Another Heater question
bmwloco
bmwloco is offline
PostPosted: Sat Nov 29, 2008 8:52 am    Post subject: Another Heater question Reply with quote
O.k. I'm actively working on my heater. It looks good. I've checked everything. Even spark plug looks 5 by 5.
So... fuel supply. I do not have an original tank in my Thing. I just checked the original though, and it doesn't look any different than the one in it now.
I'm working alone, and I need to make sure my thought process is in the right orbit.
Plan on doing it like this:
- With low fuel in tank, remove it.
- Find fuel line for heater (it does go down through the trunk). Replace as necessary.
- Check fuel pump for heater. Replace if necessary.
- install "T" off of fuel tank.
- Button up, fuel up, take out side and try to fire up.
Do you see any missed steps? I'm pretty task oriented and I'd like to do this right the first time.
It sure would be nice to have heat in my Thing soon. Winter is coming.
'85 Vanagon Westfalia
doublecanister
doublecanister is offline
PostPosted: Sat Nov 29, 2008 9:21 am    Post subject: Reply with quote
Hey BmwLoco,
from what I know on these so far, that sounds right, my heater dont work either but it is all hooked up.
I can supply a photo if you think it would help with your connections.
Mine has the Tee off the tank, with a fuel filter to the heaters fuel pump.
As a test (once your'e done)you could turn it on and see if the heaters fuel pump squirts gas prior to running the fuel line to the heater, I belive its 30 revs of the fan to 1 squirt of gas so it will be a pulse instead of a constant flow.
Yall correct me if i'm wrong, I've been reading up on this stuff as I have to take on the same project.
I may be a few weeks behind you but would be glad to offer any photos if you think it will help ya.
Have fun, good luck.
T.
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8
bmwloco
bmwloco is offline
PostPosted: Sat Nov 29, 2008 2:13 pm    Post subject: Reply with quote
Another question: where does the fuel for the heater come from?
Is there a "T" valve off the bottom of the tank?
Photos? Parts source?
[email protected]
mpb181@aol.com is offline
PostPosted: Sun Nov 30, 2008 9:55 am    Post subject: Reply with quote
Yes there is a t-fuel line, not so much a valve, and you should plan on changing the fuel filter,
it attaches to the body just before the pump.
I have some t's and other heater parts
Michael Basso
http://www.thingparts.com
New and Used VW Thing Parts Free advice
CALL 518 630 0173
kme_eone
Banned
kme_eone is offline
PostPosted: Sun Nov 30, 2008 11:15 am    Post subject: Heater Reply with quote
What brand of gas heater do you have? South Wind or Eberspacher?
Chris Blankenship
South Wind parts and service
907-276-3397
Anchorage, AK
mrafindley
mrafindley is offline
PostPosted: Sun Nov 30, 2008 1:58 pm    Post subject: Reply with quote
I need a fuel pump for mine but not all the gold plated ones everyone has. what happened to the days of i will help u if you will help me anyways
73 THING
67 Beetle
http://w2.wolfsburgii.com/downloads.htm
MercurialThing
MercurialThing is offline
PostPosted: Mon Dec 01, 2008 11:56 am    Post subject: Reply with quote
I have a picture of the set up bmwloco, it's after I pulled the tank, so everything looks cruddy. I have a large version of the photo if you'd like a larger view. I can post it tonight when I get home.
[EDIT]Removed now irrelevant comments[/EDIT]
..._____
..|_____|
[o\|_|_|/o]
.U..........U
Southern Integrity Aircoolers
Last edited by MercurialThing on Mon Dec 01, 2008 12:48 pm; edited 1 time in total
crofty
Judas of the North
crofty is offline
PostPosted: Mon Dec 01, 2008 12:47 pm    Post subject: Reply with quote
Those days died when the hippies got jobs. Very Happy
Mans gotta make a living, right?
HamburgerBrad wrote:
bmwloco
bmwloco is offline
PostPosted: Mon Dec 01, 2008 6:39 pm    Post subject: Reply with quote
MercurialThing thanks!
Pulled the image down on my Mac and hit the "+" key. Clear as a bell. Thank you very much!
I'll be on it very soon... as soon as I find my "T" valve. I know I put it somewhere.
I need to drive the Thing more too. Full tank of fuel and all.
MercurialThing
PostPosted: Mon Dec 01, 2008 8:22 pm    Post subject: Reply with quote
You're welcome. I've been thinking about simplifying the set up and putting a big fuel filter in-line just after the gas tank before the "T" fitting so I only have one filter and it takes care of both the engine and the heater. Glad I could help!
..._____
..|_____|
[o\|_|_|/o]
.U..........U
Ian Epperson
Ian Epperson is offline
PostPosted: Tue Dec 02, 2008 8:20 am    Post subject: Reply with quote
Regarding those lines, I'm sure they're supposed to be metric, but I've found that a 1/4" line fits:
- from the tank to the T
- from the T to the body
- from the T to the filter
- from the filter to the pump
And 3/16" line fits
- from the pump to the heater (about 4 foot)
Also, I like having the strait-through part of the T go from the tank to the body. That portion will have the least flow restriction and should go to the biggest fuel draw - the engine. The fuel feed that makes a 90 degree turn should go to the pump as it's got a much lower flow requirement.
VW-181 shirts and stickers.
http://ian.epperson.com/vw
Ian Epperson
PostPosted: Tue Dec 02, 2008 8:31 am    Post subject: Reply with quote
I did that when I put an electric fuel pump under the tank. Here's my filter:
It has duel outputs, one to feed the pump for the engine and one to feed the pump for the heater.
Here's the bracket I built that now mounts in the area where that T was. It's bolted to the pan and just clears the right-hand tie rod.
MercurialThing
PostPosted: Tue Dec 02, 2008 8:48 am    Post subject: Reply with quote
Wee
Not so wee
Friggin' huge!
Of course, I guess you need a monster filter for that monster Raby engine in your Thing. Some day... some day.
That's a great idea turning the "T" so the fuel goes "straight" through to the engine compartment and the "turn" feeds the gas heater. I'll be adding that change to my set up when I get my gas lines in a week or two.
I've got lots of parts coming as Christmas presents... CANNOT wait!
..._____
..|_____|
[o\|_|_|/o]
.U..........U
