frig and battery
liwesty
liwesty is offline
PostPosted: Fri Jun 05, 2009 12:09 pm    Post subject: frig and battery Reply with quote
i have an 86 westy and only 1 battery if the frig is on dc power does it still draw power when the ignition is off
Sodo
Sodo is offline
PostPosted: Fri Jun 05, 2009 12:17 pm    Post subject: Reply with quote
This is confusing for everyone. I'll make it more complicated, then try to simplify it.
The Dometic never draws from the battery at all.
And it does NOT draw from the battery when ignition is off.
It ONLY draws from the battery when the engine is ACTUALLY running.
The only time it ever draws 12v is if the Alternator is putting out an excess of 12v (and to have that condition the engine must be spinning).
SIMPLIFIED: The Dometic will draw 12v (thus operate) only when the engine is running.
Read this: (Reefer Madness on vanagon.com) http://www.vanagon.com/info/articles/Refrigerator/Reefer_Madness.htm#12Volt
....KTMs, GasGas, SPOT mtb
Dogpilot
Dogpilot is offline
PostPosted: Fri Jun 05, 2009 12:40 pm    Post subject: Reply with quote
There is one caveat. If the relay and Aux battery are installed, many of the relay mods allow powering the reefer from the Aux. It just depends which of the hundreds of ways to do this it has been set up. I have personally killed an Aux battery with the 12 Volt position and my lack of useful neurons.
But yes, the starting battery is isolated from the reefer with the standard wiring, unmolested, installed. A quick test at the little black fuse box with a meter will show you what is powered , when. Not a bad thing to do, as the wiring may have been attacked by more than one industrious previous owner.
Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G
Points Mean Prizes
Points Mean Prizes is offline
PostPosted: Fri Jun 05, 2009 1:37 pm    Post subject: Reply with quote
I don't know if this is the same question but I have just got my first Westy, it's an '81, and I noticed that the fridge works on mains and on gas but not on battery. Is this why and how can I check? I have a leisure battery also.
mightyart
mightyart is offline
PostPosted: Fri Jun 05, 2009 1:53 pm    Post subject: Reply with quote
Next time you go for a drive turn the reefer to 12 volt, when you stop, see if the fridge is colder.
crazyvwvanman
crazyvwvanman is offline
PostPosted: Fri Jun 05, 2009 3:22 pm    Post subject: Reply with quote
Since you have an early Westy you have a different electrical layout for the fridge 12 volt and kitchen 12 volt. You still have a fridge relay that allows the fridge to run on 12 volts only when the engine is running but your relay is not easily accessible and you don't have a separate fuse on the output side of it.
Mark
Vanagon Nut
Vanagon Nut is offline
PostPosted: Fri Jun 05, 2009 3:33 pm    Post subject: Reply with quote
Mark
Pic of my Dometic 182A out of my '81. "Fridge" relay shown at rear L of center
1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN
Points Mean Prizes
PostPosted: Fri Jun 05, 2009 4:02 pm    Post subject: Reply with quote
thanks for the replies but the pic isn't showing up.
Vanagon Nut
PostPosted: Fri Jun 05, 2009 4:16 pm    Post subject: Reply with quote
Well that's just goofy! Smile
Maybe picasaweb changes the link to it's "larger view". Which I sent.
Smaller pic below. More Dometic pics. (smaller pic can be enlarged)
http://picasaweb.google.com/musomuso/DometicPics?authkey=Gv1sRgCOn8wqShjI200QE#
(VW Gas I4)
VE7TBN
