Best Dash Pad / Cover / Face?
Page: 1, 2, 3  Next
supercharged
supercharged is offline
PostPosted: Wed Mar 04, 2009 7:57 pm    Post subject: Best Dash Pad / Cover / Face? Reply with quote
I am starting the search for parts and I am hoping to get advice...
Are there any sources of dash cover and dash face that are better than the others? Question
I noticed that some look like thin plastic that is glued over the existing dash and others look thicker and are clipped in place!
I used the thin type for my daughter's Galaxie and the fit was very poor, but it has help up for four years of the Texas sun.
Supercharged Texan
"Texan by birth and the grace of God"
"Texan Until I Die"
Ghiaddict
Ghiaddict is offline
PostPosted: Thu Mar 05, 2009 6:14 am    Post subject: Reply with quote
Unless you can find a NOS original, I don't
think you can beat the "show quality" dash pads
sold by KGP&R.
All the thin plastic dash "caps" that overlay the
old pad leave a lot to be desired, from what I've seen.
AFAIK the dash face replacements
are all the same quality.
Karmann Ghia & Beetle parts available.
Convertible tops installed.
MDKG
MDKG is offline
PostPosted: Thu Mar 05, 2009 7:34 am    Post subject: Reply with quote
If you are talking about the cover with the fake wood grain I had very good experiences instaling the one from KGPR. Great fit and easy to cut with a precision knife.
Still quite a pain to remove everything around the dash before instalation though!
I have not come across good looking repro dash pads.
Good luck!
Marcel
NOVA Airhead
NOVA Airhead is offline
PostPosted: Thu Mar 05, 2009 7:48 am    Post subject: Reply with quote
I have the upper and lower pads from KGP&R. The quality is good however fit is something else. The studs on the new pad did not all line up with the holes in the underlying metal. You have to remove the stud or enlarge/make a new hole.
Its my understanding this is a common problem.
The lower pad fit with no problem.
My car still had the original pads. The replacements were very close in terms of quality of materials and look.
Ghia Owner Emeritus
supercharged
PostPosted: Thu Mar 05, 2009 10:15 am    Post subject: Reply with quote
I am glad you guys let me know about the repro dash pad. The thin plastic "slip cover" style pads always look bad. For my daughter's Galaxie there was no other choice and after several days of prep before and patching after installation, the dash looks good from five feet but up close you can see where I had to "iron" out wrinkles and gaps. Confused
But on the positive side it was inexpensive and it has held up to almost five years of harsh Texas summers (and remember our summers are 11 months long! Laughing lol!) Wink
Supercharged Texan
"Texan Until I Die"
Chinorlz
Chinorlz is offline
PostPosted: Thu Mar 05, 2009 11:30 am    Post subject: Reply with quote
Nova, which upper pad did you order from KGPR? The standard black or the show quality one?
I'm soon going to be redoing my entire front dash so issues that come up such as holes not lining up are "make or break" sorts of deals with so many options out there.
NOVA Airhead
PostPosted: Thu Mar 05, 2009 1:31 pm    Post subject: Reply with quote
I ordered the Show Quality replacement.
Ghia Owner Emeritus
Chinorlz
Chinorlz is offline
PostPosted: Thu Mar 05, 2009 3:45 pm    Post subject: Reply with quote
thanks Nova, I'll keep that in mind when ordering
Plantman
Plantman is offline
PostPosted: Thu Mar 05, 2009 4:18 pm    Post subject: Reply with quote
I used the Show Quality from KGPR also and hand no problem wit the fit or alignment of the plastic studs. I did mine about 1 1/2 years ago. The windshield, all the gauges and glove box were out. That did make the install easier as there are studs in the corners.
Good luck,
David
Every day may not be good, but there is something good in every day,
No matter where you go, there you are.
'69 bug & '71 Ghia
Chinorlz
Chinorlz is offline
PostPosted: Thu Mar 05, 2009 9:28 pm    Post subject: Reply with quote
really novice question, but do I need to purchase any screws/studs/nuts along with the new dash pad from KGPR to install? The current pad on my ghia looks to be pretty ah, "not original" shall we say.
NOVA Airhead
PostPosted: Fri Mar 06, 2009 5:30 am    Post subject: Reply with quote
Everything you need for the new install will be with the KGP&R show quality replacement.
However, if your present pad is held in with the original nylon nuts, I would hold on to them.
Ghia Owner Emeritus
mgcordato
mgcordato is offline
PostPosted: Tue Mar 10, 2009 1:44 pm    Post subject: Reply with quote
im thinking of just re-wraping my current dash. any suggestions on what type of material would be best??
sleeklines
sleeklines is offline
PostPosted: Mon Jun 22, 2009 1:21 pm    Post subject: Reply with quote
I have a 63 Ghia Coupe and it seems to be a hard year to find a good replacement. WCM seems to be the closest I have found (in research not application) to a good replacement for that year. Does anyone have any experience with West Coast Metric dash pads and know if they are good?
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger MSN Messenger Classifieds Feedback
Ghia Nut
Ghia Nut is offline
PostPosted: Mon Jun 22, 2009 6:17 pm    Post subject: Reply with quote
I got my dash from KGPR, my only complaint is the covering for the glove box cracked... will be replace by carbon fiber soon though Smile
'59 typ1 rajay turbo
'72 Ghia rajay 1641 dual 36DRLAs, 1 3/8" SS merged header and fat boy
78" GL Vert with ej22t swap
This will likely change tomorrow to something else.
View user's profile Send private message AIM Address Facebook Gallery Classifieds Feedback
cool karmann collected
cool karmann collected is offline
PostPosted: Thu Jun 25, 2009 1:54 pm    Post subject: Reply with quote
I've got the KGPR one too, the dash top pad was replaced before I got the car, but judging from the comments above about hole alignment, I'd say it is from KGPR too.
Before...
New face...
As it is today, minus the EMPI GT Crying or Very sad
kimbill
kimbill is offline
PostPosted: Sun Oct 11, 2009 6:11 pm    Post subject: Best Dash? Reply with quote
A "search brought me here ........ Our recently acquired Ghia came with an uninstalled faux wood dash face, and a tube of silicone glue... Sad . Geeeez, is that the means of attaqching a new face? What are the slots for in the dash face? ..... The PO bought it from Rocky Mountain Motorsport.
Grandpa Bill
'71 Ghia, AS
kimbill
kimbill is offline
PostPosted: Sun Oct 11, 2009 8:29 pm    Post subject: Best Dash?? Reply with quote
Ignore my previous post (above), I found the answer ..... Very Happy
Grandpa Bill
slafa
Location: Where getting a real beer is like winning the lotto
slafa is offline
PostPosted: Sun Feb 28, 2010 5:45 am    Post subject: Reply with quote
Ever get a replacement dash for your '63?
'63 KG Roadster proj.
1973 Mercury Montego MX Brougham
1977 Dodge Tradesman 200 "shorty" Van
1983 Ford 350 Econoline Ambulance
1997 Mercedes S500 W140
1976 BMW 75/6 bike
various Honda, GMC daily drivers
beicholz
beicholz is offline
PostPosted: Wed Mar 17, 2010 7:57 am    Post subject: Reply with quote
I have concluded from the thread above that I should buy a "show quality" dash from KGP&R. But here's my question:
If I bite the bullet and spend this much, will I have a crack again in a few years? Or is this part made of a material that's more resistent to the sun's heavy toll?
Thank you.
Ghiaddict
PostPosted: Wed Mar 17, 2010 8:31 am    Post subject: Reply with quote
Their written catalog states "new parts are covered as long as
you own your Ghia."
But I would ask them directly about the dash pad guarantee.
Page: 1, 2, 3  Next
