trailing arm
CF
CF is offline
PostPosted: Tue Dec 09, 2008 1:49 pm    Post subject: trailing arm Reply with quote
has anyone make a replacement plate for the lower spring mount?
either weld / bolt on ??
i have 2 customers in the rust belt of jersey, 1 van needs both of them and the other needs one replaced.
the trailing arms are in good shape but the mounting plate is rotted gone.
thanks
mark
Rhinoculips
Rhinoculips is offline
PostPosted: Tue Dec 09, 2008 2:20 pm    Post subject: Reply with quote
I would ask the guys are Burley Motor Sports Direct - www.burleymotorsportsdirect.com/
They do custom and replica trailing arms for Syncos, but may be able to help you out with what I am assuming are 2wd vanagons.
Ryan
“May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.” - Edward Abbey
Click to view image
MarkWard
MarkWard is offline
PostPosted: Tue Dec 09, 2008 2:27 pm    Post subject: Reply with quote
I have no idea what you are asking about, but could you adapt one of these?
These come from circle track racing. This one is from a company called UB Machine.
