Dead Water Pump- What Else to Check?
vegpedlr
vegpedlr is offline
PostPosted: Mon Jun 19, 2017 6:29 pm    Post subject: Dead Water Pump- What Else to Check? Reply with quote
So I recently finished a great long trip through the Southwest. No problems, just a few sips of fluids and an oil change.
BUT now:
Heard a squealing belt a couple blocks from my parents' house. Idiot light for battery on, so my conclusion is the alternator belt. Took a look, and the banshee was the alternator belt not moving. Loosened the belt and took a brush to clean out the crud on the water pump pulley. The pulley would not turn a complete circle, getting really stuck.
So it looks like a call to VC for a new water pump. This one has about 40K miles. Any ideas what may have caused this other than simple failure? Anything else I should check while I wait? It also recently started leaking some coolant, probably from the pump, but not sure.
1985 Tintop 4 sp GW 2.3 “Connie”
2006 Mk V GTI 2.0 FSI “Penelope”
heidi85ho
heidi85ho is offline
PostPosted: Tue Jun 20, 2017 4:43 am    Post subject: Re: Dead Water Pump- What Else to Check? Reply with quote
Check out this thread for some chat on wp failures.
https://www.thesamba.com/vw/forum/viewtopic.php?t=651168&highlight=water+pump+failure
85 westy-1.9-standard trans, FAS GenV 2.0
