Distributor cap wire order
pmartini777
pmartini777 is offline
PostPosted: Tue Jul 28, 2009 12:21 am    Post subject: Distributor cap wire order Reply with quote
I know this must be a REALLY stupid question but in replacing the manifold I removed the plug wires from the distributor and did not mark them. I have the fire order at the spark plugs as its noted on the tin but now where can I find a diagram with which plug wire goes to each location on the distributor cap. Does someone have a diagram or let me know. Consider I am facing the engine (ie. rear left =1, etc). It would a huge help. Better yet a picture. I feel pretty dumb right now!
pmartini777
PostPosted: Tue Jul 28, 2009 12:22 am    Post subject: Reply with quote
forgot, its a 1959 36 hp original engine no mods but dont think that matters.
FINEGERMANSTEEL
FINEGERMANSTEEL is offline
PostPosted: Tue Jul 28, 2009 1:05 am    Post subject: Reply with quote
#1 cylinder is right side, front
#2 cylinder is right side, rear
#3 cylinder is left side, front
#4 cylinder is left side, rear
firing order is 1 4 3 2 clockwise.#1 plug wire should go closet to you on distributor cap.and go clockwise.take #4 next and so on.tried simple explination.but theres always some to explain it easier...take off dist.cap and turn motor crank(big pulley) till your top dead center.(TDC) crank till the rotor points little mark on dist..thats number one
hope it help Wink
--MovedFromSeattleArea2SpokaneLate2021.
NowMoscow Id-----------
60 bus mango
61 bug. low n slow1200
65 bus project_sadly sold it
66 squareback project..in process..kinda
--CultWagen--slowlow61
FINEGERMANSTEEL
PostPosted: Tue Jul 28, 2009 1:16 am    Post subject: Reply with quote
http://www.reluctantmechanic.com/images/ht-leads-firing-order-big.jpg pictures are always better
60 bus mango
Hammarlund
Hammarlund is offline
PostPosted: Tue Jul 28, 2009 7:38 am    Post subject: Reply with quote
All good advice; but I would add that it is advisable to find the terminal for #1 wire by the notch under the distributor cap, not its relative position; some engines (such as mine) have the distributor drive installed in such a way that the terminal for #1 is quite a few degrees off from the standard factory position.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Jul 28, 2009 7:42 am    Post subject: Reply with quote
Hope this helps.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
pmartini777
PostPosted: Tue Jul 28, 2009 9:42 am    Post subject: Reply with quote
THANKS everyone! I scratched my head for weeks before sucking it up and posting. Was hoping not to look like an idiot. The pics are valuable. Thanks for the advice on TDC. I will start with 1 then use the pics for the rest. Amazing how a forum can combine many heads to create a super brain Smile
Nubby
Nubby is offline
PostPosted: Fri May 20, 2011 11:01 am    Post subject: Reply with quote
It's been so long, I forgot as well... Thx Glen for the pics. I would have messed that one up without it! That's why I love this site..
Mr. 010
Glenn is offline
PostPosted: Fri May 20, 2011 11:36 am    Post subject: Reply with quote
And thank you for searching first.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
