Deluxe trim; Are the clips different?
Bay Window Steve
Bay Window Steve is offline
PostPosted: Sun Dec 21, 2008 8:14 am    Post subject: Deluxe trim; Are the clips different? Reply with quote
Replacing the trim clips on my '69, (see my ads if'n you have some to donate) just curious, did the trim clips change at all from year to year? I thought someone said the trim changed for the later years, but I couldn't find that info anywhere. I searched "deluxe trim" and read several of those, but never found my exact answer.
Sankoo, sankoo very much.
'73 Transporter - Driver
'69 Deluxe
Member: WTKHABG
Original Air Cooler Member
panicalum
panicalum is offline
PostPosted: Sun Dec 21, 2008 8:29 am    Post subject: Reply with quote
This is what you are looking for. They were the same for all years.
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-241-853-547-20
'63 Bug
gone:
69 Riviera - non walk thru-Turd
1971 Type 3 squareback
1974 Orange Westy -William
1970 Deluxe Sunroof - Tinkerbell
1973 Westy - Didn't stick around long
1976 Sage Green Westy
1959 Single Cab
1982 Vanagon Westy
1974 Thing
1962 Bug
1974 Baja Bug
1973 Blue/White Thing
1978 Sage green Westy (Mom and Dad's) got me hooked
busdaddy
busdaddy is offline
PostPosted: Sun Dec 21, 2008 8:30 am    Post subject: Reply with quote
All the same clips, 68-72. I haven't seen the clips that come with the repro sets though, they could be different.
Слава Україні!
Blaubus
Blaubus is offline
PostPosted: Sun Dec 21, 2008 8:51 am    Post subject: Reply with quote
the trim itself changed between 68 and 70 (not sure just when), but just the front door spears forward of the side view mirrors. 68s are rounded, and 71s are pointed.
busdaddy
busdaddy is offline
PostPosted: Sun Dec 21, 2008 9:30 am    Post subject: Reply with quote
Must be really late 71s', all mine had the slash tip. 72s' have the pointy trim, probably to reduce the parts count as they fit left or right. Everything from the mirrors back looks the same though.
Слава Україні!
germansupplyscott
germansupplyscott is offline
PostPosted: Sun Dec 21, 2008 10:16 am    Post subject: Reply with quote
the new clips are junk too, be forewarned. they're plastic. afaik there is only one part number for the clip.
SL
Blaubus
Blaubus is offline
PostPosted: Sun Dec 21, 2008 7:19 pm    Post subject: Reply with quote
yeah new anything is junk
yeah slash tip is what i meant by pointy tip
Karl
Karl is offline
PostPosted: Sun Dec 21, 2008 9:06 pm    Post subject: Reply with quote
I believe the year question came up because of this ad:
http://www.thesamba.com/vw/classifieds/detail.php?id=673648
Blaubus
Blaubus is offline
PostPosted: Sun Dec 21, 2008 9:57 pm    Post subject: Reply with quote
regardless of junky clips, you should consider that OG clips with new moulding might not work as well.
the new moulding does not have the same profile as the OG. once i saw the new moulding, i decided i would never give up my OG moulding. the OG is taller and squarer, and has that nice patina. beltline moulding is supposed to look like deluxe window moulding, brite dip aluminum. stainless cant imitate that.
just doing my part to keep the O in OG.
420GOAT
Location: Wilmington, CA on a nice quiet street but still in the 'hood
420GOAT is offline
PostPosted: Mon Dec 22, 2008 12:46 am    Post subject: Reply with quote
WITH AL THAT BULLSHIT SAID, ive used the new clips on the corners and on the long pieces and they worked fine as long as the orientation is correct and they are back where they belong. they do work but dont withstand popping on and off.
once you realize im not impressed we will get along just fine
