2BOLLOX Samba Member
Posted: Mon Oct 21, 2013 8:28 am Post subject: Driver seat removal/ quick cheat? |
Hi,
Is there a short cut to removing the drivers seat to get to the battery?
Got to get to the battery turning part is in the way.
Any help would be great!
Thanks for your time! _________________ VANAGON 1.9 SEA TURTAL
R32
R1100RS
NORTHERN MARINE 55 |
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1509 Location: Deep South of the Great White North
Posted: Mon Oct 21, 2013 8:32 am Post subject: |
Mornin'
Bentley 72.2
It is written. (With pictures)
Good Luck _________________ 1988 Vanagon
The most important part in every vehicle is the nut behind the wheel...... |
OddN Samba Member
Joined: August 19, 2010 Posts: 690 Location: Northern Norway
Posted: Mon Oct 21, 2013 8:33 am Post subject: |
If this is a Westy swiveling front seat you should be able to get to the battery just by turning the seat facing rearward. _________________ 1991 VW Multivan syncro 1,9 TD |
Summers420us Samba Member
Joined: June 14, 2010 Posts: 759 Location: Amissville, Virginia
Posted: Mon Oct 21, 2013 8:39 am Post subject: |
In my 88, I need to slide the seat all the way forward. Then I have to swivel the seat just a little each way to get the corners of the battery cover up one at a time.
Remeber that the lid on this side is hindged. _________________ 1997 EVC
1988 2WD Westfalia with OE 2.1 (R.I.P.) |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6344 Location: Portland OR
Posted: Mon Oct 21, 2013 8:45 am Post subject: |
The drivers seat in a westy doesn't swivel 180. You need to slide it forward toward the steering wheel and release the catch to take the seat completely out. Then you can swivel the base without the seat and remove the battery. _________________ 89 Westy 2.1 Auto |
Posted: Mon Oct 21, 2013 9:50 am Post subject: |
Great stuff thank you guys!!! _________________ VANAGON 1.9 SEA TURTAL
R32
R1100RS
