blobaugh Samba Member
Posted: Wed Feb 18, 2009 10:03 pm Post subject: Possible to make headliner white again? Headliner cleaning. |
Is there any trick to get the headliner white again? It is yellowing. I know I can replace it all, but it is in really good shape so if anyone here knows of some special way to restore it I would appreciate it.
It looks whiter in these pictures than it really is. Probably because I took these images with a flash at nighttime.
Dave24 Samba Hack Purist
Joined: April 14, 2004 Posts: 7442 Location: Hablamos Ingles, So. Cal.
Posted: Wed Feb 18, 2009 10:18 pm Post subject: |
| Westleys ?... maybe? |
Posted: Wed Feb 18, 2009 10:24 pm Post subject: |
| That looks like some sort of bleach for cleaning tires? I suppose it might work. Bleach itself might work, dunno why that didn't pop into my head before. |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71908 Location: Phoenix 602
Posted: Wed Feb 18, 2009 10:27 pm Post subject: |
If it's just dirty you can clean it. Simple Green in the mix ratios on the back can work. Or a rag and soapy water. Try not to get it too wet.
If it's the area where the glue is coming through, this would be all the thin sides, I haven't be able to do anything that was permanent. I used a watered-down bleach solution on my Ghia pillars and the yellowing came back after a while. _________________ How to Post Photos
Olymale Samba Member
Joined: April 04, 2006 Posts: 620 Location: Olympia, Wa
Posted: Wed Feb 18, 2009 10:28 pm Post subject: |
I have been somewhat successful with laundry soap and a mild bleach combo. Just need to be carefull not to stretch it as you clean. _________________ SBS #76
58 ragtop bug
60 sc
65 splitty
67 Square Back
85 911 Carrera
http://community.webshots.com/user/olymale |
Posted: Wed Feb 18, 2009 10:29 pm Post subject: |
| Tires, WW's and vinyl. I've used it on eveything from whitewalls to white vinyl vert tops to white boat upholstery with good results in most cases. |
Posted: Wed Feb 18, 2009 10:40 pm Post subject: |
| I do a section at a time (of course) and "wipe-wash" it as I go with clear water/toweling, I will say though as Everett said, it's not perm.. Needs to be done from time to time, and though I've not seen any damage on my uses, I don't know if would eventually damage an og/old headliner. |
Posted: Wed Feb 18, 2009 10:46 pm Post subject: |
Thanks for all the suggestions. If I have time tomorrow I will head to the store and get some Simple Green, and some Magic Eraser, and try them both on small sections. I will be pretty busy till the weekend though, so maybe it will have to wait till then  |
Ian Samba Moderator
Posted: Thu Feb 19, 2009 12:06 am Post subject: |
Bleche white _________________ All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012 & KEN CRIMMINS 1957-2024 |
Posted: Thu Feb 19, 2009 9:26 am Post subject: |
Bleeche-white IS westleys  |
Clara  Samba Member
Posted: Thu Feb 19, 2009 9:41 am Post subject: |
simple green and water and a sponge.
I like arm and hammer laundry soap. Baking soda neutralises.
Bleach is a bit harsh, and can help dry out the vinyl, so if you use it, do so sparingly, in a squirt bottle diluted with water. rinse well after wards.
If you hose, you'd want to take the seats out first. You don't want soggy seats. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
eth727 Samba Member
Joined: February 21, 2007 Posts: 542 Location: san diego
Posted: Thu Feb 19, 2009 9:59 am Post subject: |
| Leave it as is. It matches the patina of the rest of it. |
Posted: Thu Feb 19, 2009 5:34 pm Post subject: |
I had some time to try out the Magic Eraser today. It did a pretty good job of cleaning it up. Left only what I assume to be glue marks. Cleaning the entire headliner with Magic Eraser will require a lot of Magic Erasers. Going around just one window had it pretty dirty. I picked up some Simple Green as well, but did not have time to mix it. If it works just as well, or better, I think that will be the cheaper way to go for sure!
Here is a before and after shot.
brettsvw Samba Member
Joined: November 22, 2007 Posts: 2178 Location: Florida
