torque converter question
allsierra123
allsierra123 is offline
PostPosted: Sat May 30, 2009 12:22 pm    Post subject: torque converter question Reply with quote
I am having trouble getting it to move to line up the bolt holes. The tranny and engine are mated togther in the van, Do I need to put it in nuetral or have the rear wheels in the air? Looked around online couldnt find the answer.
95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
91 Vanagon GL. 1.9TD Conversion Sold
81 Vw rabbit 1.6 Diesel. Sold
mike boland Premium Member
mike boland is offline
PostPosted: Sat May 30, 2009 12:57 pm    Post subject: Re: torque converter question Reply with quote
put it in neutral, make sure your wheels are blocked. you don't want it to roll. put a socket & ratchet with short extension on the crankshaft pulley bolt If I recall correctly it is a 36MM. turn engine over by hand watch for bolts to line up in hole on case. there are 3 bolts. break first bolt loose, but do not remove... move on to next bolt break it loose then do last one, then go on back to other two bolts and remove those. It's nice to bag N tag your parts too..
allsierra123
PostPosted: Sat May 30, 2009 1:01 pm    Post subject: Reply with quote
OK would I do that in the reverse order for reinstall?
PostPosted: Tue Jun 02, 2009 12:43 pm    Post subject: Reply with quote
yes, you would...
Wildthings
Wildthings is offline
PostPosted: Tue Jun 02, 2009 1:01 pm    Post subject: Reply with quote
The torque converter should spin freely against the flex plate, the transmission does not need to be in neutral, park, or any gear, makes no difference. If it does not spin freely I would be concerned you didn't have the shafts splined correctly before you put everything is place.
allsierra123
PostPosted: Tue Jun 02, 2009 4:21 pm    Post subject: Reply with quote
It was spinning I just doing it right,
