vanagon_fan_again Samba Member
Joined: October 20, 2009 Posts: 157 Location: Paoli, Indiana
Posted: Thu Mar 10, 2011 11:01 am Post subject: Alternator Wire back to starter- Too Thick for starter stud? |
If any of you have been following my ongoing starter problem threads- Found the sum of all my problems. A self tapping screw I foolishly used on my floor went into the red/black wire that tells the starter to start. Was hard to find, but I'm sure thats what has given me so much trouble.
Anyways- Got a new starter today, took the last warrantied one in because I'm fairly sure the solenoid wasnt working. New ones pretty much the same but different- The stud for the batt cable/alt wire is a good bit shorter.
I'm just assuming everyone has the same thick alternator return connector, if not-
Now my question is- Would it be alright to cut this large connector off and put a simple flat one on? Or would that mess up the charging circuit? I really dont want to take another starter back to the FLAPS for the 3rd time, but if it has to have that special end on it I guess thats what I'll have to do. _________________ -JENYVAN-
1989 Vanagon GL 2.1 Automatic. Metallic Blueeee. |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8422 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Thu Mar 10, 2011 11:08 am Post subject: |
Your electrical connection comes on the mating surfaces of the connector, so you don't need that thick old thing.
Cut it, crimp & solder the "flatter" replacement & get on with it...
Happy Trails! _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6344 Location: Portland OR
Posted: Thu Mar 10, 2011 11:28 am Post subject: |
The mass of the connector also absorbs heat though. I'm wondering if for some reason that is needed on that particular connection. It's at a point where you are getting a very high amperage distributed to the entire vehicle. A smaller connection will heat up more. Just a thought. _________________ 89 Westy 2.1 Auto |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15381 Location: Syracuse, NY
Posted: Thu Mar 10, 2011 11:29 am Post subject: |
Indeed that's a wiring upgrade for 85+ (?) Vanagons
I clipped our and soldered/crimped a heavy Ring terminal (any FLAPS/Marine store) to make that connection when I switched mom's Automatic starter($150) for a 76-79 bay automatic starter ($50) with the shorter solenoid stud.
*note 76-79 Bay AT starters are LONGER (+more hp)then a vanagon and some adjustment of the throttle rod/kickdown rod was necessary to reach around the new motor.
$50 Bay AT starters are available via NAPA & Pepboys. _________________
Abscate wrote: |
