airkooledchris Samba Member
Joined: January 25, 2005 Posts: 2640 Location: Where the pacific ocean meets the redwood forest
Posted: Fri Jul 31, 2009 3:12 pm Post subject: new beetle owner - 67 - new pics all cleaned up! |
So this 67 that was found here in my hometown is officially signed over to me now. I just paid the owner and picked up the title, as well as about 7 boxes of parts.
original lights, distributor, hub caps, replacement (new in box) interior parts, brakes, you name it and it's probably already there. (in boxes, not saying all of the original parts are on the car)
In the end, after seeing all of the parts that actually came with it, it was an amazing deal. There has to be a few hundred bucks worth of new parts in boxes, let alone all of the original to this 67 parts that were stowed away over the years.
It's still sitting over in front of the original owners place for now while I arrange the DMV paperwork, insurance/etc, but the fun officially starts now.
At some point this weekend im going to try and photograph/document all of the spares and originals parts that came with it to see what should be put back on and what's better left alone. (those funky original seatbelt mounts came with it, but appear to be just lap belts and no shoulder restraints - something like that I suppose the replacements are best left in place.)
im finally a beetle owner!
update.
started taking pictures of the spare parts boxes for identification...
Random brackets?
fuel pumps? USA on left, VW in middle, Brasil on right.
exhaust tips? the little sleeves in front of them the PO said might be part of that same setup.
original carb?
original dist?
pass side mirror? there is none there now.
a horn, some sort of rubber bushings and the bottom left appears to be some sort of bumper/antenna mount? _________________
metahacker wrote: |
... i would say that, if it's an option, (edited) not listen to any forum pessimism.. |
Last edited by airkooledchris on Mon Aug 17, 2009 10:00 am; edited 2 times in total |
gondiwindi Samba Member
Joined: December 12, 2006 Posts: 1130 Location: Tampa Bay, FL
Posted: Fri Jul 31, 2009 4:45 pm Post subject: |
Awesome little car! - Congrats on the find.
A bottle of brasso would work wonders on your chrome. Keep the restoration pics coming.  |
Montgomery Samba Member
Joined: August 09, 2008 Posts: 35 Location: NW Arkansas
Posted: Fri Jul 31, 2009 5:07 pm Post subject: |
Very nice, I love that color _________________ 67 Beetle |
Posted: Sun Aug 02, 2009 2:26 pm Post subject: |
I updated the original post with some additional photo's of the box of parts that came with this beetle. any help with identifying/correcting what is shown above is appreciated. _________________
metahacker wrote: |
toyvergnugen Samba Member
Posted: Sun Aug 02, 2009 2:54 pm Post subject: |
Top picture are heater box levers.
Picture with exhaust pee shooters are heater box repair inserts. You use them when the tips from the heater boxes are corroded beyond use. |
6Kabrio7 Samba Member
Joined: July 22, 2006 Posts: 2387 Location: California
Posted: Sun Aug 02, 2009 5:01 pm Post subject: |
post more pictures of the car please  _________________ 67 Convertible July 67 Yukon Yellow
67 Sedan May 67 Zenith blue |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Mon Aug 03, 2009 9:06 am Post subject: |
thanks for the parts ID so far.
I have a few more lots of parts to show....
another chunky bracket that looks similiar to the one with the antenna connection shown above, some misc gaskets, a hard metal line (fuel?), and a really old looking (but in seemingly fantastic shape) old brown dist cap. the contacts on the inside look new.
next is what I think ive heard referenced to as 'J-tubes' - some sort of option to bypass the stock heating system right? along with a new in package replacement antenna.
here is a closer look at that bumper mount bracket from the first pic:
per request, a few more shots of the actual car. some of these showing more of why it was such a killer deal (rust)
metahacker wrote: |
Posted: Mon Aug 03, 2009 6:55 pm Post subject: |
airkooledchris wrote: |
the tubing is vacuum tube from stock distributor to carb. the antenna is stock for 67 onwards. the wide band clamps go between heater boxes and clambshell pieces on muffler. _________________ 1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
Posted: Mon Aug 10, 2009 4:52 pm Post subject: |
update: It runs, drives forward and stops.
the whole brake system needed to be redone, most of which I had in boxes but also needed two rear wheel Cylinders and all of the lines (hard and soft.)
The hard line running under/alongide/whatever the center channel of the bug, for the brakes, had a bunch of tiny holes in it.
new fuel lines, filters, plugs, plug wires, cap, rotor points, brake return spring, master Cylinder Adapter plugs for the master Cyl, 2 brake pressure switches, VC gaskets.....
still needs:
rear tires (cracked all over, probably not safe)
Muffler (one of the tips broke off, it seems way too rusty to do anything to it without it just cracking and breaking.
also a Voltage regulator is needed. It's working for now, but apparently it will go on and off and if the Gen light comes on and stays on I need to replace it then for sure.
any suggestions for exhaust?
it's still too new to me (beetles) and im overwhelmed with the different opinions out there....
more pics and details to follow. I really need to clean it up now. They did an amzing job making the motor compartment look good, but inside its all cobwebs and nastyness. _________________
metahacker wrote: |
Hotrodjrod Samba Member
Joined: January 18, 2009 Posts: 28 Location: Dayton, Oh
Posted: Mon Aug 10, 2009 8:52 pm Post subject: |
Man I wish my 67 were that good! Very nice find.
If you find a rear apron in that box of goodies, please let me know. I'll send you some beer for it
I dunno what it is about the 67 thats so great. I mean, they had a HUGE sales year in 67 on bugs, but the fact that so many things are ONLY 67 is just cool to me.
Enjoy it man! I cant wait to get mine on the road. Its killing me having it sit in the driveway while i go thru all the stuff it needs in our short ohio summers. |
Rusty O'Toole Samba Member
Posted: Mon Aug 10, 2009 9:47 pm Post subject: |
In the last pic of the first post, the rubber bushing with the metal band around it, looks like a new mount for the front sway bar. There should be another metal piece to clamp the open end together, a C shaped piece.
It clamps the sway bar to the lower suspension beam.
They tell me the old brown distributor caps are rare and hard to get now.
Don't throw anything away, you never know what weird metal or plastic thing will turn out to be an irreplaceable part you didn't know you needed.
OK you can throw out the dried up ballpoint pens and McDonald's wrappers but that's all LOL. |
arthurnugen Samba Member
Joined: January 11, 2005 Posts: 3080 Location: The PNW, where "going green" means rolling with moss.
Posted: Tue Aug 11, 2009 12:59 pm Post subject: |
Cool find! Is it just me, or does it look like this car had an engine fire in the past? The scorched decklid and rusty air cleaner seems odd.
Arthur
cdennisg wrote: |
Lawyers don't deserve buses. |
zozo wrote: |
Don't worry too much. You can always trust a lawyer. |
ALWAYS WEAR STEEL-TOE BOOTS IN THE GARAGE!
1965 Bus (Riviera camper)
1972 Bug 'vert
1967 Bug sunroof
1961 Ghia 'vert
1957 DKW 3=6: 3 cylinder 2 stroke! |
Posted: Tue Aug 11, 2009 2:02 pm Post subject: |
it isn't scorched, it was really just that dirty.
the air cleaner actually cleaned up pretty well, it wasn't nearly as rusty as it looks in that pic.
ill take some shots in a few days once I can get it over to the self serv wash place and have at the bottom of the motor/trans with some serious degreaser. _________________
metahacker wrote: |
83_WabbitGTI Samba Member
Joined: December 01, 2006 Posts: 1335 Location: Eagle Point, Oregon
Posted: Tue Aug 11, 2009 2:26 pm Post subject: |
Was that an Oregon or California car? I haven't seen one that rusty around these parts in a long time. Most of it looks like surface rust though. Might have spent it's life on the coast? _________________ 2013-2014 Vice President of SOVW www.sovw.org
"No matter how a VW breaks down.... You can always make it home on Zipties, Ducktape, and JB Weld...."
-Doug Christen, VW Owner
83 Rabbit GTI - 83 Rabbit LS Custom - 63 Westy - 65 Bug - 64 Baja (Herbie's Studly Cousin) - 91 Audi 90 Quattro 20v - 85 Vw Cabby - 84 VW Scirocco - 69 Beetle (Phantasm Bug) - 78 Cabriolet
Need a VW website built? PM me. |
Posted: Mon Aug 17, 2009 9:53 am Post subject: |
yup. it had the same owner from 1968 until now and the original owner for that first year (or just shy of it) was also on the coast. most of that time was in Santa Cruz, the rest of it has been here in Eureka, CA.
turns out though that you can polish a turd. some friends came over and we cleaned the F out of it, installing a bunch of the misc parts that came with it and took it for a few drives....
metahacker wrote: |
Vee Dub Nut Samba Member
Joined: April 25, 2004 Posts: 1095 Location: NW Georgia
Posted: Mon Aug 17, 2009 10:11 am Post subject: |
looking good! _________________ Fightin' Texas Aggie Class of 2006
67 Beetle (1500sp, 1776dp, 1915NA, 1915T fuel injected, 2276NA, 2276T fuel injected, 2084NA, 2056 T4, back to the trusty 1600dp)
74 Transporter (2.0 T4, SOHC EJ25) - Build Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
See all my VW pics on Instagram @ vee_dub_nut |
Posted: Mon Aug 17, 2009 10:24 am Post subject: |
WOW!! That's one nice looking turd!!
That came out really nice man! Guess it was just surface rust??
000 steel wool and Mothers chrome polish work wonders!
Lookin good mang. _________________ 2013-2014 Vice President of SOVW www.sovw.org
Herrbern Samba Member
Joined: May 04, 2008 Posts: 342 Location: Luxembourg, Europe
Posted: Mon Aug 17, 2009 12:02 pm Post subject: |
[quote="arthurnugen"]Cool find! Is it just me, or does it look like this car had an engine fire in the past? The scorched decklid and rusty air cleaner seems odd.
Arthur
[img]http://i258.photobucket.com/albums/hh243/ruckman101/DSC_0139.jpg[/img][/quote]
Lovely bug. But please, clamp those fuel lines. Like on the pictures, it will get fire sooner or later. Replace those old lines with new once and replace the grommet behind the fan shrould where the fuel line comes into the engine compartiment. |
Posted: Mon Aug 17, 2009 12:19 pm Post subject: |
this is how the motor compartment looks now. the shop that got the motor running again replaced the fuel lines amongst other things, but I don't see any clamps, and will have to check that grommet behind the fan shroud...
so just throw some fuel clamps on the two lines coming to/from the fuel pump and on either side of the two fuel filters as seen in the pic? 6 clamps total ? _________________
metahacker wrote: |
