rear suspension bolt sizes
vt70vw
vt70vw is offline
PostPosted: Wed Jun 10, 2009 4:00 am    Post subject: rear suspension bolt sizes Reply with quote
ok just trying to figure out what size the socket head is for the diagonal arm ? i see a few of you have replaced the bushings so must know what size aand maybe were to get it . thanks
Cusser
Cusser is offline
PostPosted: Wed Jun 10, 2009 6:49 am    Post subject: Reply with quote
Isn't it 17mm allen wrench? Bear with me if I'm wrong, I haven't replaced one in over 25 years.
runamoc Premium Member
runamoc is offline
PostPosted: Wed Jun 10, 2009 6:50 am    Post subject: Reply with quote
It's a 17mm allen 'wrench'. Look around the lip of the frame piece for a indention that holds the bolt from moving. Punch it back and the bolt should unscrew right out.
vt70vw
vt70vw is offline
PostPosted: Wed Jun 10, 2009 7:07 am    Post subject: huh Reply with quote
funny thing is i have one did not fit maybe i have to tap it a little with hammer .
vt70vw
vt70vw is offline
PostPosted: Wed Jun 10, 2009 7:19 am    Post subject: jackpot Reply with quote
yippy works . it came lose very exited i hinking it was going to break and then big trouble . Next ? what is best place to get 12 point socket head for CV shafts ?and what size is it ?
runamoc is offline
PostPosted: Wed Jun 10, 2009 10:45 am    Post subject: Reply with quote
very exited
You won't be after getting the old bushing out. Wink
Don't forget that those big washers go together, side by side, and not on each side of the bushing.
