Santana Samba Member
Joined: March 18, 2008 Posts: 146 Location: T-Town, WA
Posted: Sat Apr 11, 2009 4:52 pm Post subject: Another LED instrument cluster question |
I will start by saying I read all six pages of the original LED post on here.
I know that people are using the direct fit B8.3D supplied by superbrightleds.com. What I am wondering is which B8.3D are people using??? There are 2 different options a regular and a high output.
B8.3D-R cost $1.59
B8.3D-BHP cost $2.59
Any info would be super helpful! |
vwlovr Samba Member
Joined: May 21, 2006 Posts: 1122 Location: on the road
Posted: Sat Apr 11, 2009 4:54 pm Post subject: |
| i just installed the regular and it works great, i think high output would be too much. that said, you can dim them so i think either way would work. |
a914622 Samba Member
Joined: July 29, 2004 Posts: 948 Location: Westend of HWY2 , Wash
Posted: Sat Apr 11, 2009 7:01 pm Post subject: |
I bought both the Blue and the UV and tryed them both. The UV seemed a little dark for me. The blue is what i have in.
Remember the dimmer works with leds but not as dim as the stock lights. I think the brights would not dim down enough..
They are cheap try them all
jcl _________________ 87 gl powerd buy 2.5subaru
75 914 getting 2.2t subaru scratch that SVX subaru |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12406 Location: Santa Cruz, CA
Posted: Sat Apr 11, 2009 8:56 pm Post subject: |
| The HP version is new, I haven't seen it listed before. The leds put such a low load on the system that they only dim a little bit. The Hp version might be too bright, they are more than 2x brighter than the standard B8.3D led that everybody is using. If you don't mind experimenting buy 1 of any bulb that you are considering and them make the decision which one to keep and make a final order- that is what I did. The true test of which LED will make you happy is the lighting of the speedo and the clock(the clock is the real test). Good luck and let us know the results if you decide to throw in a HP. |
Posted: Sat Apr 11, 2009 9:18 pm Post subject: |
Thanks for your input! I was thinking that I would just order both and see what looks better. I just don't want to overload the circuit and burn up the instrument cluster foil. Should I be concerned about that?
I have already had to replace my foil once and found that it is not that easy to find. |
Posted: Sat Apr 11, 2009 9:49 pm Post subject: |
| The spec. on the leds show a lower current draw with the HP version, they are a different type. I have never burned up a dash foil so I don't know what it takes to do something like that- were you using some kind of superbulbs? Good luck. |
Posted: Sat Apr 11, 2009 10:37 pm Post subject: |
Actually when I bought the van the foil was melted near the 2 top light positions. Somebody was doing something funny.
I'll let you know how the high power bulbs work. If I have time I'll post up some pics, side by side. |
