fclmscott Samba Member
Posted: Sat Jun 06, 2009 3:15 pm Post subject: Tranny question please |
Hey guys
Need a little input here. Got a buggy running a 2332 with a stock three rib bus tranny. Turns about 4000 rpm when going down the highway. Also running 33" tires. What I want to do is put a type 1 tranny back in it geared to give about 2700 in fourth on the freeway. What do ya'll recommend and will the starter and axles interchange? Any other things I should know?
Thanks in advance. |
dubkrzy Samba Member
Joined: July 02, 2006 Posts: 485 Location: One step behind
Posted: Sat Jun 06, 2009 6:09 pm Post subject: |
Call Rancho or AZ transaxle exchange, they will set you up right  _________________
| vwracerdave wrote: |
| always modify the cheapest part and never modify the most expensive part. |
| Glenn wrote: |
| Sure... you can take a grinder to them. You can also use an adjustable wrench to assemble it. |
| Jake Raby wrote: |
| That looks like Tom Jones |
sturgeongeneral Samba Member
Joined: June 23, 2005 Posts: 2460 Location: Sacramento, California
Posted: Sat Jun 06, 2009 8:09 pm Post subject: |
Change to a 4.12 ring and pinion gear ratio and drop those rpms! _________________ Street legal fiberglass rocket ship
2005 Lotus Elise supercharged
1974 Chevy Corvette
My fiberglass car collection!
In honor of bowtie56jw:Another victim of the nasty "C" Praying for ya Jeff!
My exwife said if I towed home one more bug she would leave me. You know, every once in a while I miss her |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17685 Location: Left coast, Canada
Posted: Sat Jun 06, 2009 11:13 pm Post subject: Re: Tranny question please |
| fclmscott wrote: |
At what speed? _________________
| overheard at the portland Swap Meet... wrote: |
| ..... a steering wheel made from a mastadon tusk..... |
Posted: Sun Jun 07, 2009 7:21 pm Post subject: |
Guess that would have helped. 70mph and tach reads about 4000. 3 rib aka002 and best I can tell it has the 5.38 R&P in it and a .82 fourth. Anybody got an idea as to what it would cost to have a new R&P installed? Debating on either going to a type 1 freeway flyer for highway or replacing the R&P with a different on. MOstly drive on the street but occasionally take it to the dunes. AS it is I can climb in second gear without any problems. Do ya'll think it would be a problem if I were to change the R&P? In other words how much do you think it would affect the ratio overall for 1st and 2nd?
I will also give them a call on monday.
Thanks |
donson Samba Member
Posted: Fri Jun 26, 2009 1:07 pm Post subject: Trans |
| You can change the trans from the 5.38 you have now to a 4.96 or pull the 002 and install an 091 with a 4.57 rig and pinion. 4th gear can also be changed from the stock .82 to a .70 or .77 Weddle gear. Out this ratios in one of the many gear calculators in the internet with the height of your rear tire and you see the effect. Hope that helps! Don |
