interesting cooling fans
sportee
sportee is offline
PostPosted: Tue Nov 22, 2005 3:00 pm    Post subject: interesting cooling fans Reply with quote
take a look at this website:
http://www.rockyjennings.com/race_engine_pics.htm
has anybody ever seen anything like this setup? how much air would heach of these blowers have to flow to do the job that a stock cooling fan would at 5000 rpm?[/img]
ekimthemad
ekimthemad is offline
PostPosted: Tue Nov 22, 2005 3:50 pm    Post subject: Reply with quote
Cooling set ups like that are pretty common on drag race engines. They are basically used to cool the heads inbetween rounds. I have a friend that even used 4 computer fans with some custom aluminum cylinder tins that actually works rather. They won't flow anywhere near enough air to keep a street engine cool though.
Mike
59 single, 66 bug, 69 bus, 73 super
Member of the Ddk
Remember never argue with a moron. They'll drag you down to their level and beat you with a lifetime's worth of experince.
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger Gallery Classifieds Feedback
Banzai KG
Banzai KG is offline
PostPosted: Wed Nov 23, 2005 9:01 am    Post subject: Reply with quote
If you're gonna run the electric race cooling fans on your engine, you might as well get the eletric hair dryer for your forced induction turbo setup, slap a bunch of sticker, graphics, a two or three-tier wing. Uhhh...you get the picture.
Electric fan setup is used used for racing as ekimthemad mentioned above.
Racers typically drill, screw, or rivet these electric fan assemblies to their stock cylinder covers. The use of an electric fan will NOT provide adequate cooling for driving on the street, but it's enough for 1/4 mile racers to get back to their pit-space, and keep them running for further cooling while the engine is off!
These fans draw about 6A each.
Jim Kikuchi
Sunnyvale (near San Jose), CA
1964 Karmann Ghia coupe
V.V.W.C.A. - Golden Gate Chapter: http://www.ggcvvwca.org/
B.L.T.N. (Better Late Than Never) late model VW Club (San Jose/Santa Clara, CA): https://www.facebook.com/groups/bltnvw/
NorCal Aircooled Group (NAG) Facebook Goup: https://www.facebook.com/groups/NAGVW/
sportee
sportee is offline
PostPosted: Wed Nov 23, 2005 11:56 am    Post subject: Reply with quote
Exactly - those fans are to cool the engine in the pit after a 1/4 mile run.
i_want_a_pre_49_ratbeetle
i_want_a_pre_49_ratbeetle is offline
PostPosted: Thu Nov 24, 2005 7:52 am    Post subject: Reply with quote
i was talking to a kid recently he said was going to try a gas leaf blower to see if it would put out enough volume of air for street driving was planing to mount it under the front & run pipe to back to a y above the engine & to tin & was going to use a small alternator mounted low to charge battery he wanted to do this for the psyche when people saw it cruising with no fan he wasnt planning to run an engine lid i couldnt give any advice he was going to run an oil temp gauge & said was going to use 4 cylinder temp gauges 1 for each plug to watch to make sure didnt over heat.
maybe someone on here can coment?
wasnt planning for long trips just around town cruising
i think he is warped. but i laughed it might work but i have no idea & i wouldnt want to have to be filling up small 2-cycle tank under hood & hear that screaming leaf blower while driving. but he is just a kid & will try things even if foolish. & this 1 might be doable but i really dont know the answer
ill tell him what is said next time i see him.
Randy
clearsurf2001
Samba Vaccinator
clearsurf2001 is offline
PostPosted: Thu Nov 24, 2005 8:33 am    Post subject: Reply with quote
i_want_a_pre_49_ratbeetle wrote:
... try a gas leaf blower ...
Randy ... tell your friend that all great inventions are born by such "out of the box" thinking. He's a true innovator. Gently remind your friend that leaf blower engines are 2 stroke and most of them don't have oil injection. Therefore ... he'll have to set up a stand alone premix fuel supply, figure out what to do with the exhaust, lose about 50% of his airflow due to the routing of his "pipe and Y" configuration ... oh yeah ... he'll have to supply a source of air for the little buzz bomb engine for induction as well as cooling (gee they're aircooled too). Don't rain on his parade too much though. I'm sure that primates used to dope slap each other once they discovered that peeling a banana made it taste soooo much better. Compiled from the "Thought You Knew?" archives.
Get ready for the injection Smile
Make sure it is coherent. Rodney
mharney wrote:
I think Glenn has an EMPI crank in his engine.
PostPosted: Thu Nov 24, 2005 10:02 am    Post subject: Reply with quote
ok cool well i talked quite a lot few weeks back he had planned to mount the blower motor in his superbeetle & for exhaust he was going to braze extension pipe & route it into lower front wheel well opening with flex exhaust pipe if can find that small said the tube was going to be routed on passanger floor in middle sorta out of the way he had planned to keep transistion pipes as good as he could for the best airflow he said was going to make a bigger fuel tank like 2 gallons & was planning to take a 1 gallon fuel tank every where he went to mix fuel while he was out & about if needed to & was planning to take a small electric leaf blower to get him home if the gas 1 died on him that he could plug into a small 400 watt inverter depending on if it heated up or drive slow? & as far as intake air he was planning to make a small box ducted from hood vents to force air around the motor & there isnt any tubes coming from under the car for defrost so hot air will exit from there as well any areas not sealing good on the hood.
he figures it will be a good experiment for an old engine & a good learning experience & if he likes it & the cooling works he wants a 1776 dual kadroned motor in it & watch peoples expression as he runs all over & no cooling visible & it would free up some power just like the racers do it.. & for alternator he mentioned small riding lawn tractor style just needs to keep battery charged & wont do much night riding no radio just stock lights & ignition & the starter & horn.
im curious myself. thats why i talked to him so much it is crazy but it might work.
Randy
fitnessforyoutoo
fitnessforyoutoo is offline
PostPosted: Tue Aug 14, 2007 6:49 pm    Post subject: Re: interesting cooling fans Reply with quote
Run methanol and you wont need any cooling tin to drive around town. I used to have an 1835 set up like that with an electric radiator fan over the motor but never had to turn it on even in traffic.
2stroke
2stroke is offline
PostPosted: Tue Aug 14, 2007 6:51 pm    Post subject: Reply with quote
nothing quite beats german tin/fan setup for the price...
myolbug
myolbug is offline
PostPosted: Tue Aug 14, 2007 9:04 pm    Post subject: Re: interesting cooling fans Reply with quote
Was it straight Meth or mixed with...?
"To my mind it is wholly irresponsible to go into the world incapable of preventing violence, injury, crime, and death. How feeble is the mindset to accept defenselessness. How unnatural. How cheap. How cowardly. How pathetic." Ted Nugent
candyman wrote:
i broke my brain over ten years ago and its still dumb
fitnessforyoutoo
PostPosted: Tue Aug 14, 2007 9:31 pm    Post subject: Re: interesting cooling fans Reply with quote
It was straight, run though highly modified 48 Dellortos with 14-1 compression. It takes around 2.25 times more alcohol than gas if you want to find out what jet sizes to use plus you have to reduce the air jet about in half and switch the needle and seat to a bigger one. Oh and they did not sell jets back then so I have over 100 drill bit sizes, there are numbered, lettered and inch bits.
1956 2000cc 30 psi + boost, methanol EFI NOS chop top turbo sedan under construction
Eaallred
Eaallred is offline
PostPosted: Wed Aug 15, 2007 6:30 am    Post subject: Reply with quote
I have the same fans on my motor:
They pretty much suck. When I switched to those, I watched my head temps SOAR. I knew it would run hotter compared to the fanshroud but being a drag car I figured the added cooling while the engine was turned off would offset them.
Boy was I wrong. They don't blow air for squat. Going through the traps my head temp (under #3 spark plug) was 425-450. That's just starting the engine up, doing a burnout, staging, and taking off. Never mind after that I still had to drive the car back to the pit space. Honestly, the engine ran cooler with no cooling system on it at all. My heads were cooler going through the traps with a bare motor by about 50 degrees. Still much hotter than with the stock shroud of course.
I have since switched over to E85 to run cool enough with those fans to make them work. No doubt I would still run cooler without them, but I spent $100 on them so by god, i'm going to use them.
I was talking to a friend of mine that also runs those fans and told him how hot the engine ran with them on and he told me "I've never had a problem with mine", to which I reminded him "You don't run a head temp gauge either". He laughed to me "I don't want to, do I". LOL. I guess they work fine if you aren't looking at what they're actually doing I guess.
Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn.
myolbug
myolbug is offline
PostPosted: Wed Aug 15, 2007 3:17 pm    Post subject: Reply with quote
[quote="Eaallred"]I have the same fans on my motor:
Dayum! That there's a purdy enjine!
fitnessforyoutoo
PostPosted: Wed Aug 15, 2007 4:19 pm    Post subject: Reply with quote
Try moving your firewall back to the nose cone of the trans and your cooling will greatly improve almost for free if you do it yourself.
Eaallred
Eaallred is offline
PostPosted: Wed Aug 15, 2007 7:24 pm    Post subject: Reply with quote
How do you figure?
Eric Allred
fitnessforyoutoo
PostPosted: Wed Aug 15, 2007 7:30 pm    Post subject: Reply with quote
How do you figure?
Because the air comes from up under the car when it is moving and pushes right over the top of the engine and out the back. Then around the propped open deck lid or air release doors in the rear.
stonerbug
stonerbug is offline
PostPosted: Mon Sep 21, 2009 1:08 pm    Post subject: Reply with quote
i read that the stock fan porduces 1250cfm at 4500rpm?? wouldnt you just have to over come that? i found a 6" cooling fan that moves 1600cfm on summit.. what about two of those and a custom made shroud to hold them. that would be 3200cfm total. i looked at some cage fans and saw that some of them only about 300-600 cfm.. the though of doing the 6" fans has crossed my mind just because the car wont do a dd so if all else fails i could use one on my motorcycle... doing simple math there is just 625cfm per side so wouldn't 1600cfm be plenty of air, or simply too much for the air cooled motor?
Stuggi
Stuggi is offline
PostPosted: Mon Sep 21, 2009 1:15 pm    Post subject: Reply with quote
What I'm always thinking is why the heck doesn't people get an electric motor, attach it with a fan belt to the fan and spin that puppy with that instead. You would probably need a gutted out generator/alternator for supporting the fan. Alternatively you could convert an alternator into a motor at a rewinding shop or use a combined starter/generator, I know for a fact that Bosch used to make one that looks identical to the old 12V generator on beetles.
Orange Bug 1970 Beetle
Green Bay Bus 1969 Panelvan
Orange VW Fest!
Pulled out of a Lake Fest!
Jimmy111
Jimmy111 is offline
PostPosted: Mon Sep 21, 2009 1:19 pm    Post subject: Reply with quote
See if it can move 1500 CFM at 2 psi or 60 inches of water.... Wink
miniman82
Samba Swamp Donkey
miniman82 is offline
PostPosted: Mon Sep 21, 2009 1:21 pm    Post subject: Reply with quote
How do you figure?
I know this happens for a fact, cause I drove my Bug around for a while with the package tray cut out. I've since gotten a box to cover the turbo system, but I can tell you that the amount of air coming up there from under the car is impressive. It's also the same reason why I don't need a fan on my oil cooler, it gets more than enough air where it's at on the right side of the frame horns.
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote:
satterley_sr wrote:
I just wanted to bitch but I'm getting no sympathy.
Welcome to the Samba.
