Advise Needed 21 Window
J0HN---H
J0HN---H is offline
PostPosted: Tue Oct 11, 2022 6:08 am    Post subject: Advise Needed 21 Window Reply with quote
I am looking at a 21 Deluxe Samba with a rag top but need some advise. The M tag is missing but it still has the body stamp and body tag on it.
Is there a way to know in this is a true Samba just by the body number? The owner does not have birth certificates for it and said it has been his for many years.
Thank you in advance.
sled
sled is offline
PostPosted: Tue Oct 11, 2022 6:41 am    Post subject: Re: *** Advise Needed 21 Window *** Reply with quote
technically, no there is not. Without a birth certificate or matching (original) m-code plate, there isn't 100% certainty.
that being said, if the bus is patina/original paint, then one could be reasonably sure its an original 21 window.
drive your split.
turkis-deluxe
Samba Security
turkis-deluxe is offline
PostPosted: Tue Oct 11, 2022 7:44 am    Post subject: Re: *** Advise Needed 21 Window *** Reply with quote
Also look for belly pans to make sure they are original. If they've been removed for some reason look for the main wiring loom will be in a metal tube and not exposed like non-sunroof buses.
Clara Premium Member
Clara is offline
PostPosted: Tue Oct 11, 2022 10:08 am    Post subject: Re: *** Advise Needed 21 Window *** Reply with quote
21 window buses don't have a body number. 1958 and earlier buses have a body number ( behind front seat) which is not the same as a VIN.
The number stamped in the engine compartment is the VIN.
Beginning in the 1965 model year (August 1964), the VIN/chassis number begins with the 2-digit model number, i.e. 21 for Panelvans, 23 for Kombis, etc.
So if the VIN starts with 23, sounds like a kombi with a roof clip.
If the VIN starts with 24 or 25, the VIN is for a deluxe, but that does not tell you if it was a sunroof or tin top deluxe.
Also check the VIN tag on the air vent and make sure it matches. I did once get a clipped 21 window with a different VIN in the engine compartment to the VIN tag on the fresh air vent.
read this:
https://www.thesamba.com/vw/archives/info/id.php
x2 on og paint making it easier to tell.
J0HN---H
J0HN---H is offline
PostPosted: Tue Oct 11, 2022 10:39 am    Post subject: Re: *** Advise Needed 21 Window *** Reply with quote
Thank you, this is very informative and helpful.
