generator wire
zabo
zabo is offline
PostPosted: Fri Aug 28, 2009 4:57 pm    Post subject: generator wire Reply with quote
old gen:
I just got this rebuilt generator- my old generator didnt have this wire.
Where does it go? what does it do?
thanks
1960 36hp sedan- 1978 adventurewagen
What will you do when the label comes off and the plastic's all melted and the chrome is too soft? ~FZ
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Fri Aug 28, 2009 5:23 pm    Post subject: Reply with quote
I've seen the picture of that one in the Bentley before and wondered about it - it's got all three wires going to the voltage regulator. But I don't recall ever seeing one of those in person before. (never messed much with 6V stuff - got rid of 6V on my 62 very soon after I bought it) Here's the image from the Bentley:
-Andy
zabo
zabo is offline
PostPosted: Fri Aug 28, 2009 5:31 pm    Post subject: Reply with quote
agh- im guessing i cant use my current regulator then?
Numbers on my regulator
TA7v45A
0190213036
are those two wire coming out of the circle hole being connected to the same terminal?
The Android
PostPosted: Fri Aug 28, 2009 7:17 pm    Post subject: Reply with quote
I wish I knew the answer.... hopefully someone whose dealt this this can chime in.
zabo
zabo is offline
PostPosted: Sat Aug 29, 2009 8:55 am    Post subject: Reply with quote
are both wires coming out of the circular hole DF and the single one is D+?
zabo
zabo is offline
PostPosted: Mon Aug 31, 2009 7:45 am    Post subject: Reply with quote
can anybody confirm? thanks
Jody '71
Jody '71 is offline
PostPosted: Mon Aug 31, 2009 9:47 am    Post subject: Reply with quote
Zabo,
I just pulled an old Bosch Brazilian 6V regulator out of my stash that matches the #'s ( well sort of) on yours. I seem to recall it's about 15 years old. It says:
0190 212 032
TA 7V 45A
446
This came off a '66 from a friend of mine's that was still and remains to this day 6V. Can you kinda give us an idea where this wire originates from inside the generator? Where did you get this rebuilt from, is there a web link? It may be that you don't need that wire hooked up to anything and you can tape it off or something similar, but Andy has given you some really good info to ponder. Maybe some of the the early Beetle guys that still retain 6V will offer the differences in say like late model rebuilt 6V gens as opposed to your original.
'66 Beetle
2011 Hyundai Elantra Touring
zabo
zabo is offline
PostPosted: Mon Aug 31, 2009 11:37 am    Post subject: Reply with quote
hey jody its the gr11x
Its the only 6v generator i could find that anyone actually had in stock
link here -http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-111-903-021-H
Jody '71
Jody '71 is offline
PostPosted: Tue Sep 01, 2009 6:21 am    Post subject: Reply with quote
On the new gen, is there a flat spade connector on that far right wire coming out of the round hole? Looking at Andy's pic, it looks like you would need one and then a female connector attached to the VR post on that side. Or, just take the bare end and attach it with the other connection on the same side when you tighten down the screw. This is by no means any confirmation however.
'66 Beetle
zabo
zabo is offline
PostPosted: Mon Sep 14, 2009 5:57 am    Post subject: Reply with quote
just for anyone searching in the future- both wires coming out of the circular hole DF and the single one is D+
