bus depot P & S kit
typicaldeadhead420
typicaldeadhead420 is offline
PostPosted: Thu Jul 09, 2009 6:56 pm    Post subject: bus depot P & S kit Reply with quote
recently made an order through aircooled for P & S since they are out of stock and so is there supplier i am going to alternative options bus depot has a set for 479
http://busdepot.com/details.jsp?partnumber=029198075GR so im thinking about buying these maybe which looks pretty good any help or adive would really be appreciated
Blaubus
Blaubus is offline
PostPosted: Thu Jul 09, 2009 8:00 pm    Post subject: Reply with quote
Kolbies are real good, but i always opt for NOS brazilian at a cheaper price. while cofap makes shit for dampers and shocks, they used to make a very high quality P/C set- the pistons even carried the KS logo on the inside Shocked heres an ad i found for that very item:
http://www.thesamba.com/vw/classifieds/detail.php?id=632651
assuming your engine is running cool, oil choice and cleanliness is the main determinant of piston life. i have personally run the old cofap 80K without even wiping out the machine tool marks (changing Kendall 20W oil every 2500 mi.) you should spend some of the extra 300 on several cases of brad penn 10W-30 IMO. this would make more difference than the Kolbies would.
vw72hippy
vw72hippy is offline
PostPosted: Fri Jul 10, 2009 4:33 am    Post subject: Reply with quote
where can you find the nOS brazilian P&Cs you were mentioning? what makes one piston and cylinder kit cost more than another? i want the best for the 2.0L motor.
Marv [UK]
Marv [UK] is offline
PostPosted: Fri Jul 10, 2009 5:32 am    Post subject: Reply with quote
Kolbenshmidt still make type 4 cylinders and pistons
(EDITED OUT CRAP LINK)
Kolbenshmidt bearings are still being made also
Sometimes parts in europe are easier to get hold of.... sometimes, but not very often Very Happy
Marv [UK]
PostPosted: Fri Jul 10, 2009 5:36 am    Post subject: Reply with quote
dang frames!!!!
Just go here and have a look around
http://www.ms-motor-service.com
all kolbenshmidt or pierburg spare parts
Randy in Maine
Randy in Maine is offline
PostPosted: Fri Jul 10, 2009 5:42 am    Post subject: Reply with quote
Suggestion:
Here is where you can find the Mahle P&C:
http://www.aircooledtechnology.com/store/product.php?productid=16893&cat=275&page=1
Or these:
http://www.aircooledtechnology.com/store/product.php?productid=16165&cat=275&page=1
I would think that either of those would work well in a pretty much stock rebuild as you are likley only to see <5000 RPMs on this engine. All buses need the dished pistons. I would suggest that you get them balanced to a couple of grams or less while you are doing it so that they are all about the same mass.
