runboy
Runboy is offline
PostPosted: Wed Aug 13, 2008 7:27 am    Post subject: Lock Cylinder Removal? Reply with quote
Did a search of this forum and didn't turn up anything. Does anyone have any info or know how on removing the lock cylinders from all of the door handles on a 59 type 2?
Mike
vw7266
vw7266 is offline
PostPosted: Wed Aug 13, 2008 7:37 am    Post subject: Reply with quote
i know on the front you have to knock the pin out of the door handle and take it apart then theres a small flat head screw you have to loosen to get the actual cylinder out.
PostPosted: Wed Aug 13, 2008 9:23 am    Post subject: Reply with quote
Front door handle:
Closeup of small screw:
Remove handle from Bus
Drive out cross pin with punch (in left center above)
Spring will fall out (may be broken as seen above)
Move finger piece upward to expose tiny screw
Use small screwdriver to undo screw
Insert key, draw out cylinder
Cylinder may be stuck in place due to grease or age. Spray with your favorite cleaner to help it slide out. I use spray carb. cleaner to clean everything up, then relube and reassemble.
Cargo door handle and rear hatch handle are similar except there is no cross-pin to remove, just remove from Bus, remove locking ring, and undo the small screw.
Da TOW'D
Da TOW'D is offline
PostPosted: Wed Aug 13, 2008 7:31 pm    Post subject: Reply with quote
I've got a couple of Ice pick handles that need a new spring.
Has anybody found a good source for those replacement springs?
'57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
'69 Karmann Ghia Convertible (new project)
'92 Eurovan Willy
'99 Eurovan Winnie
and NUTS
Ian
Ian is offline
PostPosted: Wed Aug 13, 2008 8:06 pm    Post subject: Reply with quote
http://wolfsburgwest.com/cart/DetailsList.cfm?ID=211837215
http://wolfsburgwest.com/cart/DetailsList.cfm?ID=111837215
All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012 & KEN CRIMMINS 1957-2024
Runboy
Runboy is offline
PostPosted: Wed Aug 13, 2008 9:20 pm    Post subject: Reply with quote
Thanks for the info Guys. Wish me luck and I will post back my results after rebuild and re-plating.
Mike
Da TOW'D
Da TOW'D is offline
PostPosted: Wed Aug 13, 2008 9:27 pm    Post subject: Reply with quote
ya thanks Ian
that is exactly what I was looking for
good luck with your handle rebuild Runboy
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy
'99 Eurovan Winnie
and NUTS
PostPosted: Thu Aug 14, 2008 12:58 am    Post subject: Reply with quote
I have the Wolfsburg West springs on a few of my door handles.
They work well.
powellscooter
powellscooter is offline
PostPosted: Thu Aug 14, 2008 5:03 pm    Post subject: Reply with quote
They work well.
I just put one on the drivers door in my panel and it works well but is noticably weaker than the original on the passenger side door.
PostPosted: Thu Aug 14, 2008 11:20 pm    Post subject: Reply with quote
They work well.
They feel the same to me on my '61. I have one of each.
I noticed my '63 springs feel weaker than my '61. They are a different design.
