Chevy or VW journals?
veedubnut
veedubnut is offline
PostPosted: Mon Jul 06, 2009 2:24 pm    Post subject: Chevy or VW journals? Reply with quote
I see these options alot when looking at crankshafts. What's the difference and why?
dubkrzy
dubkrzy is offline
PostPosted: Mon Jul 06, 2009 4:44 pm    Post subject: Reply with quote
Chevy rod journals are smaller, so less clearancing is involved.
vwracerdave wrote:
always modify the cheapest part and never modify the most expensive part.
Glenn wrote:
Sure... you can take a grinder to them. You can also use an adjustable wrench to assemble it.
Jake Raby wrote:
That looks like Tom Jones
vwracerdave
vwracerdave is offline
PostPosted: Mon Jul 06, 2009 5:03 pm    Post subject: Reply with quote
Use VW journals for 78mm and smaller cranks. Use Chevy journals for 82mm and larger.
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Mon Jul 06, 2009 5:21 pm    Post subject: Reply with quote
No hard and fast rule to it, Dave. I have a VW 82 crank with stock rods and one of those pre-clearanced cases, it dropped right in with plenty of room to spare. Personally, I'd rather have the additional journal overlap on the longer cranks, it adds life.
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
dubkrzy
dubkrzy is offline
PostPosted: Mon Jul 06, 2009 5:29 pm    Post subject: Reply with quote
I also have an 82mm crank and pre-clearanced case with stock clearanced rods, but I still had to clearance the cam.
Probably wouldn't have had to clearance the cam if I had used chevy journals.
gonebuggy
gonebuggy is offline
PostPosted: Mon Jul 06, 2009 7:16 pm    Post subject: Reply with quote
Total agreement.
