iamdonquixote Samba Member
Joined: January 28, 2003 Posts: 2087 Location: M*ssholia
Posted: Tue Aug 04, 2009 5:45 am Post subject: Spring plate bolt questions |
Needed to remove my transmission.
Did many searches
One bolt hole was stripped. Couldn't get a timesert so used helicoil, yuk, seemed to work though.
Questions:
1) can I replace the helicoil with a timesert later on?
2) what washers are used for bolts, I noticed a lock plate in a pic? where can they be found?
3) what is the torque spec? ( don't have a Bentley handy right now )
thanks |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10804 Location: the past
Posted: Tue Aug 04, 2009 5:49 am Post subject: Re: spring plate bolt questions |
| iamdonquixote wrote: |
Did many searches
Questions:
thanks |
1) i have not tried to replace a helicoil with a timesert. i guess it could be done. a helicoil is a coil and could probably be "uncoiled", a timesert is a solid insert and they say they can be drilled out if necessary.
2) http://www.thesamba.com/vw/classifieds/detail.php?id=825680
or if you want original style lock plates, WW reproduces them: http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211598600
they also sell bolts, but i don't know what grade they are: http://wolfsburgwest.com/cart/DetailsList.cfm?ID=N101191
3) torque spec is 100-120Nm (or 72-86 ft. lbs) and are tightened in this sequence:
Clara  Samba Member
Posted: Tue Aug 04, 2009 6:04 am Post subject: Re: spring plate bolt questions |
The earlier buses came with 17mm heads on the RGB bolts
the later have 19mm.
I believe the change was when they dropped the lock plates in favor of the washers.
Always use a tap to clean out the threads in the RGB, so you can thread them in by hand. Avoid crossthreading. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Tue Aug 04, 2009 1:05 pm Post subject: |
The spring plate bolts that I have removed from the big stub axle RGBs have been longer than the earlier ones. Someone said that, because the lock washers were thicker than the lock plates, they used longer bolts. Is that true? _________________ Don't worry; be happy. (Baba) |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15489 Location: Casa de Oro, California
Posted: Tue Aug 04, 2009 6:08 pm Post subject: |
| I'm tending to agree with you. I wonder if the parts list shows a difference. I like the longer ones for Bays and then I chase a bottoming tap on down and use the thick ass lock washers when I can find them. |
Posted: Tue Aug 04, 2009 6:23 pm Post subject: |
the replacement washers are not lock washers, they are spring washers. the spring washers are thinner than a lock washer. the spring washers are about the same thickness as an original lock plate.
the part number, in the parts book, is N 10 199 1 Bolt, hex. head M 12 X 1.5 X 25 - Spring plate mounting from chassis No. 20 117 902
i've taken out plenty of "early" bolts and "late" bolts (whatever), they are 25mm in length.
mr. warehouse Samba Member
Joined: February 27, 2001 Posts: 5002 Location: Nor Cal 707
Posted: Tue Aug 04, 2009 6:47 pm Post subject: |
| If anyone needs OG bolts in 17mm or 19mm heads, I have literally 10 coffee cans full of them at my shop. |
BarryL  Samba Member
Posted: Wed Aug 05, 2009 7:03 am Post subject: |
| Do you have a pic of a Bay one and its washer? |
Posted: Wed Aug 05, 2009 9:41 am Post subject: |
| BarryL wrote: |
pics of a bay's what? |
BarryL  Samba Member
Posted: Wed Aug 05, 2009 7:31 pm Post subject: |
| The Bay springplate-to-bearing housing bolt that is similar. I couldn't look it up on the parts website as it only goes to '67. It uses a spring washer but with a thick lock washer it will go all the way into a RGB. Or nevermind as it doesn't actually pertain. |
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9016 Location: Portland, OR
Posted: Thu Aug 06, 2009 9:49 am Post subject: |
| Threads like this remind me of how much the use of anti-seize has changed my life. I should devise a little belt holster to carry it around the shop with me, I use it that much. |
sventinker Samba Member
Joined: June 10, 2009 Posts: 1481 Location: the sandbox
Posted: Wed Jan 27, 2010 11:40 pm Post subject: |
the use of anti seize changes torque specs be careful you can easily over tighten a bolt when used I prefer to chase the threads wit a tap and visually inspect or replace the bolts. Once torqued water shouldn't be reaching the threads to cause a problem _________________ April 3rd 62 standard mgr/pw
374 North American equipment
Includes 6 popouts
025 Safety belts
195 Adjustable bench seat/backrest (until 1963)
| dawerks wrote: |
| Perfection only comes with delusion. |
http://www.oacdp.org/ |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9831 Location: Exit 7, New Jersey
Posted: Thu Jan 28, 2010 6:33 am Post subject: |
| sventinker wrote: |
| the use of anti seize changes torque specs |
Source for this info, please?
I've been using the copper based anti-seize for thirty years, never a problem, quite the opposite. _________________ Founder and Chairman Emeritus, ECMSAS
| BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
| Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all!  |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3447 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Thu Jan 28, 2010 9:39 am Post subject: |
| j.pickens wrote: |
| sventinker wrote: |
| MDMetrics wrote: |
| Antiseize lubricants can reduce torque required by approximately 20%. |
Posted: Thu Jan 28, 2010 9:52 pm Post subject: |
| ToolBox wrote: |
| j.pickens wrote: |
| sventinker wrote: |
| MDMetrics wrote: |
Well, I guess I've been "overtorquing" all this time.
I plan to continue to do so. _________________ Founder and Chairman Emeritus, ECMSAS
campingbox  Samba Member
Joined: November 14, 2000 Posts: 10264 Location: Petaluma, CA
Posted: Thu Jan 28, 2010 10:08 pm Post subject: |
| j.pickens wrote: |
| ToolBox wrote: |
| j.pickens wrote: |
| sventinker wrote: |
| MDMetrics wrote: |
I plan to continue to do so. |
83% or statistics are made up. |
Posted: Thu Jan 28, 2010 11:09 pm Post subject: |
| Quote: |
| 83% of statistics are made up. |
that is some funny sh*t _________________ April 3rd 62 standard mgr/pw
Includes 6 popouts
025 Safety belts
| dawerks wrote: |
Posted: Sun Feb 26, 2012 8:15 am Post subject: |
anybody have a source for the proper grade bolts?
I got black ones from the store but they were 8.8 rated. The Kamax bolts are 10. Next grade is a 10.9 I think. I ordered bolts from Wolfsburg West thinking they would be the right grade but they gave me silver 8.8 bolts.
My Kamax bolts were a little to worked over to reuse. |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 21004 Location: Sandpoint, ID
Posted: Sun Feb 26, 2012 9:12 pm Post subject: |
McMaster Carr? Fastenal? _________________ Confusious say it takes it takes two wipes to know you need three, but it takes three wipes to know it only needed two. |
