Schnitzelfuss Samba Member
Joined: September 18, 2024 Posts: 182 Location: North Alabama
Posted: Mon Aug 18, 2025 12:29 pm Post subject: Torsion bar lands and grooves inside the swing axle |
| Don’t forget to inspect and clean Subject receptacles in the axle casting if you ever pull your torsion bars out. Mine were horrible. Looked like thousand year old underwater cave entrances- so bad I could barely make out the lands and grooves. Rigged a circular wire brush onto the end of a painters pole and manually “bore brushed” them until they looked much better, then used the torsion bars kind of like a thread tap, working them in and out with a cleaning solvent until all the gunk was gone from the grooves in there. |
