CraigL Samba Member
Joined: December 07, 2008 Posts: 45 Location: San Diego
Posted: Sun Dec 07, 2008 11:36 am Post subject: 16" Westfalia Tires need recomendation |
I am working on upgrading my '90 Westy and need some recomendations on tires. I just picked up the 16" rim package from Gowesty yet choose not to get the tires they sell based on some issues I read about the load rating that the van requires (GW tires do not meet that rating). So, I wanted to see if Samba members could help me out. I have done a search and cannot locate a topic in the forum that covers this issue. Quite a bit about rims though. So, I have a '90 2wd Full Camper. Standard springs with new 16" rims. I live in San Diego so the van will not see much snow so a snow tire is not needed. I would like an A/T tire as I do take trips to Baja from time to time though I do not do much off road when there.
Pls let me know what direction you would recomend. Thanks in advance and if there is a link to this topic here or elsewhere please pass it on. |
Steelhead Samba Member
Joined: February 25, 2007 Posts: 1791 Location: Kentfield, CA
Posted: Sun Dec 07, 2008 1:02 pm Post subject: |
Here's what I went with for 16" A/T. I didn't want to increase the rolling diameter too drastically. Love 'em so far. Quiet, but someone said they get louder over time (as I think most tires do).
215/60R16 Yokohama Geolander AT-S. Treadwear: 500, Load: 1521 lbs., max pressure: 51 psi, diameter: 26.1", revs per mile: 796
_________________ '77 Bay Window / '89 Caratsburg (aka. the Stormtrooper) |
82WestyMan Samba Member
Joined: December 28, 2006 Posts: 1098 Location: Western OR
Posted: Sun Dec 07, 2008 2:07 pm Post subject: |
I have these on my 82 Westy w/16" after-market (Audi A6) rims
ContiProContact - 225/55R16 99H AUD XL
http://www.discounttiredirect.com/direct/tires/continental/size/viewProductDetail.do?pc=26586
I live in the South so snow really isn't really an issue for me but they're VERY impressive in rain
'XL'/99 load rating (1709 lb)
H-rated (130 mph) - not something you're likely to experience but it tends to give you a stiffer sidewall and a better 'road feel'
the rest of the rating is:
Treadwear: 400
Traction: A
Temperature: A
not cheap but I love them
I went from a 205/70HR15 on factory alloy wheels to these
The difference in road wander was like night and day
(ps - i also run H&R lowering springs with Bilstein HD's) _________________ "The floggings will continue until morale improves"
"I never did give anybody hell. I just told the truth and they thought it was hell" - Harry S. Truman
82 Westfalia - w/ a Raby 'Camper Special' engine |
Tracey Samba Member
Posted: Mon Dec 08, 2008 9:53 am Post subject: |
| If you can return the rims for the 15s it would give you a much better choice of tires. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19160 Location: Retired South Florida
Posted: Mon Dec 08, 2008 11:39 am Post subject: |
| I put these on my rims from Go Westy. P215/65R-16 YOKOHAMA AVID TRZ I have a TDI engine and was looking for a taller tire over stock. I don't think you'll get much more tire on the Go Westy 16 rims without raising the ride height. My Vanagon just fits in my garage. That was important too. |
Dave56 Samba Member
Joined: October 01, 2008 Posts: 24 Location: Westerly RI
Posted: Mon Dec 08, 2008 3:52 pm Post subject: |
CraigL,
Try the tire rack. You can google it. They have a good selection of tires, specs and reviews.
Good Luck
Dave |
astaal Samba Member
Posted: Mon Jun 22, 2009 10:04 pm Post subject: Vanagon Tires |
| Continental has a newer tire designed for vans out that I'm getting ready to try when I get my rims. Its the Vanco Contact2. The tire has a 99 Load Index in the 215/60/R16 size. 51 psi max inflation and 799 revs per mile. They are designed for high center vans (our westies qualify for that) and the reviews and specs look very promising. |
buildyourown Samba Member
Posted: Mon Jun 22, 2009 10:41 pm Post subject: |
| Steelhead wrote: |
215/60R16 Yokohama Geolander AT-S |
I have these on my Tacoma and I've been really happy with them. I drive lots of unimproved roads and they haven't let me down. Aggressive enough without being silly loud.
I went with the Nokians on my van since tire wear was not an issue for me and I wanted something that would do better in the snow.
edit: Are these available in a C-ply in that size? If I was going to baja, I would want a reinforced side-wall tire. Flat tires suck. Flat tires in the middle of no-where Mexico really suck. |
astaal Samba Member
Alaric.H Samba Member
Joined: March 28, 2009 Posts: 2529 Location: Sandy Springs GA
Toaster Samba Member
Joined: November 13, 2007 Posts: 48 Location: Gibsons BC Canada
Posted: Tue Jun 23, 2009 7:25 am Post subject: |
I just installed four BF Goodrich TA long trails 215/70/16 on my 87 two wheel drive, with VOXX MG rims.
They ride and handling very nice, and I got a 10% lower RPM. I have a Subaru 2.5 in my Vanagon
This is my third set of BFG I have purchased
I got the package from Discount Tire for $692.00 delivered after repate.
a914622 Samba Member
Joined: July 29, 2004 Posts: 957 Location: Westend of HWY2 , Wash
Posted: Tue Jun 23, 2009 8:05 am Post subject: |
| Toaster wrote: |
They ride and hanle very nice, and I got a 10% lower RPM. I have a Subaru 2.5 in my Vanagon
I got the package from Discount Tire for $692.00 delivered after repate. |
Did the 20mm offset work for you??
jcl _________________ 87 gl powerd buy 2.5subaru
75 914 getting 2.2t subaru scratch that SVX subaru |
Posted: Tue Jun 23, 2009 8:19 am Post subject: |
| a914622 wrote: |
| Toaster wrote: |
jcl |
Yes
The 20 MM ET went on just fine. I purchased new studs for the rear, but got over 8 turns on the studs that where already in the hub.
I would post a picture but I can not seem to post one. |
Posted: Tue Jun 23, 2009 2:32 pm Post subject: |
I hope this works, Picture of 87 with new wheels
[img]http://www.thesamba.com/vw/forum/album_page.php?pic_id=568945 |
shenan-agon Samba Member
Joined: May 11, 2005 Posts: 429 Location: Portland, OR
Posted: Tue Jun 23, 2009 2:58 pm Post subject: Re: Vanagon Tires |
| astaal wrote: |
I have a set of VancoContact (2?) tires on my van, albeit in the 15" size. So far, so good. |
Randy in Maine Samba Member
Posted: Wed Jun 24, 2009 4:38 am Post subject: |
Looks pretty good to me!
