Window Crank Modification
DAW
DAW is offline
PostPosted: Wed Aug 13, 2008 9:46 am    Post subject: Window Crank Modification Reply with quote
The PO of my '70 bug installed speakers within the radius of the window cranks. The cranks rub if the grilles are on the speakers and it looks crude without the grilles. If the crank were spaced about 1/4" more away from the door panel it would clear fine.
Does anyone know of an alternate source for a window crank that has more offset (arm farther away from the door panel)? Cranks from a Volvo 240 bolt-on but they aren't any farther away from the panel, plus they have a little less lever-arm and require more applied force to move the stubborn windows.
I searched and saw nothing on this. One possibility would be to make an extension/adapter for the shaft, but it would be a lot easier to just substitute a crank that fits.
DAW
Mr. Unpopular
Mr. Unpopular is offline
PostPosted: Wed Aug 13, 2008 10:32 am    Post subject: Reply with quote
I seem to remember somebody selling shorter cranks a few years ago. I'll try to look through some old mags.
"In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
-Keith Duckworth, creator of the Ford/Cosworth DFV
DAW
DAW is offline
PostPosted: Wed Aug 13, 2008 1:01 pm    Post subject: Reply with quote
I appreciate the info; but a shorter crank won't help because it would have to be about 2'' long to clear the speaker grille (and wouldn't provide enough leverage to crank up these old windows).
The crank has to be offset inboard more than the stock VW crank is in order to clear the speaker and still be long enough to be do the cranking.
DAW
Mr. Unpopular
PostPosted: Wed Aug 13, 2008 1:02 pm    Post subject: Reply with quote
Wow, sounds like the PO is guilty of extremly poor planning.
rustybutterknife
rustybutterknife is offline
PostPosted: Wed Aug 13, 2008 1:24 pm    Post subject: Reply with quote
http://www.gowesty.com/ec_view_details.php?id=3678&search_phrase=window%20spacer&start=60
I used two of these kits (one kit per door) and stacked them (had to also find longer screws)... it worked. If the inside pannel is already cut and in otherwise good shape I would think this route would be acceptable.
*edit*-I don't remember paying that much for them though.
What, they don't sell purple locktite? Just mix the red and the blue together.
Last edited by rustybutterknife on Wed Aug 13, 2008 1:27 pm; edited 1 time in total
Mike Fisher
Mike Fisher is offline
Easiest way would be just buying new door panels.
blacktruck
blacktruck is offline
PostPosted: Wed Aug 13, 2008 2:31 pm    Post subject: Reply with quote
its a crap shoot but maybe get a spare handle and see if you can heat it and bend it-
