DubKru Samba Member
Posted: Mon Jun 08, 2009 8:36 pm Post subject: Type 4 Rod Bushing Clearance..? |
What is the rod clearance in the wrist pin bushing? I got my rods back and they seem to have a little wiggle. How should it feel?
Robbie _________________ 2L, Raby cam, HAM Heads, Mallory, Dual Dell 40's, Porsche discs, Fuchs (Colored matched not to my bus),tunin' the crap out of it, slammed on Wagenswest suspension.
Polish Rifle wrote: |
I like to take care of my engine and find a nice speed to cruise in on my bus, but sometimes.....you just get in the mood to run the piece of crap into the ground. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23109 Location: Oklahoma City
Posted: Tue Jun 09, 2009 4:36 am Post subject: |
At room temp of about 72-75F....it should be a smooth push fit. Holding the rod in both hands....and using both thumbs...moderate pressure. No wiggle whatsoever. Without straining it should take a couple seconds to push the pin in. Ray |
germansupplyscott Samba Member
Posted: Tue Jun 09, 2009 6:16 am Post subject: Re: Type 4 Rod Bushing Clearance..? |
DubKru wrote: |
Robbie |
ray's description above is very good.
did you send the machine shop a pin when they machined the rods? is it a new pin or a used one? _________________ SL |
DubKru Samba Member
Posted: Tue Jun 09, 2009 7:45 am Post subject: |
New pin. I figured it shouldn't have that much slack... _________________ 2L, Raby cam, HAM Heads, Mallory, Dual Dell 40's, Porsche discs, Fuchs (Colored matched not to my bus),tunin' the crap out of it, slammed on Wagenswest suspension.
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Tue Jun 09, 2009 8:23 am Post subject: |
DubKru wrote: |
New pin. I figured it shouldn't have that much slack... |
New or used wrist pins? |
Bleyseng Samba Member
Posted: Tue Jun 09, 2009 9:19 am Post subject: Re: Type 4 Rod Bushing Clearance..? |
[quote="DubKru"]What is the rod clearance in the wrist pin bushing? I got my rods back and they seem to have a little wiggle. How should it feel?
Robbie[/quote.
they shouldn't have any "wiggle" as they should smoothly push in without much effort.
take em back! and have a new pin with you. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
DubKru Samba Member
Posted: Tue Jun 09, 2009 11:52 am Post subject: |
The new pin is at the machinist with the rods.
Is "friction fit" the proper terms I need to be using or are there any numbers to tell him? _________________ 2L, Raby cam, HAM Heads, Mallory, Dual Dell 40's, Porsche discs, Fuchs (Colored matched not to my bus),tunin' the crap out of it, slammed on Wagenswest suspension.
Posted: Tue Jun 09, 2009 12:09 pm Post subject: |
the VW engine manual says, to quote directly
Quote: |
at room temperature the piston pin should be a push fit in a new bush |
DubKru Samba Member
Posted: Thu Jun 11, 2009 11:19 am Post subject: |
THANKS!
I got the shop to go back and refit new bushes. The fit just didn't seem right and I wanted to make sure it wasn't just me. _________________ 2L, Raby cam, HAM Heads, Mallory, Dual Dell 40's, Porsche discs, Fuchs (Colored matched not to my bus),tunin' the crap out of it, slammed on Wagenswest suspension.
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42439 Location: at the beach
Posted: Thu Jun 11, 2009 1:13 pm Post subject: |
DubKru - that was a wise decision. The description Scott and Ray gave were accurate. Lightly oiled, at room temp there should be a little drag as one is pushed through but neither play nor binding. The rod should also be checked for straightness at the same time. In an ideal situation you want to do the following while your rods are out.
*check for straightness
*clean them (glass bead or shotpeen)
*verify the thrust surfaces are within tolerance (big end width)
*resize the big end, making sure the measuring after resizing goes all the way around and doesn't pinch across the cap.
*lightly clean up the thrust surfaces
*resize the small end (wrist pin end) requires new bushings usually
*verify still straight
*check the weight of the rods and pins to balance them
*check the piston weight to balance them
*test the bearing fit with plastigauge before final assembly. use the old nuts for this then use new nuts on the final assembly. Verify the thrust clearances are correct on the crank. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Joey Samba Member
Joined: August 12, 2005 Posts: 5375 Location: Nova Scotia - Canada
Posted: Fri Jan 29, 2010 7:39 am Post subject: |
So, without oil, should the pin drop right through the bushing or should there be resistance? _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Posted: Fri Jan 29, 2010 7:44 am Post subject: |
Joey wrote: |
So, without oil, should the pin drop right through the bushing or should there be resistance? |
no, not at all. the pin should not be passed through the honed bushing without oil, for one thing. but the resistance would be a bit greater if the pin was slid though the bush dry. _________________ SL |
Desertbusman Samba Member
Posted: Fri Jan 29, 2010 8:38 am Post subject: |
Joey wrote: |
should the pin drop right through the bushing |
A drop thru fit is not a push fit  _________________ 71 Superbug
71 Westy |
Joey Samba Member
Posted: Fri Jan 29, 2010 9:07 am Post subject: |
Desertbusman wrote: |
Joey wrote: |
A drop thru fit is not a push fit  |
They easily drop through without oil, but don't with oil. With oil they will drop through but takes a few seconds. Without oil there is slop, with oil slop is still there but not as much. No good? _________________ Joey
Posted: Fri Jan 29, 2010 9:31 am Post subject: |
i think the bushes need to be replaced if the pin will slide through under any circumstances. _________________ SL |
Joey Samba Member
Posted: Fri Jan 29, 2010 9:42 am Post subject: |
I agree. I just have to convince the machine shop that just did them that they are wrong. _________________ Joey
Posted: Fri Jan 29, 2010 11:01 am Post subject: |
Joey wrote: |
I agree. I just have to convince the machine shop that just did them that they are wrong. |
OH.
i always sent a pin and a note that i want them "snug". they can always be honed to fit looser. _________________ SL |
Posted: Fri Jan 29, 2010 11:49 am Post subject: |
The other option is only let a recognized experienced top notch VW engine builder and shop to touch the parts. Additionally, VW has published all the pertenant specs. They are there for a purpose. If you arn't following the good published info it's best not to touch the engine. _________________ 71 Superbug
71 Westy |
Joey Samba Member
Posted: Fri Jan 29, 2010 2:07 pm Post subject: |
The other option is only let a recognized experienced top notch VW engine builder and shop to touch the parts. Additionally, VW has published all the pertenant specs. They are there for a purpose. If you arn't following the good published info it's best not to touch the engine. |
Unlike the southwest where there's a VW shop in every town, here there isn't any. German Supply would probably be the closest (if you want to call 1063 miles close). This shop has done them for me a few times before (Sept. was the last time) and they were fine so I don't know what happened this time... maybe a different employee... I dunno. I gave them the specs from the Bentley. _________________ Joey
Posted: Fri Jan 29, 2010 2:13 pm Post subject: |
Joey wrote: |
Unlike the southwest where there's a VW shop in every town, here there isn't any. |
i agree with this, it isn't easy to find machine or repair shops in canada with aircooled experience. _________________ SL |
