Front Disc Brakes
Page: 1, 2, 3  Next
pandanom
pandanom is offline
PostPosted: Tue Sep 19, 2006 2:46 pm    Post subject: Front Disc Brakes Reply with quote
Hello, I have a stock 1966 Deluxe Bus. Is there any reasonable solution to finding a front disc brake system without having to pay 300.00 shipping from Germany, wait for development of a system and paying to be on the waiting list, or make radical changes like replacing a perfectly good beam or changing all the wheels to 15" and buying all new tires for the new wheels? Plus lowering which I really am not interested in. It was so easy on my bug, just buy Ghia components and change them. If you have front disc brakes, what are they and how did you do it?
Thanks,
Novice
It is never too late to have a happy childhood!
sloans265
sloans265 is offline
PostPosted: Tue Sep 19, 2006 5:53 pm    Post subject: Reply with quote
Check out Nates site. He's now doing a spindle for use w/late bus disc brakes. Seems like a good option using mostly all "stock" parts.
http://www.wagenswest.com/
1970 Lotus White Panel
In search of any Pensacola Fla dealership items
mintonman
mintonman is offline
PostPosted: Tue Sep 19, 2006 6:14 pm    Post subject: Re: Front Disc Brakes Reply with quote
If your talking about the CSP set they have a distributer in CA. & they are worth every penny.
Hoockd on fonicks werkt for mee?
under the influance "DUH"
rizzag
Now Wut?
rizzag is offline
PostPosted: Tue Sep 19, 2006 6:22 pm    Post subject: Re: Front Disc Brakes Reply with quote
doesnt the CSP kit not clear stock 14s though?
flossin, tossin, dippin, and trippin
DaveB
DaveB is offline
PostPosted: Tue Sep 19, 2006 7:07 pm    Post subject: Reply with quote
Bay setup will not clear 14's either
Dave Brooks
USAF Retired
1966 Custom Camper
rene p. l.
rene p. l. is offline
PostPosted: Tue Sep 19, 2006 7:52 pm    Post subject: Reply with quote
Why not, bay are on 14's! When you go with a bay setup, i think you must use bay wheels. Confused
mintonman
PostPosted: Tue Sep 19, 2006 7:57 pm    Post subject: Reply with quote
They make them to fit stock 14's on now
mintonman
PostPosted: Tue Sep 19, 2006 7:59 pm    Post subject: Reply with quote
Here's the link http://www.csp-shop.de/cgi-bin/shop2/shop_main.cgi?func=dlink&wkid=53257932207&artnr=20627a
I tried the link & it takes you to their vented set, so you must click around in the brake systems page to see the info on them.
DaveB
DaveB is offline
PostPosted: Tue Sep 19, 2006 8:05 pm    Post subject: Reply with quote
What I meant is using a stock Bay setup, as I did, stock 14 inch Split wheel (with adapters) will not go over the calibers. 14 inch bay rims will.
Like mentioed above CSp has a kit to clear 14 split wheels
Dave Brooks
USAF Retired
1966 Custom Camper
rene p. l.
PostPosted: Tue Sep 19, 2006 8:09 pm    Post subject: Reply with quote
Ahh better now... Did you look at the Porsche 944 set-up. Is it possible to run your 14's with this set-up. I think ronnie sell this kit
biggraham
biggraham is offline
PostPosted: Wed Sep 20, 2006 1:19 am    Post subject: Reply with quote
Are you positive the stock Splitty wheels won't fit with adapters, I've seen Bays on Empi 5s.... Question
67 S0-42 Pop-Top Walkthru
pandanom
pandanom is offline
PostPosted: Wed Sep 20, 2006 4:17 am    Post subject: Reply with quote
Thanks for all the input, very helpful in my search for front discs brakes. I think I will go with the CSP, Custom Speed Parts, P/N 499-264-5205-14 kit. This way I can keep the 14" wheels I already have and make no modifications except the brakes themselves.
thanks again
Namocsid
Namocsid is offline
PostPosted: Wed Sep 20, 2006 6:15 am    Post subject: Reply with quote
I'm also planning a front disc conversion at some point in the future. From the CSP Webpage:
CSP wrote:
CSP Front Disc Brake Kit 5/205, T2 55-70
Now you can keep your original 14 or 15 steel wheels on the bus while upgrading the front to discs brakes. With the existing CSP front disc brake system, this was not possible. With this all new constructed disc brake system these wheels can now be used.
The new kit can also be used with 15 Alloy wheels, as per the existing kit. If you intend to swap between alloy wheels and steel wheels, this is the kit for you.
The principle of the kits remain exactly the same. The kit features an alloy hub with a bolt on disc rotor. The high grade aluminium calliper bracket is bolted to the original spindle. There are no modifications necessary to install this kit. Only the master cylinder needs to be changed to a disc brake type as usual.
What master cylinder swap are they talking about, and what would fit a 67?
ITMC - Backyard chapter
Hold the pickles, it's 100% pure beef Namocsid!
pyrOman
Fire Master
pyrOman is offline
PostPosted: Wed Sep 20, 2006 6:59 am    Post subject: Reply with quote
Yes, positively they will NOT clear 14" bus wheels! EMPI's are 15" and have a different offset. That "new" kit seems to fit the bill though. Wink
a-train
a-train is offline
PostPosted: Wed Sep 20, 2006 7:31 am    Post subject: Reply with quote
I got the 14" CSP setup from William at CSP USA. Awesome quality, easy install.
I also did the MC switch in my '67. Very easy to do. You need the bay window disk brake MC ('71 I think) and a spacer kit (and save your reservoir, it fits perfect). You may also want to get new rubber grommets where the reservoir attaches to the MC....mine were dry and a bit crusty. I didn't have to adjust the plunger or anything, it mated up perfectly. Might as well replace some of the brake lines if needed too.
Running these mated up to drop spindles as well.
I like VWs
VWBobby
VWBobby is offline
PostPosted: Wed Sep 20, 2006 7:36 am    Post subject: Reply with quote
'72-79 baywindow master....
pyrOman
Fire Master
pyrOman is offline
PostPosted: Wed Sep 20, 2006 7:50 am    Post subject: Reply with quote
Nice & clean set up! Cool
Q. Did you have to also install the "proportional/check valve" on the rear brake line as the fatchicks have? Confused
Bulli Klinik
Bulli Klinik is offline
PostPosted: Wed Sep 20, 2006 8:39 am    Post subject: Reply with quote
Where is the check valve? I don't remember seeing one on my 70.
Has anyone ever tried to use the vacuum assist master cylinder found on later bays on a drum brake setup? I could have sworn that I saw a vac assist master cylinder upgrade from the factory in a book at some point..
pandanom
pandanom is offline
PostPosted: Wed Sep 20, 2006 8:43 am    Post subject: Reply with quote
Beautiful installation!
I noticed CSP has cross drilled discs for 57.00 more for the kit. Is it worth it?
rizzag
Now Wut?
rizzag is offline
PostPosted: Wed Sep 20, 2006 8:46 am    Post subject: Reply with quote
there would not be one on your 70 since it doesnt have disc brakes.
Page: 1, 2, 3  Next
