jbow1076 Samba Member
Posted: Sat Aug 22, 2009 12:27 pm Post subject: Input shaft seal removal |
Hi All, I am trying to remove the input shaft seal on my 70 fastback and it is giving me fits. Does anyone know any tricks to removing this seal? thanks, Jeff |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sat Aug 22, 2009 12:37 pm Post subject: |
Mine are home made, but they work.
_________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Sat Aug 22, 2009 12:57 pm Post subject: |
is the original seal a rubber rings with metal inside? I have the rubber off and now I can't figure out how to get the metal out...ugh! |
Posted: Sat Aug 22, 2009 12:59 pm Post subject: |
Yes, the seal is made from a metal base with rubber over that.
You will have to get that metal piece out. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Woreign Samba Member
Joined: June 04, 2006 Posts: 2841 Location: Crestview FL
Posted: Sat Aug 22, 2009 2:21 pm Post subject: |
I have had good luck drilling a long screw into the metal part of the seal, and then using a hammer to pull on the screw and pull the seal out. I typically have to drill two screws, one on each of the seal, to remove it. |
Tony K Samba Member
Joined: June 15, 2009 Posts: 9 Location: Salt Lake City, UT
Posted: Sat Aug 22, 2009 3:20 pm Post subject: |
I used a seal puller on mine. $8-10 at Sears I believe.
Posted: Sat Aug 22, 2009 8:05 pm Post subject: |
Tony K wrote: |
That is kind of like the factory one. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
