Finding 80mm cylinders for 36hp project
gimmesomeshelter
gimmesomeshelter is offline
PostPosted: Sat Nov 01, 2008 11:52 am    Post subject: Finding 80mm cylinders for 36hp project Reply with quote
Hello-
The more I think about it, it would be nice to go up from 77mm to 80mm cylinders. I've been looking around and my only options seem to be custom (e.g. nickies from LN), or to modify 80mm Porsche cylinders. BTW, I plan on stuffing 74mm Porsche crank/rods into a 36hp case, and buying custom pistons so I can keep the engine width stock. I've noticed that AA Performance (yes, I know, off-shore rubbish) sells 80mm pistons/cylinders for 356’s, but they're made for later 3 piece cases (wider stud pattern) and are longer than my 36hp cylinders. How hard would it be to 1) shorten the cylinders, 2) move the stud locations so they'll fit a 36hp case? Here's a link: http://cgi.ebay.com/ebaymotors/Porsche-356-912-New...0276684080
BTW, if anyone has any ideas where I can find custom cylinders for a reasonable price, I'm sure we would all like to know.
Thanks,
Paul
"I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman
Bengt H
Bengt H is offline
PostPosted: Sat Nov 01, 2008 12:10 pm    Post subject: Reply with quote
This is how I changed my worn out 356 cylinders, after this they where bored to 83 mm.
Braukuche
Braukuche is offline
PostPosted: Sat Nov 01, 2008 2:13 pm    Post subject: Re: Finding 80mm cylinders for 36hp project Reply with quote
gimmesomeshelter wrote:
Hello-
Thanks,
Paul
There's a guy on this site in the classifieds selling a set of over sized P&Cs. The cylinders have been "reconditioned" whatever that means. I think he wants $300 for them.
--Dan
coolairX2
coolairX2 is offline
PostPosted: Thu Nov 06, 2008 5:49 pm    Post subject: Well... Reply with quote
I purchased 82.5 Porsche 912 P&C's from Joe Ruiz for my 36hp Okrassa. He turned down the fins a little and I machined the case to fit other than that they are a drop in. The price was around $900 which is not necessarily a bargain.
-Craig
Shorrock
Shorrock is offline
PostPosted: Thu Nov 06, 2008 10:56 pm    Post subject: Re: Finding 80mm cylinders for 36hp project Reply with quote
Thanks,
Paul
Here is the set I am planing on using. Shasta 80mm JE custom pistons and Durabar Extruded Cast Iron machined cylinders:
oval56
oval56 is offline
PostPosted: Fri Nov 07, 2008 12:18 am    Post subject: Re: Finding 80mm cylinders for 36hp project Reply with quote
Thanks,
Paul
356 pre a pistons??? valve position to piston?!
pricerange?
www.oval56.com
1956 Oval, 2364ccm typ4
1957 Oval Ragtop 1584ccm singel port modified
1950 Hebmüller, 1584ccm okrasa modified
DBK Germany!!!!!!!!!!
www.dbkvw.com
Shorrock
Shorrock is offline
PostPosted: Fri Nov 07, 2008 6:44 am    Post subject: Re: Finding 80mm cylinders for 36hp project Reply with quote
pricerange?
Yes they are Pre-A. I am planing on using a NOS 36hp case modified to take an NOS 912 74mm CWC, 912 Rods, 80mm Shasta P/C and Pre-A heads. According to Duane his P/C are set up for 8.5 compression with everything else stock. If you want to order you must contact him by phone listed on the bottom of his web site. He can custom make the pistons if you want something else (no valve pocket etc.). Read up on the Durabar cylinders they are regarded as the best.
Here is a couple of links to the Shasta info:
http://shastadesign.net/pistonandcylinders.php
http://www.maxted-pageandprill.com/Products/shastadesign.html
