thedavidson Samba Member
Joined: September 27, 2009 Posts: 12 Location: Berkeley, CA
Posted: Tue Oct 06, 2009 2:10 pm Post subject: Syncro help! Shuddering at 10-20mph |
I searched the forums and couldn’t find any problems that sounded like what is going on with my Syncro. As I accelerate or decelerate, at around 10-20mph the van shudders and it feels like I am driving on a washboard. It happens even when I pull it out of gear. The engine is not sputtering or varying rpms when this is happening which makes me think it is not the engine. Could this be transmission, cv joints, viscous coupling, etc? Thanks for any help! |
jpwerks  Samba Member
Joined: July 16, 2009 Posts: 56 Location: Pacific Grove,Ca
Posted: Tue Oct 06, 2009 2:50 pm Post subject: |
Could be your driveshaft.Maybe bad universals. _________________ 81' single cab 1.8T Syncro (converted)
85 Vanagon 1.8T
55 chevy
2008 330i BMW
2000 jetta 1.8T
2004 Golf 2.0 |
WestyBob Samba Member
Joined: June 11, 2004 Posts: 2346 Location: Portland, Oregon
Posted: Tue Oct 06, 2009 3:04 pm Post subject: Re: Syncro help! Shuddering at 10-20mph |
Could be the driveshaft needs adjustment/rebuild or replacement. But could also be suspension related. How's the alignment ? Any tire bulges or something stuck in there (inspect) ? |
blakeck2 Samba Member
Joined: April 10, 2009 Posts: 939 Location: Los Osos, CA
Posted: Tue Oct 06, 2009 3:20 pm Post subject: Re: Syncro help! Shuddering at 10-20mph |
thedavidson wrote: |
mine does that occasionally and its a 2wd  |
Alaric.H Samba Member
Joined: March 28, 2009 Posts: 2529 Location: Sandy Springs GA
Posted: Tue Oct 06, 2009 5:10 pm Post subject: |
The last time I saw a syncro do something like that the trans nose got riped off from the bad vibes. |
Dogpilot Samba Member
Posted: Tue Oct 06, 2009 5:27 pm Post subject: |
Could be the driveshaft, but could also be one of the eight CV joints as well. A loose or worn out CV can cause odd vibrations to move back through the system. _________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
Grizzly_black Samba Member
Posted: Tue Oct 06, 2009 10:25 pm Post subject: |
The front outer CV joints vibrate something fierce when they go dry and are shot. It also makes a lot of noise. Turn slightly back and forth while driving at the speed where it is loudest. If the noise gets louder when you are turning the wheel it is probably the outer CV. I have a bad one on my syncro right now. I am up in the Alaskan bush, so 20 mph is about my average speed on dirt roads. I can't wait for my Lobro axles to get here. The noise is driving me nuts! |
Sir Sam Samba Member
Joined: July 19, 2009 Posts: 1724 Location: Fort Collins Colorado!
Posted: Tue Oct 06, 2009 10:46 pm Post subject: |
Had a similar problem on my 87 syncro years back, replaced the U-joints and the problem went away. _________________ '91 Carat Westy
87' Syncro + '87 Westy conversion coming soon |
Posted: Wed Oct 07, 2009 1:58 pm Post subject: |
Sounds like the place to start would be to pull the drive shaft. I will give it a try and report back. Thanks again. _________________ '86 Syncro |
Posted: Mon Oct 12, 2009 11:56 am Post subject: |
Pulled and replaced the drive shaft yesterday. The front U-joint was nearly frozen in one direction. The problem seems to be fixed for now. Thanks again for the advice! _________________ '86 Syncro |
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2717 Location: Missoula MT
Posted: Mon Oct 12, 2009 12:37 pm Post subject: |
Pulled and replaced the drive shaft yesterday. The front U-joint was nearly frozen in one direction. The problem seems to be fixed for now. Thanks again for the advice! |
did you rebuild your existing shaft or buy a new one? |
