Vw4x4 Samba Member
Joined: May 18, 2004 Posts: 211 Location: SUNNY CALIFORNIA
Posted: Sun Dec 05, 2004 8:35 am Post subject: Front bumper installation |
I was trying to install the front bumper and I stripped two threads in the driver's side. Any suggestion how to fix without welding it on... |
bljones Resident Wit
Joined: February 08, 2002 Posts: 2377 Location: ontario canada
Posted: Sun Dec 05, 2004 8:45 am Post subject: |
if it's just cross threaded, get a tap and die set and chase the threads with the right size tap. if it's really messed up, carefully drill it out and tap it one size larger, and use larger bolts. _________________ OG JHC
Author of Original Rant #1
"It stingd itself to dead... now that is control on you"
2% |
kubelmann Samba Member
Posted: Sun Jan 02, 2005 10:26 pm Post subject: |
The front bumper on a Thing basically attaches to the body with nuts that are welded on the inside of the mount. You actually have a few options to solve a stripped set of threads. The easiest and perhaps best solution is as was suggested in the last post. Get a tap of the correct size and gently rethread the nut. If that fails get a tap of the next larger size and cut those threads. If both of these fail, you can drill through and bolt the bumper through the body. This last solutiion is not an acceptable soltution for show cars or an intended perfect restoration. K-mann |
suntour Samba Member
Joined: November 25, 2004 Posts: 443 Location: Woodinville, WA
Posted: Sun Jan 02, 2005 10:29 pm Post subject: |
If there is enough metal left you can also use a heli-coil, that way you can still use the right size bolt if it really matters… |
vw1968 Samba Member
Posted: Tue Jan 04, 2011 3:54 pm Post subject: front bumper |
does anyone know the size of the 4 bolts that hold the bumper???? |
uberautowerks Samba Member
Joined: October 17, 2005 Posts: 1600 Location: Longmont Co
Posted: Tue Jan 04, 2011 4:55 pm Post subject: |
M10x1.5 20mm long and takes a 17mm wrench _________________ --- The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at and repair.
- Douglas Adams -
'74 Thing (White)
'71 Single cab (White too)
'70 Weekender (White three)
'05 Evolution VIII (White also!!!)
'68 F-250 (White over black) |
74 Thing Samba Member
Posted: Wed Jan 05, 2011 10:55 am Post subject: Re: Front bumper installation |
Vw4x4 wrote: |
74Thing... Those are cool but are going to require welding _________________ --- The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at and repair.
- Douglas Adams -
'74 Thing (White)
