Interior rear door opener mod
papawhisky
papawhisky is offline
PostPosted: Tue Jan 13, 2009 8:01 pm    Post subject: Interior rear door opener mod Reply with quote
I would like to be able to open my rear door from the inside. Has anyone got pix of a mod? I am assuming I can do something as simple as drill a hole and run a cable loop at the right place.
Papawhisky
88 Westy
70 Bug Vert (project)
1621
1621 is offline
PostPosted: Tue Jan 13, 2009 8:25 pm    Post subject: Reply with quote
Exactly. Take off the rear panel and study the mechanism for a minute. You'll probably need to drill a small hole in "lever arm" of the latch mechanism, but it's really a simple project. I ran a cord with an extra length of fuel line over the top of it (for added girth) up to an extra door handle (stock brown) that I attached to the interior as well. This way I can both open AND close the rear door from the inside. It's great for when you're camping and want the fresh air, but around 3am it becomes too cold and you want to close the hatch. You can accomplish it all without ever having to leave your bag.
'85 Westy
Captain Pike
Captain Pike is offline
PostPosted: Tue Jan 13, 2009 8:31 pm    Post subject: Reply with quote
What happens when your dog/child bumps into it and falls out the back? Sad
LEARN TO SELF RESCUE
....Bad Sneakers....
1621
1621 is offline
PostPosted: Tue Jan 13, 2009 10:21 pm    Post subject: Reply with quote
They learn not to do it again. Laughing
There's nothing to bump into unless the hatch is propped open, and even then is fairly secure. I prop the rear hatch open using one of those GW latch extenders. Obviously for camping use only, not while underway. The kids are never back there while driving to pull on the cord, and thus the hatch stays closed. Truth be told, I've not use the interior opening feature nearly as much as the grab handle to close up at night and while grabbing things out of the back. I consider it more as an emergency exit like those found in the trunks of cars.
'85 Westy
Sodo
Sodo is offline
PostPosted: Wed Jan 14, 2009 3:50 am    Post subject: Reply with quote
Thanks for the heads-up. I will look mine over to make sure the kids can't use it.
....KTMs, GasGas, SPOT mtb
westynova
westynova is offline
PostPosted: Wed Jan 14, 2009 4:35 am    Post subject: Reply with quote
I found this a while back. It has a photo of the wire loop idea but no demonstration on the inside of the panel. Also has a good idea for the sink up-gradge.
http://www.telusplanet.net/public/gary2a/rack/westy/westymods.htm
westynova
PostPosted: Wed Jan 14, 2009 4:40 am    Post subject: Reply with quote
Keeping on the door idea, i recently snapped off the handle on the sliding door. I will eventually replace it; but in a effort to stop the same thing happening to the next handle, has anyone come up with a better fix.
I was thinking of installing a grab handle on the outside at the rear of the door. I could use that to close it.
Any thoughts, ideas?
Anyone have a Side Sliding Door Handle kicking around?
Home Team Van
Home Team Van is offline
PostPosted: Wed Jan 14, 2009 10:44 am    Post subject: Reply with quote
here's another hatch latch write up.
http://www.griffco.ca/interest/vw/HatchLatch.htm
_________________________________
82 Diesel Westy
spitsnrovers
spitsnrovers is offline
PostPosted: Thu Jan 15, 2009 3:31 pm    Post subject: Reply with quote
I've made the same mod, details here www.griffco.ca/interest/ but haven't installed the hatch door back into the van yet to prove it.
Let me know what you think of this one.
papawhisky
PostPosted: Fri Jan 16, 2009 10:48 pm    Post subject: Reply with quote
Ill definitely pull the panel and do the mod. I like the idea of adding a strap for closing it as well. Innovations!
Thanks-
Papawhisky
88 Westy
dravin21
dravin21 is offline
PostPosted: Sat Jan 17, 2009 12:57 am    Post subject: Reply with quote
velcro on the door and felt to cover the end of the cable .. cant bump what you cant reach
View user's profile Send private message Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
doyll
doyll is offline
PostPosted: Sat Jan 17, 2009 4:37 am    Post subject: Reply with quote
Link to thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=317601&highlight=
woggs1 has links to his website with some writeups I found of different installs.
I would love to see a pic of the factory emergency release latch. Pretty sure it's just a piece of rod welded on.
bond007x
bond007x is offline
PostPosted: Fri Jun 04, 2021 8:44 am    Post subject: Re: Interior rear door opener mod Reply with quote
Well, I just ran into the stuck hatch latch issue this morning as I'm trying to prep the engine/car for smog test in another 6 hours .... ugh!!!
Update to one of links (apparently changed around 2018):
http://www.griffco.ca/VW/hatchlatch.htm
Now I just hope I can get the darn thing opened! Wink
valvecovergasket
valvecovergasket is offline
PostPosted: Fri Jun 04, 2021 8:49 am    Post subject: Re: Interior rear door opener mod Reply with quote
looks to be just begging to be gowesty-kit-ified
4Gears4Tires
4Gears4Tires is offline
PostPosted: Fri Jun 04, 2021 9:31 am    Post subject: Re: Interior rear door opener mod Reply with quote
I would like a Vanistan version plz and thx.
valvecovergasket
PostPosted: Fri Jun 04, 2021 9:32 am    Post subject: Re: Interior rear door opener mod Reply with quote
or this!
danfromsyr
danfromsyr is offline
PostPosted: Fri Jun 04, 2021 10:32 am    Post subject: Re: Interior rear door opener mod Reply with quote
just an FYI for this thread
many VW models have a (mandated safety) release for inside the trunk
these snap into a panel and have a cable that pulls the latch..
shouldn't be hard at all to rig into a westy rear panel
like this. https://www.ebay.com/itm/233560339909
https://www.ebay.com/itm/114773117468
Abscate wrote:
Crooked Designer
Crooked Designer is offline
PostPosted: Fri Jun 04, 2021 11:03 am    Post subject: Re: Interior rear door opener mod Reply with quote
I got an old door latch and grab handle and made my own using a bicycle brake cable and housing. I'll try to dig up the interior photos, but you only need to apply enough pressure to spring the latch (which doesn't seem like much if you're pulling from the correct position.
Also, FYI it still works to open from the inside when the hatch is locked (as the locking mechanism just rotates the opening pushing device out of the way.) because the pulling end of the cable is attached directly to the opening mechanism of the latch.
I wanted OEM look and for the latch handle to be high enough to clear any bedding / pillows. Mounted the pull handle this way as the structure inside the door is the beefiest right here and there were places to drill and mount the expanding nubs that the pull handle screws into. Works really well. Only thing I wish I had was a beefier return spring on the handle. Doesn't effect how it works, just don't like having the handle staying open until I shut the hatch.
'85 Westy full camper, Subaru 2.5L, 5 speed SubiGears + 5speedbus shifter kit
