vwtaiwan Samba Member
Posted: Fri Jun 26, 2009 12:15 am Post subject: Kadron strange problem!! |
During our DYNO Test, there was an unusual problem happen to me, the engine ran great and suddenly lost power. we find out right hand side AFR meter was way too lean. There must be something wrong on the carburetor. So, we remove the right side kadron. ok
we found out there was a problem, the fuel did not go through main jet, we use pressure air blow through main jet, and even no air come out from air correction jet!
So we start to heat up the air correction jet area, and remove air jet,
Guess what!! the bottom tube was lost and block the fuel rail. So we used really high pressure air blow through main jet(main jet removed).
Finally we had the bottom piece, and it cracked on the side, and fall down and block entire fuel rail....
after soldering up fixing,
start to dyno again,
madmike Samba Member
Joined: July 11, 2005 Posts: 5300 Location: Atlanta,Michigan
Posted: Fri Jun 26, 2009 5:25 am Post subject: |
K-duds are "NOT" a performance carb!! there a replacement carb for buses and the linkage sux,I've removed alot of these things and replaced them with a single Weber and the guys can't tell the diff in preformance other then relieablity ,If you want Duals+Performance get some 40IDF's then do a pull on the Dyno I've never had to solder up Webers Madmike _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7542 Location: Whittier,CA
Posted: Fri Jun 26, 2009 10:38 am Post subject: |
| That was a freak thing. Hope it all works out for you. Good luck! |
Michael Fischer Samba Member
Joined: April 20, 2004 Posts: 1585 Location: Salem, OR
Posted: Fri Jun 26, 2009 11:08 am Post subject: |
| Kadrons are good carbs. |
nsracing Samba Member
Posted: Fri Jun 26, 2009 12:22 pm Post subject: |
WTF is that "squealing sound?"
Nice pull on the dyno.  |
Posted: Fri Jun 26, 2009 1:10 pm Post subject: |
| nsracing wrote: |
| WTF is that "squealing sound?" |
Straight cuts or the fan rubbing the shroud???  |
